Question about Janome Sewing Machines
Janome 350E suddenly stopped reading the USB stick. As soon as I select My Design it shuts down and restarts over and over again. What could be wrong?
  • 5 Answers
SOURCE: need help with transferring designs to machine
Put the cd into your computer drive and open it. Put your usb stick into one of the ports and open it as well. You must have the emb folder on the usb stick to put the designs into. If they are not there already- turn off your sewing machine and put the stick in. Turn on the machine and go to settings, then embroidery. Find the one that says Format. and touch that one and then let it do it's thing.
Once you have the folders on the usb stick- you can highlight the design name you want from the list (cd file) and drag it to the folder on the usb stick. Alternatively... right click on the design you want to move. Select copy. Open the folder on the usb stick and right click inside it. Select Paste. The design should appear in the folder for the usb and then you can take it out of your computer... put it into the machine and find the design.
If I can help with anything else... lmk.
Tracy in Nashville, TN
Posted on Jan 04, 2009
  • 152 Answers
SOURCE: With memory stick in Designer SE machine USB port,
Notice if this problem ever happens with the memory sitck that came with your machine. If it does then it may be the outlet you plug your stick into. Look at the outlet, does it looked damaged in any way?
Some USB sticks now come with programs on them with could be causing a conflict in your machine.
I would look at the files on your original stick through windows explorer and see if there are program type files that you could copy to other sticks that may help them communicate with the machine better.
Posted on Oct 10, 2009
  • 736 Answers
SOURCE: how do i get rid of short of memory space the
before you can add more to that memory stick you must first delete something else ...if everything you have on that memory stick is important to you and you dont want to erase anything then you can get another perhaps larger memory stick .. they are normally not expensive .. if nothing is important on that stick then you can reformat (initialize) it .. that will erase everything and you will be starting over with a fresh memory ..
Posted on Jan 05, 2010
SOURCE: the carriage on my Janome 350E will only move left
When my janome 350e did this I had to take it in to be calibrated and one month later it did it again and I had to take it back it has not given me any problems since but it would be nice to know how to do this myself it only took 5 minutes for this and takes me 3 hours there and 3 hours back. Hope this helps.
brenbb@skywayusa.net
Posted on Jan 12, 2010
RichSew
  • 191 Answers
SOURCE: My carriage on my Janome 350E is jammed and is not
See if the embroidery arm is bent, that will jam the unit as it trys to move. If is bent you may be able to straighten my bending it gently. The arms get bent by tilting the machine to the back while the arm is exrended.
Posted on Apr 14, 2010
Janome 350 embroidery machine......when I try to rewind the thread, ( shifting the stick to the right ) the needle keeps moving up and down.....any kind of help would be very appreciated.....the deale
Try to find the exact spot on the wheel to make the needle stop. Try different spots to get the one that does not move. You may need a service. You could also remove the thread until you are ready. The needle would go up and down but without thread will not cause havoc.
Jul 29, 2014 | Janome America Inc 350E Memory Craft...
Janome 350e embroidery machine will not open files from usb
Machine memory is FULL. delete a few designs from the machine, and then you should be able to load a new design from the USB Drive.
Jan 30, 2014 | Sewing Machines
Janome 350e how to adjust tension
Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 01, 2011 | Sewing Machines
How do i get rid of short of memory space the filecannot be saved on the usb stick on a janome 350e thank you
Jan 05, 2010 | Sewing Machines
The carriage on my Janome 350E will only move left or right - NO forward or backward movement.
Nov 20, 2009 | Janome Sewing Machines
Need help with transferring designs to machine
Jan 03, 2009 | Janome Sewing Machines
Downloading embroidary designs for the Janome MC 350E
Firstly, format your compact flash card on your embroidery machine. This is presuming you have embroidery files in your jef format your machine reads on your computer. Place your compact flash in the compact flash card reader writer connected to your computer, open the compact flash card in your computer, open the file emb5. Now you can simply copy and paste a design from your computer to your flash card. It works for me. Goodluck.
Sep 20, 2008 | Janome Memory Craft 9000 Computerized...
Bobbin in 350e
Sounds like the bobbin thread may have become knotted or jammed. I would suggest if you have a spare bobin trying that one to see if the same problem occurs.
Good luck
May 21, 2008 | Janome Sewing Machines
Sewing Machines Logo
139 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
