Question about LG LAC-M6500R CD Player
Lg lac m6500
I need to know which pins are for ignition,remote,ground,and batt can you help
2000 Ford mustang 3.8 cranks won't start diagnostic gives code b1353
B1353 Ignition Key-In Circuit Open GEM Go to Pinpoint Test B .
PINPOINT TEST B: THE KEY-IN-IGNITION CHIME DOES NOT OPERATE CORRECTLY
Do you know what the GEM - genaric electronic control is ?
You need a scan tool to check ignition switch position .Don't know if this would cause a no start . Have you check for ignition spark and fuel pressure ? Are there anyother problems with power door locks or windows or lighting ? Thing's the GEM controls ?
CONDITIONS DETAILS/RESULTS/ACTIONS B1 CHECK IGNITION STATES
NGS
Monitor the GEM PIDS IGN_KEY, IGN_A, IGN_S, and IGN_R while cycling the ignition switch through the OFF, ACC, RUN, START and key out positions.
  • Do the PID values agree with the ignition switch states?
Yes GO to B2 .
No GO to B4 . B2 CHECK GEM INTERNAL TONE OPERATION Trigger the GEM Active Command CHIME ON and OFF.
  • Does the chime operate correctly?
Yes GO to B3 .
No INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs. B3 CHECK GEM INPUT FROM DOOR AJAR CIRCUIT Monitor the GEM PID D_DR_SW, while opening and closing the driver door.
  • Do the GEM PID D_DR_SW values indicate CLOSED and AJAR correctly?
Yes INSTALL a new GEM. For additional information, REFER to Section 419-10 . REPEAT the self test. CLEAR the DTCs.
No GO to Pinpoint Test D . B4 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 28 (15A)
CJB Fuse 28 (15A)
Measure the voltage between CJB Fuse 28 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and START positions only?
Yes GO to B5 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B5 CHECK GEM INPUT VOLTAGE FROM IGNITION SWITCH AT CJB FUSE 32 (15A)
CJB Fuse 32 (15A)
Measure the voltage between CJB Fuse 32 (15A), Pin 1, harness side and ground while cycling the ignition switch through all positions.
  • Is the voltage greater than 10 volts in the RUN and ACC positions only?
Yes GO to B6 .
No REPAIR the CJB. REPEAT the self test. CLEAR the DTCs. B6 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 911 (WH/LG)
CJB Fuse 28 (15A)
GEM C352
Insert ignition key. Measure the resistance between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and CJB Fuse 28 (15A) Pin 2, Circuit 911 (WH/LG), harness side.
  • Is the resistance less than 5 ohms?
Yes GO to B7 .
No REPAIR Circuit 911 (WH/LG). REPEAT the self test. CLEAR the DTCs. B7 CHECK GEM VOLTAGE INPUT CIRCUITS FOR OPEN - IGNITION SWITCH CIRCUIT 1002 (BK/PK) Measure the resistance between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and CJB Fuse 32 (15A), Pin 2, Circuit 1002 (BK/PK), harness side.
Yes GO to B8 .
No REPAIR Circuit 1002 (BK/PK). REPEAT the self test. CLEAR the DTCs. B8 CHECK GEM INPUT CIRCUIT FOR OPEN - KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK) Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
Yes GO to B9 .
No REPAIR Circuit 158 (BK/PK) and key-in-ignition switch for failure. For additional information, REFER to Switch-Key-In-Ignition Warning . REPEAT the self test. CLEAR the DTCs. B9 CHECK GEM VOLTAGE INPUT CIRCUITS FOR SHORT TO POWER - IGNITION SWITCH CIRCUITS 911 (WH/LG), AND 1002 (BK/PK)
CJB Fuse 28 (15A)
CJB Fuse 32 (15A)
GEM C352
Remove ignition key. Measure the voltage between GEM C352 Pin 8, Circuit 911 (WH/LG), harness side and ground, and between GEM C352 Pin 22, Circuit 1002 (BK/PK), harness side and ground.
  • Are voltages greater than 10 volts?
Yes REPAIR the circuit in question. REPEAT the self test. CLEAR the DTCs.
No GO to B10 . B10 CHECK GEM INPUT CIRCUIT FOR SHORT TO GROUND -- KEY-IN-IGNITION SWITCH CIRCUIT 158 (BK/PK)
GEM C352
Remove ignition key. Measure the resistance between GEM C352 Pin 9, Circuit 158 (BK/PK), harness side and ground.
  • Is the resistance greater than 10,000 ohms?
No REPAIR Circuit 158 (BK/PK). REPEAT the self test. CLEAR the
Jan 03, 2017 | Ford Cars & Trucks
Need to know how to program keyless remote on 98 cavalier
1997 Cavalier remote keyless entry programming.
All Remote Keyless Entry Modules may be programmed to receive four different
transmitters which all may be used to operate the remote control lock system on the
vehicle.
Also, severalvehicles, each with the same system may all be programmed to operate from the same transmitter or four different transmitters.
Step 1. Turn ignition off
Step 2. Ground the program pin.(within one second, Lock, Unlock and Trunk will cycle to indicate module ready for programming.)
