Question about Dryers
Kenmore 70 series that wont heat up can i just
Kenmore 70 series that wont heat up can i just light a pilot light?
    Master:
  • 413 Answers
Generally, a dryer with a turning drum but no heat is caused by one of three or four issues. The first and most common is the thermal fuse. Located near the lint tunnel in the rear, the rear chassis panel with eight screws, needs to be removed to access that device. It looks like a flat white plastic strip with two wires coming from it, usually held in place by one screw and a slot which clamps one end. It blows when heat is exceeded in the lint tunnel. If you just dried a thick blanket, a large load of dense items, such as levi jeans or other items made of heavy fabric, you can count on it. Of all the problems with dryers, 99% are the thermal fuse. Get your machine serial number at the back of the machine and go to your local appliance parts dealer with that info. $15 is the average price of this item and about an hour of disassembly/reassembly of the back panel. Clean out the lint tunnel and lint filter while you're back there! Check the "repairclinic" dot com's site for more insight into your dryer's parts.
Posted on Dec 20, 2014
  • 146 Answers
Well did check if burner is coming on is filiter clean is duck clogged. there should be sensor near the pilot light it should be close or even within the pilot light.
Posted on Jun 24, 2009
How to light pilot for Kenmore 70 series Gas dryer
In order for us to provide you accurate information and supply you with the correct manufactures part numbers , we will need the complete model number, serial number and batch or series numbers (if applicable) found on a business card size metal/foil plate. If you are having difficulty locating this identification label, follow this link which will take you to our Website where we have pictures of common locations where your model number ID label can be found. Here is the link: http://www.affordableappliance.com/Tips/modelnumbers.htm Once you have the updated information, please reply to this email. Eric Campion
May 21, 2014 | Kenmore 73952 Gas Dryer
Kenmore 70 series electric dryer not heating
You either have :
-A bad heating element
-A bad thermal cut-off
-Thermostat
OR
-A bad fuse.
May 12, 2012 | Kenmore Dryers
I have an old Kenmore 70 Series dryer, just this weekend, the drum turns but no heat..... after a little search online, I suspect the pilot light went out. Where is the pilot light located? I lost the...
The burner is on the lower right side of the bottom under the drum. See this manual pdf page 23 for location and access. https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794/$FILE/4322260.pdf
The burner uses an ignitor and a flame sensor vs a pilot light. See this link pages 12 - 14
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/c5c81d2c8f26b1b5852574f20055c20c/$FILE/4314010.pdf Note the M series burner has been in use since 1984.
The dryer must have a complete termperature circuit and no "high temp limit" failures for the ignitor to light. That means the door is closed, motor is running, and the cycle thermostat is less than 135 deg F and the High limit thermostat is less than 180 deg F just to provide power to the gas valve solenoids, ignitor, and radiant / flame sensor.
Thanks for choosing FixYa,
Kelly
Nov 28, 2010 | Dryers
Kenmore Dryer 70 series electric-quit heating and timer wont shut
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
This link will help you in diagnosis/disassembly/parts.
Possibly a faulty heat element is most common failure. Fix the no heat problem and the dryer should shut off ok.
Make sure you have correct voltage to the unit before tearing apart. Again visit the link above
Nov 24, 2017 | Kenmore Dryers
No heat coming on to dry the clothes
Try this link I hope it helps, I know it helped me a ton!! ps don't forget to rank my help. Thank you and have a nice day!
http://fixitnow.com/wp/2004/11/13/mailbag-how-to-troubleshoot-a-gas-dryer-with-no-heat/
May 06, 2009 | Dryers
Kenmore 70 Series
The most likely cause is a bad ignitor part number 279311. It has to glow to open the valve and ignite the gas. You should hear a loud click when you first start the dryer. That tells us there is voltage to the gas valve.
Apr 07, 2009 | Dryers
Heating on series 70 Kenmore Gas Dryer
suspect the 2 black coils on gas valve/burner after first heat cycle they will open and not work until cool down
Nov 26, 2008 | Kenmore 70172 Gas Commercial Dryer
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
Unless the dryer is extremely old, you do not have a standing pilot. It uses and ignitor or glow coil which could be your problem. It could also be defective gas valve coils or an open thermal fuse. Since it is a gas unit, I recommend you call a technician.
May 09, 2008 | Dryers
Dryers Logo
135 people viewed this question
Top Dryers Experts
