Ricoh aficio 401 error 302 - Office Equipment & Supplies
  • 162 Answers
Change the wire and Charge Corona Grid. Possibly it can be damaged a socle.
Posted on Dec 07, 2009
  • 313 Answers
THE EROR CODE IS TO DO WITH THE CHARGE ROLLER SECTION EITHER THE ROLLER IS DIRTY OR THERE IS A PROBLEM WITH THE BUSHINGS LEAKING THE CHARGE.. IF YOU TAKE THE DRUM UNIT OUT AND CLEAN THE ROLLER WITH A BIT OF WARM WATER AND A CLOTH THEN REPLACE IT CHECK THE BUSHINGS AT THE SAME TIME ONCE I T IS STARTED GO INTO THE SP MODE AND DO A ID SENSOR INITIALISATION AND CHECK THE READINGS IN PROCESS CONTROL..IF THIS IS A BIT FAR FOR YOU TRY THIS.. PRESS THE YELLOW CANCEL BUTTON AT TOP OF NUMBER PAD THEN ENTER 107 THEN HOLD DOWN THE RED CANCEL BUTTON {YOU NEED TO ENTER THESE IN QUICK SERIES} YOU CAN THEN TURN OFF THE COPIER AND WAIT 5 SECS AND TURN BACK ON IF IT IS JUST A READ ERROR THE CODE SHOULD GO IF NOT YU WILL HAVE TO PERFORM THE LONG WAY ROUND IE TAKE THE THING APART AND CLEAN OFF .........GOOD LUCK a
Posted on Jun 24, 2009
How to solve this problem sc 302
Hi
I managed to find a list of Ricoh error codes with brief explanations of their causes here:
Ricoh copiers error code messages
This clearly identifies the problem as a laser motor problem - OR
Charge roller, HVT, or fuse FU5 (AFICIO 340, 350 series, 355, 450 series, and 455) - OR
SC-302-01, 02, 03, 04 Charge corona assembly Aficio 550/650
SC-303 Charge corona wire cleaner, disconnected or time out for printer.
All of these sound rather like an engineer requirement but you may be able to something with appropriate spares
Sep 25, 2014 | Ricoh Office Equipment & Supplies
Error Code SC 401
1. Check the transfer unit is set correctly.
2. Check the transfer roller is set correctly.
3. Check the high voltage supply board is set correctly.
4. Check the harness of the high voltage supply board.
5. Call a Ricoh Service tech.
Aug 14, 2014 | Ricoh Aficio Mp 3352 B&w Copier
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
How to reset MP161 Ricio
The Ricoh Aficio MP 161 LN give error code - SC 302
Please adivse
Nov 21, 2010 | Ricoh Aficio MP 161 Black and White Copier
Functional problem sc 302 in ricoh photocopier model aticio1600
the charge roller in the drum unit is faulty or need to be cleaned.strip the drum unit and clean the unit
Sep 06, 2010 | Ricoh Aficio MP 1600 Black and White...
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
Is there any immediate solution for the ERROR SC302 for aficio 1018?
tnx
Aug 24, 2010 | Ricoh Aficio MP 2000 Black and White...
Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Sep 30, 2008 | Ricoh Aficio 1013F Copier
Error sc 302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
In English:
I would check the roller motor for a short, frayed, or damaged wires. Use a voltometer and compare the voltage to the cleaner motor.
Apr 27, 2008 | Ricoh Aficio CL3500N Laser Printer
Ricoh copier aficio 401 error sc 419
hi im jules_09.
sc 401 means transfer roller leak error.a transfer current leaksignal is detected.posible causes is 1.transfer power pack is defective 2.poor connection between the transfer terminal and the trnsfer power pack
sc 419 mean quenching lamperor.1 quenching lamp defective 2.poor conection between power pack and quenching lamp.
check all component but pay attetion to the current leak at the transfer because there both connected at the power pack
Nov 01, 2007 | Office Equipment & Supplies
154 people viewed this question
k24674
jasbo
jasbo
