Question about HP OfficeJet D135 All-In-One InkJet Printer
Error message scanner failure message each time i turn on the power. i have tried turning it off ,waiting 20 sec and then turning it back on...still got the message. tried unplugging it and replugging it in and still got that nasty message. don't know what to do now..any one have a solution??
  • 2 more comments
  • rey baron Nov 24, 2007
    my printer doesn't work
  • mcgen Dec 06, 2007
    I have the same thing happen with my d135. It worked fine a few days ago, and now I get this message. Is there anything I can do? Also, I did a print of my fax history before the message came on, and that worked fine. Right after that is when I got this message! Thank you.
  • Anonymous Jul 28, 2008
    turning the machine off and wiating 30 seconds repluging and not happens
  • my copier Aug 07, 2008
    Message comes on that says scanner failure. I can't fax out. I was able to receive faxes and print but now I can't even do that. I performed all the tasks mentioned for cleaning the glass and the bulb. I got lost on the part that says to remove the screw under the thing that you lift up to get to the print cartriges. Help me with more info on this or anything else that might work. Cheryl Mesa az
  • HP Master
  • 1,113 Answers
Clean the scanner head and glass
Removing the scanner glass
The Automatic Document Feeder (ADF) will need to be removed before the glass can be removed. You will also need a T10 Torx head driver approximately 6" long. Driver handles that accept removable bits may be too large in diameter for this particular job.
Removing the automatic document Feeder (ADF)
1. Hinge the ADF upward as if you are going to manually scan a document.
2. In the hinge area there is two black pull latches. Pull them up and lift the ADF straight up to remove it. Some side-to-side rocking may be necessary before it will disengage.
Removing the Scanner Glass
1. Remove the four T10 Torx head screws around the perimeter of glass, i.e. two in the ADF hinge area and one on the right and left.
2. Remove the Control Panel overlay. It pries off.
3. Open the printer as if you are going to access the cartridges and disengage the support legs. Two latches at the base of each leg must be pried outward with a slot style screwdriver to disconnect them. The scanner assembly will now "flop" freely, so steady it while removing the four screws on the underside.
Note: The screw in the front is hidden under the piece that you grasp to gain cartridge access. Two latches must be released to remove it. The screw can now be seen using a flashlight but may be obscured by some wires.
Clean the underside of the glass, giving particular attention to the white strip. Then clean the scanner bulb (gently, its thin glass) and the mirror(s) with a cotton swab sparingly moistened with Windex or a similar cleaner.
Posted on Dec 07, 2007
As am update to what I just wrote, my d135 says "warming up" before the message comes on. Does this mean something? Thank you.
Posted on Dec 06, 2007
Hp 1005 Scanner error 20 please suggest the problem
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it. Plug the device directly into the wall socket.
Use thepower switch to turn the device on.
Jul 08, 2011 | HP LaserJet M1005 Printer
Scanner error message
is your printer is detected in the device manager settings??
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Hi sir, i got a problem regarding the celcom broadband. the problem was happen since yesterday. i left my notebook for along time (may be about 20 hours) where i am not to turn off the celcom...
Power off the broadband modem and your laptop, wait 30 secs then power up the broadband modem until the modem has restarted, then boot up the laptop.
If you still have problems, leave me a comment with a description of what happened plus the error messages.
Jan 31, 2011 | Computers & Internet
I have an error message on my HP Photosmart Premium C309a - "Ink system failure - 0xc19a0027 - Please turn printer Off and then On" - I have done this as well as replace all of the ink cartridges &...
Unplug the USB cable from theback of the printer if it is connected. Now take out the power cord.
Now Reset the printer:-
To reset it.
Connect the printer power cord to the Wall Outlet or Wall Jack.
Make sure it is not connected to the Serge Protector or power strip.
Partial reset :-
Now on the printer itself. --> Press and hold the
# and 3 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 3 button the hold time )
(On the printer screen it should say Part nvm reset.)
Now try to turn on the printer and check if it shows the Ink system failure - 0xc19a0027 option. If it works Perfect. If not then do this :-
Semi-Full Reset:-
Open the front door and take out all the cartridges from the printer. Now close the door.
# and 6 button at the same time. Now take out the Power cable from the back of the printer and wait for 20 sec. Now put the power cable back in the printer. Now release the two buttons. ( Note :- remember you need to hold down the # and 6 button the hold time )
( On the printer screen it should say Semi-Full rest )
The printer might shut down automatically or may be it won't. At this point Put the cartridges back into the printer and then turn on the printer if it was shut down.
or If the printer is on turn it off and then switch it back on.
The problem should be resolved up till now.
If still the problem Exist Call HP as the product has gone bad. The printer will be replaced if it is still in warranty. Remember the printer HP replaces is always a refurbished printer.
HP :- 1-800-474-6836 ( Tech Support )
May 06, 2010 | HP Photosmart C5180 All-In-One InkJet...
Scanner failure
The "Scanner System Failure" error occurs if the scanner bulb is not heating to the correct temperature or there is some other issue with
the scanner hardware. Perform the following steps to resolve the error:
1. Verify that the scanner bulb is lit. If the scanner bulb will not
light up, the all-in-one will require to be serviced.
2. Perform a Power Cycle on the all-in-one as listed below:
a. Verify that the unit is switched on.
b. Remove the power cable from the back of the machine.
c. Wait for 20 seconds.
d. Reinsert the power cable in the backside of the unit.
3. If the error continues to persist, remove the power cord from any power strip and plug it directly into a wall power outlet. The power strip may not be supplying enough power to the product.
4. Cold ambient room temperatures may also cause this error. Move the all-in-one to a warmer room and see if the error reoccurs.
May 22, 2009 | HP PSC 750 All-In-One InkJet Printer
HP Officejet 6310 scans once but then says scanner failure
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
52 Scanner error
52 scanner error means yoy got got an error with the scan assy, it could be many problems. If it not helps with turn off /turn on, try reset the printer. Turn off power press and hold * and #, turn on power, wait 20 sec and release the buttons. If printer not goes to ready, disconnect power cord when printer initialize and turn off power switch. reconnect power cord and turn on power switch. If you get the printer to ready state, upgrade firmware.
Oct 15, 2008 | HP LaserJet 2840 Printer
Error code on 5300 printer
turn off the printer
unplug the power chord at the back of the printer
wait for 5-10 sec.
replug power chord
turn on the printer
Jun 12, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP officeJet K series scanner failure power off and on again
The "Scanner System Failure" error occurs if the scanner bulb is not heating to the correct temperature or there is some other issue with the scanner hardware
Please follow the below given instructions to resolve the issue.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Hope, this solution would work for you.
Jan 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet D135 All-In-One InkJet Printer Logo
117 people viewed this question
Ben Johnson
