Question about Whirlpool Dryers
My gas dryer does not heat how do I check the pilot
  • 6,784 Answers
Check the following to address this issue.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 24, 2009
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
The dryer starts,heats up,gets good and hot,heat kicks off,electronic pilot kicks back on but does not light. runs cool from there on even as pilot continues to try and light.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Whirlpool Dryers
The pilot lights up, but when the thermostat is calling for heat nothing comes out. Basically the pilots on but the burners wont light.
heatman101
Aug 19, 2011 | Dryers
My Whirpool dryer Model LGR 563 isn't heating now. Does it have a manual or electronic pilot light? I don't see a pilot light lit through the hole.
heatman101
Apr 24, 2011 | Whirlpool LGR5636PQ Gas Dryer
Hey, I am getting no heat out of my dryer, it is not the atlantis but is a gas dryer. I opened the bottom to see if the pilot is lighting and it is not. What do I do? The heat coil which lights the...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | Maytag Atlantis MDG7400AW Gas Dryer
Pilot out dryer does not dry.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 22, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heats up then pilot lght turns off, dryer
heatman101
Oct 20, 2009 | Kenmore 63942 Dryer
Dryer pilot light goes on then goes right out. dryer wont heat
Hi there. Soon as the pilot switches off (will still be red hot but fade away rapidly) the gas valve should turn on. (make sure gas supply is on) If valve doesn't turn on, check sensor located very near pilot element.
When the sensor "feels" the heat of the pilot, it switches the pilot off and the gas valve on.
Thanks
Paul
Jul 13, 2009 | Dryers
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
Pilot
according to the model number its an electric dryer so the is no pilot. todays GAS dryers do not have pilots anyway. there is a globar that heats up and then the gas comes on, passing over the hot globar causing the gas to ignite
Aug 20, 2007 | Crosley CDE6000 Electric Dryer
Dryers Logo
62 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
