Question about Faberware FCP280 Coffee Maker
I dropped my 4-8 cup farberware coffee pot; it no longer works. can it be fixed?
    Scholar:
  • 176 Answers
Hi. It can be fixed, but the cost will be high. You can not gets parts for them. I repair them and have to make the parts I need.. bobbyone
Posted on Aug 11, 2010
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
How much coffee do I use for the 22-cup Farberware coffee pot?
that would depend on the coffee, and how strong you like it.
as well as how large your standard cups are.
I use 1/4 cup of folgers classic blend for 4 'normal' cups of coffee. I also use an oversized camping mug - so 4 normal cups fills two of the mugs. - - - you may want to try 1 1/8 cup of coffee grounds in the filter if making a full pot.
regards,
Oct 12, 2010 | Faberware 12-55 Cup Coffee Urn
3 prong plugs becoming loose
Hi, You have a pot that was made in China. to fix the problem you have you have to replace the base. You can try to get one at Goodmens.com or Repair Shop.com. The China pot is very very inferior to the USA pots. I suggest buying a USA pot on eBay. The China pot is like owning a boat. Good luck . Ron
Jul 23, 2010 | Farberware FCP280 Stainless Steel...
I have farberware 56 cup coffee maker w. no instructions. How much coffee do I add to coffee maker for each cup?
I heaped teaspoon for every person + one for the pot
very simple to remember.
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | Faberware Farberware FSU236 12-36 Cup Urn...
Looking for a replacement handle for a FCP412
Go to my eBay auction. look for Farberware coffee pot parts. They are use but you cannot buy a new one (Ron622c) Good luck. bobbyone
Dec 26, 2009 | Faberware FCP412 Coffee Maker
My Farberware coffee maker starting making a high
Hi Farberware China pots and USA pots perk super fast. That is what making the racket. It will stop when the coffee is ready. bobbyone
Sep 21, 2009 | Faberware 2-8 Cup Percolator
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Coffeepots not operating by not getting hot enough
Hi. Sue, Problem is you're buying China pot's. One of 2 things can cause that problem. The Thermostat or the keepwarm element. 9 out of 10 it is the thermo. The parts are not available in the USA. I have a eBay auction site. I have to make the thermo's out of USA ones. They are 8.00 plus 2.00 S/H. My eBay name is ron622c. If you want to stay with Farberware you can buy a used one or if you are lucky a new one. But don't buy a China one, Good luck. Ron
Jul 06, 2008 | Faberware FCP280 Coffee Maker
8-cup Farberware electric coffee maker
Hi, I just posted this for the FCP412 model: here it goes again.
I've had the same problem, I went with a percolator since our water is hard and we calcify the heating element within about a year. Having the FCP-412 stop working has made me angry as well.
1st, I placed an order for a P04-303 thermostat. It seems to be the correct replacement but we'll see. You can find it here: http://www.goodmans.net/get_item_fa-p04-303_farberware-p04-303-thermostat-for-coffemaker-urn.htm
2nd, here is my 1 cent fix. Really, insert a penny under the thermostat. The delay that it takes to additionally heat the penny will increase the duration that the 1000 Watt element is on. You can experiment with other materials just make sure it isn't flammable (it's next to the element) and it is not too insulate (you want the thermostat to open the circuit some time after the start of the heating cycle (3-3:30 minutes).
Good luck. -david
Oct 09, 2007 | Faberware FCP280 Coffee Maker
Faberware FCP280 Coffee Maker Logo
60 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Starnley Johnwells
Starnley Johnwells
Steve
Kolbrun...
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
