Question about SanDisk Sansa e260 MP3 Player
Recovery i got the mp3 player in recovery mode, got the program for it... and it says error!! application failed... is there any way to get the correct program without having to call customer service??? please help me!!!thanks
  • 626 Answers
Re: recovery
(your device will say the word Rhapsody on the back)
1. Double click on My Computer so that you can see it on your screen.
2. Turn the player off.
3. On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see the orange colour.
4. On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under "My Computer" called "16MB FORMAT". Once you see that icon you may release the Record button.
5. Double click the RHAPSODY- file you downloaded earlier and open it. You will need WinZIP or WINRAR to "unpack" it. Inside you will see a file named PP5022.mi4 drag this file onto the 16MB Format in My Computer mentioned before.
6. Double Click on the Sansa.rar and open it. Drag the Sansa.fmt file into the 16MB Format as well (this forces the device format and erase all data)
6. Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System Shutdown, move the Hold switch on the top back to the left.
7. Turn the player on and watch the screen. If you see a Refresh Database Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Best of Luck.
Posted on Nov 05, 2007
0 characters
3 Points
When i start appear "load main image failed switch to recovery mode"
The error means that the program of your SanDisk is corrupted. Do you see an option to switch it to "recovery mode"? If not, the best thing that you could do is to send the device to the authorized service center for repair.
Thank you!
Sep 12, 2010 | SanDisk Sansa E280 MP3 Player
My e260 is saying "load main image failed switch to recovery mode" what that means
Load main image failed, this is a firmware error, (this does not have software like a computer)
Recovery mode, the player tried to recover from the error.
The player has firmware updates that where put out by the MFG because of problems.
You have to read the manual, carefully and follow it to the T.
because you need to update the firmware on the player.
This is there website.
Feb 08, 2010 | SanDisk Sansa e200 MP3 Player
SANSA c240 fails booting
i want softwere of sansa c240
Jul 08, 2008 | SanDisk Sansa c240 MP3 Player
Load main image failed Switch to Recovery mode
Use the Sansa Recovery Tool on the Sandisk website
Jun 01, 2008 | SanDisk Sansa e250 MP3 Player
E270r Refresh Database error w/ version details error
Try putting the player into "msc" usb mode. "mtp" usually does that, but i've never hear of it being on the comp.
Good luck
Dec 17, 2007 | SanDisk Sansa e250 MP3 Player
Recovery mode formatting failed
"Application failed..."
Means that this version is not for your player.
You have the Rhapsody version, which is not compatible with this software.
If you call SanDisk Support, they can email you what you need.
SanDisk Technical Support 1-866-726-3475
Best of Luck.
Oct 31, 2007 | SanDisk Sansa e260 MP3 Player
I get - 'Load main image failed. Switch to Recovery mode'
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted. You need to put the device into "recovery mode" before you run the tool. - Turn the device off (hold power for 20 seconds) - Slide the hold switch into "hold" position. - Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer. Then run the recovery tool. Select format when prompted. Best of Luck.
Oct 08, 2007 | SanDisk Sansa e250 MP3 Player
Error with formatting
Its not a firmware update you are running, it is a recovery tool. The "application failed to read version details" error is because it is not meant for your device. You have a Rhapsody version and the firmware is different. You will need to call SanDisk for them to email support documents. SanDisk Technical Support 1-866-726-3475 If you are truly trying to format the device, change the mode on the device Settings>Mode or USB Mode, then try formatting again. Best of Luck.
Oct 04, 2007 | SanDisk Sansa e260 MP3 Player
Downloded recovery from sandisk website now get error msg
That software only works with the non-Rhapsody versions, hence the error message. You can call technical support and they can walk you thru the fix. Its too much to type. SanDisk Technical Support 1-866-726-3475 Best of Luck.
Sep 10, 2007 | SanDisk Sansa e250 MP3 Player
Frozen MP3 Player
There's a reset hole by the side of the player. Try reseting it. It can freeze sometimes, and fix itself after a while. no apparent reason. reset, run the battery down and recharge. Hope it helps. this is from the creative site: The recovery mode consists of these four operations. * Clean Up: It is the least destructive operation. It scans a player's hard disk and removes any invalid links from the music library. It does not affect music files themselves. It is recommended that you perform "Clean Up" first before formatting or reloading the player's firmware. It is recommended that you clean up regularly if you frequently transfer files between a PC and your player. * Format All: It is the same as a Windows format performed in a PC, and consequently all contents will be lost after a format. * Reload Firmware: Reloads the player's firmware (Operating System). It will also format the player. Note : It requires the player be connected to a PC that meets the player's minimum system requirement. Select this option ONLY if you have access to a PC and you have downloaded the necessary firmware to install. * Reboot: Reboots the player. You can reboot the player after performing a clean-up or format, or reboot it without performing neither of them. It is recommended that you try these operations in the following sequence: reboot the player; clean up and reboot; format and reboot; and finally, reload the player's firmware. If your player seems to stuck in the recovery (rescue) mode, you can try the "reboot" operation first, and format the player if necessary. If it fails to reboot, you will need to connect the player to a PC, and reinstall its firmware. For a detailed instructions on how to install a player's firmware, please refer to Updating the firmware on a Creative MP3 player, or refer to the Web Release note of the firmware download. Unlike other hard disk based players, Zen Neeon does not have a rescue mode. Though there is a Player Recovery Mode , it is for use when updating its firmware only. 1. Detach your player from your PC , and ensure that it is turned off. 2. Close all active applications (for example, Internet Explorer, Windows Explorer, or Windows Media Player etc), as well as background applications such as Norton anti-virus applications. 3. Download the latest device driver if you have not installed any drivers for your player. The file name is MStorage_PCDRV_LB_1_07_00_250.exe. 4. Double click on the file MStorage_PCDRV_LB_1_07_00_250 to install it. Follow the instructions on the screen. 5. Hold down the Play/Pause button while connecting the player to a PC's USB port. 6. When the Creative logo appears on its screen, release the Play/Pause button. The player is now in Player Recovery Mode.
May 19, 2006 | Creative Labs Zen Neeon MP3 Player
SanDisk Sansa e260 MP3 Player Logo
Top SanDisk MP3 & Digital Media Players Experts
Jazz Boyce
Jazz Boyce
Level 1 Expert
Are you a SanDisk MP3 and Digital Media Player Expert? Answer questions, earn points and help others
