Question about Sony F710 Professional Microphone
How is the procedure to open this microphone?
  • 4 Answers
I would say.....unscrew the top lol..
Posted on Jun 25, 2009
Comoaqwindows 8 microphone muted how do i turn it on
From the Start screen, type sound to open the Search charm, and then select Sound from the search results.
The Sound window opens.
Click the Recording tab.
Select the microphone, and then click Properties.
Click the Levels tab.
Change the microphone level to 100 and the Microphone Boost to +10.0dB.
Click Apply.
Disconnect and reconnect the microphone. Then check the microphone recording level.
Do not run more than one application at a time which uses the microphone.
Aug 16, 2014 | Compaq Computers & Internet
Microphone not working
You may not have selected the Mic in the setup procedure. Go to the lower right and where the icon for a speaker sits, right click on that. When open you have options and open one or more of the options to select mic. input and mic output and/or volume.
Jan 06, 2014 | Fujitsu Siemens Computers & Internet
I have a broken wire on a rode m3 microphone and wonder how to open the mic to repair.
if you don't know how to open your microphone, I recommend not doing so.
Feb 06, 2011 | Rode M3 Professional Microphone
Why CaN'T THEY HEAR ME IF CALL THEM IS IT MY MICROPHONE IS NOT PROPERLY WORKING WHEN I ALSO RECORD THE RECORDER PLAY LIKE A NOT PROPERLY WORKING TELEVISION
hi ,
your phones microphone is need to relace... you can do it in your own and to do that you need this tools ..T6 that fit for the screw of your phones housing and a working mic piece ,a small component that make your voice function ...
procedure:1. open firrst your phone with t6 screw ,(there are 2 screws on the back of your housing
2.using your nail ,take off your housing
3.then you will see now the location of your phones microphone (see picture above )
http://img192.imageshack.us/img192/1403/6300t.jpg
4.bring back your housing then try it...if still not work ,get a headset and try...if still not work ,jumper the mic this way...
http://img689.imageshack.us/img689/9057/61958919.jpg
i hope it will help you ,and for another reference look at this ....
http://www.youtube.com/watch?v=YAHc5fIbZwE
Feb 05, 2011 | Nokia 6300 Cell Phone
Dismantling the radio microphone. procedure?
It depends on the model number of the transmitter.The "SM58" is just the cartridge on the top.
Nov 23, 2010 | Shure SM58 Professional Microphone
Integrated microphone not working, m-1624
Try to install the drivers from Driveforge. Its an open source. It includes all the drivers and has the capability to select the drivers automatically based on OS.
Regards,
HP
Aug 27, 2009 | Gateway M-1624 Notebook
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
LS 3700 Leadsinger Microphone
We had the same problem just this weekend. However, we investigated it ourselves and discovered that you can take the microphone apart by unscrewing the two small screws inside the mic, under the music chips. Once the screws are out pry the two halves apart very carefully. Once we were inside, we discovered that the soundcard was loose and all we had to do is plug the sound card back in. Close 'er up and start up the show. Good Luck!
Nov 10, 2008 | LeadSinger LS-3000 Consumer Microphone
Mic
First, be sure to have the latest software from logitech's website, and the latest MSN.
Then perform the following:
Execute the audio and video setup procedure within MSN Messenger 7.5. This procedure will allow you to assign an audio input and audio output device, as well as assign the video device of your choice to work with MSN Messenger.
1. Launch MSN Messenger and select the “Audio and Vide Setup” option from the “Tools” menu.
Figure 1
2. Click “Next to begin the setup process
Figure 2
3. In the “Speaker Setup” window, select the output device you would like to use with MSN Messenger. This step is specific to speakers or headphones. If your speakers or headphone device is connected to your computer, select the device by using the drop down menu provided. You can also set the desired volume level and click “Play Sound” for an audio sample. Once you are comfortable with the your selected options, Click “Next”
Figure 3
4. In the “Microphone Setup” window, select your desired input device from the drop down menu provided. This selection will be specific to a microphone connected to your computer. If your Logitech video camera has a built-in microphone, this option will be presented as “Logitech Mic” with your camera model name in parentheses as shown below. If you have an external headset device connected to your computer which hosts a microphone, select the devices name or model number in the drop down menu. Once your device is selected, adjust the microphone volume level to your preference and click next.
Note: the microphone volume level may need to be tested in order to find a comfortable listening level for you contacts. As a starting point, try setting the level midway and adjust when necessary by re-executing this procedure.
Figure 4
5. In the “Webcam Setup” window, select the video device you would like to use with MSN Messenger. Once selected you should see a display sample in the window provided. You can also click the “Options” button to make camera specific adjustments. Once completed, click the “Finish” button to apply your changes.
Figure 5
6. Once you have completed this process, MSN Messenger should now know the audio input (microphone) audio output (speakers or headphones) and video device (webcam) to use when engaging in an audio and or video conversation.
Jan 07, 2008 | Logitech QuickCam Express Web Camera
Sony F710 Professional Microphone Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
