Question about Boating
My 120hp evinrude 1993 stop when i cruise at low speed
Also i remark that only one spark plug is dirty. Is that possible that it is a problem with oil injection. My mechanic tuned up the carburators but the problem is still there.
  • 5,687 Answers
There always that possibility and if the injectors are identical you could switch them and see if the problem moves. Then you know its that one injector. The other possiblity is spark. The wire or the coil for that plug could be weak.
Posted on Jun 25, 2009
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
It reads codes po300 po300 po522 but it runs perfect sometimes I need to press fuel pedal to start?
code p 0300 refers to random/multiple cylinder misfires detected ===causes spark plugs ---HT leads ---injector/s--ignition coil/s---low compression---wiring
code p 0522 refers to engine oil pressure sensor/switch--low voltage ===causes wiring short to ground ---engine oil pressure sensor /switch---ECM
for the first code having to alter the accelerator position ( which tells the ECM to let in more fuel indicates either a low pressure in the fuel manifold or that the injectors need cleaning
At high way speeds when the engine appears to be running good , it is still possible to have random misfires caused by low fuel pressures and /or dirty injector tips
It would be a good idea to check the oil pressure with a mechanical gauge ,then replace the oil pressure sensor/switch
Sep 26, 2015 | Cars & Trucks
How can i determine if i have a 1993 evinrude 120h V4 standars or ocean pro, what is the difference
you can check with a dealer . they should know by the serial number or model number .I worked for a dealer for 15 years and never heard of one but we are a land locked state no oceans here for 700 miles or more
Aug 01, 2015 | Boating
Evinrude 120hp v4 hi i have a lot of fule going into the motor it always floods and wont fire how do i know if the fule pump is stuffed
This isn't a networking problem.
But I will take a shot at it. Make sure that it is a flooding problem and not a lack of spark.
You should be able to figure both of these things out by removing a spark plug, if its flooded there will be excess of fuel in the cylinder at which point you want to check that the carb and carb float is working correctly, if its a lack of spark you may need a new rectifier.
Oct 25, 2013 | Computers & Internet
My 1993 seville was running fine, I turned it off and when I tried to start it again the starter kicked but the engine would not turn over as if it's stuck or locked.
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
Mar 04, 2012 | 1993 Cadillac Seville
1996 Evinrude 9.9hp, 2-stroke power loss.
Checked the vent cap on the fuel tank?
Check if it runs again great after pumping fuel...
Check when it drops power if both spark plugs still sparks...
You can have a bad coil or cdi...
Jul 25, 2017 | Boating
I have a '83 Honda Nighthawk that I'm having oil light problems with. Once the engine gets warmed up, usually after about 10 minutes of riding, and I come to a stop sign/light the oil light comes...
If your oil pressure light is coming, you probably have low oil pressure caused by worn engine parts. Usually low oil pressure is observed when you are idling since the pump is pumping slowly. When you raise RPM's, the pump speeds up and pressure increases. Take the bike to someone who can diagnose it properly, but it sounds like it is time for some repairs.
Gary
Aug 03, 2011 | Honda CB 500 Motorcycles
It misses under low rpms
POSSIBLE CAUSES OF MISSING AT LOW SPEEDS. WEAK SPARK AT IGNITION SYSTEM, BAD SPARK PLUGS + WIRES.STOPPED UP FUEL FILTER. DIRTY FUEL INJECTORS,VACUUM LEAKS AT HOSES OR AT THE INTAKE MANIFOLD, LOW CYLINDER COMPRESSION.
Aug 22, 2010 | 2004 Chevrolet Monte Carlo
POWER !
check your transmission fluid levels they may be low, and replace the spark plugs you know give it a good tune up! wires, air filter, fluids, clean throttle body, IAC sensor, check for Vacuum leaks; like cracked hoses that lead to your map sensor or EGR valve etc.
May 14, 2010 | 2004 Chevrolet Venture Passanger
Missing operators manual for Evinrude 2 hp outboard motor
Your best bet is ebay for a replacement user manual. Take a look around, you will come across one... For the meantime, gas oil ratio should be 50 parts gas to 1 part oil, i.e. 50:1. General care: Dont go full throttle for any length of time. Cruise of 3/4 throttle... Always flush engine after use in saltwater, including washing down exterior. Keep spark plugs in good order and check prop for fishing line wrapped around in near the prop hub. Otherwise, get a yearly service and have them check the water pump and replace as needed, get it tuned etc and gearbox oil changed.
Jun 15, 2009 | Boating
Boating Logo
234 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
