Question about HP PSC 1410v All-in-One Printer
My HP PSC 1410v does not print the edge of the paper. Print Preview shows the very edge of the Word document, but when it prints, it cuts the edge on the right side. The left side prints perfectly. The Page Setup for margin is: top 6.3mm bottom 6.4mm left 6.3mm right 6.4mm gutter 0mm sutter position: left Orientation is landscape. I would truly appreciate if you can help me! Tsuyo
3 Suggested Answers
  • 141 Answers
SOURCE: print orientation
somewhere i believe you have auto rotate enabled in the driver, and it is cancelling your application's landscape setting. Good Luck!
Posted on Sep 20, 2008
CompuGuy44
  • 432 Answers
SOURCE: Printer does not print whole document
In 'Print Preview' look at the margins, and see if anything is too close to the edge of the paper. If it is, then set your margins further from the edge, or drag graphics further from the edge, etc.
To correct the margins that are set to close to the edge of the paper, open the document in Microsoft Word and follow these steps:
  1. Make sure that you are using the same printer driver that gave you the error in Microsoft Word Viewer.
  2. In Word, on the File menu, click Page Setup.
  3. Click OK.
    You receive a warning dialog box about the unprintable regions.
  4. Click the Fix button.
  5. Save and close the document.
You can now open and print the document in Word Viewer without receiving the error message.
Posted on Dec 19, 2008
Used to work fine, now after scanning a document, preview shows right 1/2 inch cut off. Tried everything...
you might confirued wrong paper setting on print preview of scan document or try to change the size of the paper to A4 or letter
Nov 12, 2013 | Lexmark International Lexmark 5200 series
Last print line of any doc printed with HP J6480 is cut off
I had been experiencing this problem intermittently for some time, so I finally got a hold of HP support and with the second support technician, I did get a solution that worked for the document I was printing at the time. When Printing, click Printing Preferences, click the Advanced tab, under the Printer Features section, set Minimize margins to On. Per the technician, 'The printable area of the product increases (bottom margin 12 mm to 3 mm), so that printing closer to the edge of the paper.'
Also, he recommended using the printer's Print Preview option under same the Printer Preferences window. When I did, I did in fact see the document's bottom paper being 'cutoff' with the old settings (i.e., Minimize margins Off), with it On, it look okay.
Hope this helps. Let me know if this works for you.
Jul 19, 2009 | HP Office Equipment & Supplies
My HP PSC 1200 printer has started printing all landscape documents as portraits and visa versa. Reinstalling has not helped.
hi
goto the control panel-->printers and faxes and do a right click on the printer icon.now goto printing preferences and change the settings as per your need
there is also a check box for showing the preview before printing,check that ,now everytime you want to print something it will show you a preview in advance for how the print out's gonna look like
you can change the settings as portrait or landscape by going to printing preferences.
hope this helps
Jul 14, 2009 | HP PSC 1210 All-In-One InkJet Printer
My hp printer wont print a document and when i go to print it says it has 45 documents waiting. there is plenty ink and paper in the printer.
go to start>>control panel>> administrative tools>> services
search for "print spool" and any other listing related to the printer. stop the process by high light the service, right click on the mouse and stop.
open up the printer form start>>printer & faxes.
deleted all the print job that are in the queue.
go back to the service section above. and restart the services.
Jun 08, 2009 | HP PSC 1410v Printer
Expand Printable Area
Instead of print select print preview. Select printer options select scale to fit.
You can also setup in hp printer software just select paper size & or scale to fit.
Mar 08, 2009 | HP PSC 1510 All-In-One InkJet Printer
Printing from the Net on my HP 1410-all-in-one
Make sure the "Print To File" checkbox is clear, on the printer selection dialog window.
Dec 28, 2008 | HP PSC 1410v All-in-One Printer
  3. Click OK.
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP PSC 1410v All in One
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu00697&lc=en&cc=nz&dlc=en&product=441115&rule=46364&lang=en
Dec 16, 2007 | HP PSC 1410 All-In-One InkJet Printer
Condensed printing
Is it comming out half size?
There is a paper save mode on many printers what will reduce 50 percent to put 2 images on one piece of paper,
If your printer has that feature, turn it off.
Make sure you also do a print preview before printing and see exactly how your document is set up.
There may be a simple setting in the print properties on the driver or on the Word processor program you are running that needs reset.
Something simple, I think print preview is the place your going to be able to work out this issue.
Dec 02, 2007 | HP PSC 1315 All-In-One InkJet Printer
Printer
Could be that you're out of black? If you print blue text, will it show? Here's another troubleshooting guide on font problems - http://word.mvps.org/FAQs/AppErrors/CommonFontProbs.htm Good luck
May 17, 2006 | HP PSC 1410v All-in-One Printer
HP PSC 1410v All-in-One Printer Logo
62 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
