Question about Samsung WF203ANW Front Load Washer
No water is going into my bowl after I fixed mt SE problem
I had the SE problem with my front end loader (Samsung wf-j1254) I looked online and was able to fix the problem by cleanin out the filter (there were 3 bobby pins clogging it) But it is a brand new machine so there was hardly any dirt. Now my Machine is working again, I hearthe water running but nothing is going into the main bowl. When I opened the soap dispenser there was water flowing into it, but nothing else.. I ran the washer through a whole load and only ended up with soapy clothes!.. Can I do anything to fix this?
  • 6,784 Answers
This is a defective inlet water valve assembly. replace it asap.
Posted on Jun 24, 2009
Wf 8800lsw samsung flashing spin light error code 5e
You need to clean out the debris filter behind the little flam on the bottom right hand on the front of the machine. If that gets clogged with anything, and you would be amazed at what ends up in there, you will get that message and the machine wont work.
Sep 01, 2014 | Samsung Washing Machines
SAMSUNG WF-J1254 washer very shaky when it's spinning, Help.
machine must be level there are 4 adjustable legs (1 in each corner) place a level on machine , level left to right and front to back.also check manual for initial set up there may be shipping screws that need to be removed on the back of the washer. good luck
Jun 11, 2012 | Samsung 3.7 Cu. Ft. Stackable Front-Load...
I have a 7kg front loader which was half way through a cycle before stopping. It makes a warning noise and then SE or 5E flash on the display. It won't spin or drain and now I cannot open the door to get...
Hi dear.5E code meaning on Samsung washer's,DRAIN fault.1-Please check drain hose for kink or clogged where it gets end.2-Please slowly open the machine's filter & drain the water inside the washer.Take out the filter & check it,if there is any thing blocks the filter or pump,try to clean it & put it back.It should comes back to normal.(If non of that's happening you might have defactive pump,call service centre.)Run the spin program & make sure it's draining now.I hope that helps.Thanks.
Aug 29, 2010 | Samsung WF337AA Front Load Washer
Suds remain after full cycle
I would personally look at a cold water supply problem, since cold water is what's used in the rinse cycle. Check the water inlet valve. Remove the water supply hoses and check the small screens inside the water inlets. (especially on the cold water side). Make sure they are clear of rust or debris. Check the solenoids at the inlet valve. Use a multimeter or ohmmeter to test for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. It could be a detergent or even a pump issue, but I would check the cold water supply first. Hope this helps and best wishes.
Aug 20, 2009 | Washing Machines
I set washer to be on cold/cold but it comes hot??
CHECK YOUR HOSES- SEEMS LIKE THAY ARE ON THE WRONG TAPS
Jul 06, 2009 | Washing Machines
Ma samsung wf j1254 is not stable, i leveled many times before
It could be. The front feet have to be manually adjusted but the rear feet are self leveling. If the wood is giving enough to allow the frame to touch ground then it could cause a leveling problem. The front feet are made of plastic on the newer machines if the plastic foot is stripped out, it could be allowing the machine to become un-level during operation.
Feb 22, 2009 | Washing Machines
Detergent drawer
I ended up having to call Samsung support for this same question. Left to right two vertical bars = detergent (liquid or Powder) flower = softner, single vertical bar = bleach.
Oct 19, 2008 | GE Energy Star WCVH6260F Front Load Washer
LG Washing machine - Front Loader
Suggestion: Check your outlet filter, it could be blocked. I looked for this SE could not find it.
Jan 15, 2007 | LG WM1812C Front Load Washer
Samsung WF203ANW Front Load Washer Logo
423 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
