Question about GE JBP25 Electric Kitchen Range
Temperature conversion from numbers to actual temperatures
I have a whirlpool electric stove..we are living overseas so not North American version. On the oven settings there are numbers 1-11. I have no idea what these numbers mean in terms of temperature i.e 200, 250' etc. Do you have any idea of the conversion?
catriver
  • 878 Answers
SOURCE: Oven, Broiler inopperable
Sandwich, is it your bake or broil thats not working? You have two ignitors, one for bake and broil. One of them is your culprit. This is not a hard job. The post header says broil not working so the part number for that is WB13K0003. Bake ignitor is WB13K0004. To get at the bake ignitor you have to remove the oven bottom inside panel, remove the flame spreader (both easy). The click you are hearing is the board relay sending power to the ignitor. The ignitor has to draw so many amps to open the gas valve. The oven is pilotless. Catriver..post back.
Posted on Apr 21, 2007
WhIzAtIt
  • 136 Answers
SOURCE: GE Spectra XL Oven does not maintain oven temperature
The most logical solution for your problem would be a faulty thermostat, but yet at the same time i dont understand how it would heat to the temp desired then not come on at all. I would definately change the thermostat to start off with. Let us know :-D
Posted on Sep 14, 2007
I have the exact problem. We had the ignitor replaced 2 already and it works for 18 months and stops. Occasionally, it the oven won't even start to heat. I am ready to throw it out.
Posted on Sep 18, 2007
  • 7 Answers
SOURCE: GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Posted on Sep 28, 2007
  • 58 Answers
SOURCE: Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Posted on Oct 31, 2007
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
My Laser 30 went into power saver mode by itself and now I can't get it out of said mode, otherwise it's working well.
Rick,
Sorry to hear you're having issues with your Toyo, first off do you have a manual for your stove? If not, you can download one online, I've included the link for your convenience.
Your Toyo has a series of control buttons across the top and/or the front, the "On/Off" button for the "Power Saver Mode" is located in the middle. You can turn the mode On or Off, though you actually WANT to utilize the Power Saver Mode. It's intended to prevent unnecessary ignitions on the stove, thereby lowering your electrical consumption as well as wear & tear on the stove. All you need to do is set a maximum and a minimum temperature and whenever the temperature is not within the parameters you've established the stove will then either ignite to heat the area to your pre--determined setting or shut off until the temperature is within the parameters you've established. If there is NO error code(s) showing, and the stove is running fine, then I would not be concerned. Though I do suggest you immediately download the manual, read it thoroughly, and when necessary use it to troubleshoot future issues.
I hope this helps you, good luck and stay warm!
Regards,
Shekele
North Pole, Alaska http://www.toyotomiusa.com/OwnersManuals/Vented%20Heaters/Name%20begins%20with%20Laser/Laser%2030%20(Type%20D).pdf
Oct 09, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
How do I change from celsius to farenheit?
Use this handy temperature conversion calculator. If you are going to need it often, you might want to bookmark it.
http://www.metric-conversions.org/temperature/celsius-to-fahrenheit.htm
Sep 11, 2011 | Whirlpool RF368LXKS Electric Kitchen Range
How do I change the temp fro m degrees C to degrees F? I have a Accubake System single oven. Thanks!
From Page 15 of the Manual:
Press and hold the "Custom Broil" pad for 5
seconds. A short tone will sound
NOTE: The temperature display will go off
and the temperatures displayed will
after a conversion. The temperature display
be converted. To switch back to "F, repeat the instructions above.
NOTE: The temperature display will go off after a conversion.The temperature display will reappear the next time you press a cook function command pad.
Jul 16, 2011 | Whirlpool RBS275PD Electric Single Oven
We have a Whirlpool electric stove. The oven keeps turning itself off. It heats up and then clicks off, repeatedly. The element appears to fit tightly.
This sounds like a temperature limit switch is shutting the oven off. These are located behind he back panel on the rear of the stove.
Oct 28, 2010 | Whirlpool Kitchen Ranges
Why did stove have F2?
F2 During BAKE Control senses oven temperature above 615F-630F If actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature. F2 During CLEAN Control senses oven temperature above 915F-930F If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches.
Sep 25, 2010 | GE 30" Self-Cleaning Freestanding Electric...
Whirlpool range 465 model # sf369lemo oven temperature
no stove holds a true temp they all fluctuate temperature depending on how well it is insulated.
Feb 06, 2010 | Kitchen Ranges
I need correct temperature readings
On most US ovens the high temp is 550f and the lowest is around 100f for warm. I would imagine 1 is warm and 5 is 550f so 2 would be 250 3 would be 325 4 would be 425. Or you could say ribs and slow cooking 2, cake 3, cornbread 4, and 5 would be broil. The only way to know is set each number and place an oven thermostat in there to see what the temp is fer each number. Personally my grand mother cooked on a wood stove and never had a knob, she just shoved the biscuits in the oven and added another stick of wood.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 28, 2010 | Ovens
Temperature Display
Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “°F” will appear on the lower oven display for
3 seconds.
A complete owners manual can be downloaded from
http://shared.whirlpoolcorp.com/product_literature/search.jsp
Thanks for using Fix Ya, please take the time to rate this solution.
clarkco
Feb 06, 2009 | Whirlpool GBS277PD Electric Single Oven
GE JBP25 Electric Kitchen Range Logo
245 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
