SOURCE: Can't use built in webcam - Advent 6651
hi
read you problem.
to fix this up you have to follow few steps.
1.check if the driver for this is installed.it is there in system properties.
2.if it is installed try reinstalling the driver as it may not be installed properly.
3. if even after these things it dont work then check the webcame settings .
thnx
SOURCE: advent 4211c built in webcam
If you go to http://safemanuals.com/zearchres_6075.php
you can download the manual.
SOURCE: How do i turn on the built in webcam in the advent
Make sure you have correct driver installed properly. It dpends on the Operating System you are using as well. Like in Vista or Windows 7 you are likely to get some webcam drivers preloaded, whereas in XP you may or may not see the usb video device in the my computer panel. Also, if your webcam requires some special other applications to use it then check with your vendor to provide the same.
SOURCE: I have a Advent Roma 2001 T3100. Does is have a
hi there,
for clarification. just check if the pc has a small hole on top of the screen, like the one in cell phones. if it does, your pc has a webcam, if not it dosen't have one....
