Question about Yamaha RX-V430 Receiver
The receiver is not keeping the signal from my blu ray player. there's no sound or image. if i plug the player straight into the tv, it works great. but my brand new receiver, r-v436 works like ****.
    President:
  • Yamaha Master
  • 1,114 Answers
Your brand new receiver? that model is almost 4 years old? The HDMI version is generation 1 version 1.1 and riddled with problems. It's not a "Yamaha" problem, it's an "HDMI" problem. HDCP is the biggest issue (copyright protection) and pass thru firmware that is not forward compatable, which is why HDMI blows. Today's current version is 1.3b and supposedly has "fixed" all the issues. If your TV is 1080p and larger than 50" run your HDMI directly to the TV from the bluray. If your TV is 50" or smaller or 1080i, just run Component and digital coaxial or optical. Reason: The human eye cannot see the difference between 720p and 1080p on a screen 50" or smaller, that is fact. If your TV is not 1080p, and is 1080i, component still has it beat at 720p. I've been doing HD since 1995 and have dealt with all the issues! If your not sure if your TV is 1080i or 1080p just post a comment w/ your model # and I can walk you thru the best possible way to set your system up. If you just got the receiver "new" from a store, take it back. It's way behind the curve. Hope this helps
Posted on Jun 25, 2009
Pioneer vsx-5231 not pairing with Phillips bdp-2175 smart bluray player
have you tried to connect the Philips direct to the TV's hdmi?
Could be the resolution on the bluray is set to 1080p which may be out of range for the receiver or even the TV for that matter. If you can reset the output resolution of the bluray to 480p first, just to establish a picture then try 720P which all HD tv's and receivers can handle.
I did a quick search and could not find the resolution reset procedure for this unit. Other units will reset if you press and hold 2 or more buttons together.
May 04, 2014 | Pioneer VSX-521-K 5.1 Channel A/V Receiver
Onkyo tx-nr509 no picture with blue ray dvd player
Hello, I am sorry about your issue. Have you tried the other HDMI ports on the receiver. Please check the cable from the receiver to the TV. Thank you, Onkyo USA
Mar 07, 2017 | Onkyo TX-NR509
Hi, I just bought a blu ray home theatre system and hooked it up, the surround sound sounds great but it only works when my watching a movie with the blu ray player... I hooked the blu ray player to my tv...
If you want everything to have surroud sound, it all has to run through your system and you select which function to use. Yes it sounds like improper connections.
Sep 03, 2011 | RCA Audio Players & Recorders
Wen i play a blu-ray it keeps saying out of range
Sounds like you need to change the output from the Blu-ray player. Don't send a 1080p signal, try 1080i or 720p. Plug the Blu-ray player into the TV using the composite cable (red,white,yellow) to get the menu back up on the TV then change the output resolution and then plug the HDMI cable back in.
It should then work.
Feb 28, 2011 | Audio Players & Recorders
Hd picture
Your TV does not support 1080p thats why, just adjust blu-ray and PS3 resolution down and it will work
Jun 01, 2010 | Sony STR-DG820 Receiver
My new Blu-Ray player will not send out an HDMI signal, except when I turn it on. It shows the Blu-Ray sign, then stops sending out any signal. is this a common problem?
This is not a common problem.
It sounds like you are receiving signal from the DVD player, but are having a resolution issue. After the splash screen is when the resolutions setting can affect your output. What this sounds like is the DVD player is set to 1080P and the TV is only capable of 720P or 1080i. If there is a resolution mis-match, connect a composite cable to the TV and set the resolution of the DVD player to AUTO, then check to see if you have an image from the HDMI connection.
If your TV is capable of 1080P and if this solution does not fix the problem, and all other outputs from the player perform the same, the unit is faulty and should be returned if still under warranty.
Hope this helps!
Jan 11, 2010 | Insignia NS-BRDVD Blu-Ray Player
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
Problems with Sharp Blu Ray Player "copy protected signal"
Possible solution: You set up your remote to run your amp from the TV control, using the AQUOS Link. Even though your amp is out of the loop, it's still recognized by the TV. You might have to reset the TV back to default and run the AQUOS Link again.
Apr 19, 2009 | Pioneer VSX-D514 Receiver
What Blu Ray to buy for ONKYO TX-NR801 for Dolby TrueHD, etc???
Hi, as the Onkyo receiver you have does not have HDMI switching, the only thing it will do for you with a Blu-Ray player is process the audio signals.  The video from the BR player will have to go directly to an HDMI input of your hi def TV.  In this case, either Sony or Panasonic BR player will be equal.  Assuming you keep the Onkyo unit you have, you would want to use the optical digital output from the BR player as the audio source into one of the optical, digital audio inputs on the Onkyo.  In an ideal world, your receiver would some that does do HDMI switching.  This way, all the audio and video signals from any audio or video source would be automatically switched and channeled through 1 simple HDMI cable into your hi def TV.  This will make you life simpler as ther would be no need to select an appropriate input on the TV, as well as one on the receiver.  That said, buying a new receiver in addition to a BR player is more costly.  Good luck.  Let us know how it goes.
Jan 02, 2009 | Onkyo TX-NR801 Receiver
Video Connection Issue
Use an HDMI cable! It carries video and sound in high definition which is blu-ray dvd player. Costs about $25.00-40.00.
Dec 30, 2008 | Toshiba 43H70 43" Rear Projection...
Yamaha RX-V430 Receiver Logo
108 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