**the program pin is the two wire connector plugged into the RKE reciever in the trunk of the vehicle at the Left Wheelhouse. Leave the main harness plugged in but unhook the two wire connector and ground the pins.**
Step 3. Press and hold the LOCK and UNLOCK buttons until:
Lock, Unlock, Trunk, and Horn cycles to indicate the transmitter has successfully been programmed. (This takes no more then 12 seconds)
Step 4. Repeat step 3 for the remaining number of transmitters
Step 5. Remove the ground from the program pin.
Step 6. Verify proper operation of the transmitters.
Keep in mind that 97-99 can be programmed by the owner, 00+ require DEALER programming with the scantool.
I hope helps with this (remember rated this help) Good luck.
Dec 29, 2009 | 1998 Chevrolet Cavalier
Dont know how usb works on lgm6500r cd player
Can you please post back, LG,can not find any devise with model# m6500r or lac-m6500r.
Mar 26, 2009 | LG LAC-M6500R CD Player
Disarming the alarm
Try this,I think this will work.Unplug the Remote anti-theft module in the right hand kick panel.It will have 2 connectors,one is 22 cavity connector and the other is 26 cavity connector.
Now best I can tell by looking at the Schematics you will have you take the wires from pin 11 PK/LG and pin 22 PK/YE in the 22 pin connector and pin 1 LG in the 26 pin connector and run these to a ground.Then leave the RAP module disconnected. This should keep your electric door locks working and disable the alarm.
Feb 12, 2009 | 2000 Ford Ranger SuperCab
Lg lac-m8600r not connecting via bluetooth with my phone
the code is 1234 or 0000 to put on your cell phone
Feb 01, 2009 | LG LAC-M6500R CD Player
I need installation instructions for a MTX thunder 280
BATT = 12v positve constant
GND = 12v negative or ground
REM. = 12v positive switched or remote wire.
The remote wire is most commonly found on aftermarket CD players. It's typically in the main wire harness. The most common color of this wire is blue with a white stripe.
Jan 20, 2009 | MTX Thunder 2-Channel Amplifier 282 Car...
My LG plasma gold ac's remote controler
If you lift the flap on your indoor air con there is a Emergency operation button on your right you can operate the aircon from there. Push once for 20 cooling and twice for 22 heating
But sounds like you need a new remote. If you want to know how to test the remote please let me know
Hope that helps
Nov 16, 2008 | LG LS-L1210CL Mini Split Air Conditioner
LG LAC-M8600R TEL MUTE PROBLEM
hi there i just had same problem cut and tape the tel mute wire,usually orange but some times white its the one that goes into a1 of the connector hope this helps,Laura
Aug 13, 2008 | Car Audio & Video
INFO:EQ
Sens is ussually a term for the more common "remote
" wire. You will need to look at diagram to be sure but Im about 99% positive that in your case the sens wire is the input wire for a switched ingnition, especially since you say it is located next to theGND and BATT wires. You will need to connect the SENS wire to 12v hot, similar to the BATT wire but this wire will need to be switchable, meaning it can be turned off and on, say when you turn your key on and off, or when you turn your radio on and off. For example, the remote wire output from the back of an aftermarket cd player, ussually blue with a white stripe or just blue, or the ignition wire of your aftermarket radio, ussually red, or the ignition wire of your factory radio, or any 12v switched fuse in your fuse box. They will all work. In a worse case senario, if you have trouble locating a true ignition wire, there is a short cut. If the EQ has an actual power button that you can turn on and off, you can make this short cut by wiring the SENS wire to the 12v hot BATT wire. Then you can manually turn the eq on and off with the power button. Just remember if you wire it up this way, and forget to turn it off when the vehicle is not running, after about 24 hours or so, the battery may be drained somewhat, and you'll have trouble starting your vehicle. This is definately your last option.
The BATT wire needs to go to the hot in the BATT or the memory ( yellow) from the aftermarket CD player. The GND needs to be connected to anything metal in the car that is connected to GROUND, for example the frame work of the dash board that is metal, or the ground wire from your aftermarket radio ( black).
The rca input will be the RCA;s coming from your cd player.
the rca output will go to your amplifier.
Placement is completely up to you.
If it came with brakets, placing it flat against the underside of the dash board should work. But it could litterally be anywhere, and any where where it will suit your needs. Glove box works well too, so does in side the arm rest console, if you can get you wire to reach good luck.
Jan 29, 2008 | AudioBahn AEQ6 5-Band Car Equalizer
Alpine 3523 no instructions or wiring
I know this is a little late but I have one and the hookup is very easy, On the right side of the amp there is a six pin plug. Above it it says BATT REMOTE GND. The two pins below BATT are the battery (V+). The pin below REMOTE is the (V+) switched turn on. The two pins below GND are the ground. The rest is simple. Two RCA inputs. The switch to select MONO(R), STEREO, or MONO(L) works as explained. If you want stereo, put the switch in the middle and supply two inputs and two speakers. The MONO(R) and MONO(L) are to select a single input that will supply a single (bridged) output. Connect two speakers and they will supply the same source or connect one speaker to the outer speaker terminals for higher power output. The variable or fixed switch just bypasses the GAIN CONTROL knobs(used for Alpine's 8 pin DIN plug on unit, for older EQ's and head units.
Jan 15, 2008 | Car Audio & Video
LG LAC-M6500R CD Player Logo
137 people viewed this question
Top LG Car Audio & Video Experts
Alan W Kelly
Alan W Kelly
richie46
Tom Chichester
Are you a LG Car Audio and Video Expert? Answer questions, earn points and help others
