SOURCE: neff oven u1421 not heating up
If you have an Ohm meter, then test anything you feel is failed. No sense in replacing good parts.
I am surprised that there is no wiring diagram somewhere on the unit, like in the control head, or on the top or back (most units built in the U.S. over the past 30 years have them. Don't know about UK, which is where I assume you are.).
Let me know! The overload on the back should have a red reset button. The thermal fuse has to be replaced if it's failed, and normally when it fails, the control head will not work. It usually does not carry enough current to power the elements.
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
SOURCE: neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
SOURCE: Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Please rate my solution.
Thanks.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
