Question about Xerox WorkCentre Pro 575 Plain Paper Laser Fax
NEED DRUM RESET INSTRUCTIONS - Xerox WorkCentre Pro 575 Plain Paper Laser Fax
    President:
  • 2,072 Answers
NOTE: Perform the following procedure to reset the Drum Cartridge counter after you replace the Drum Cartridge. Do not perform this procedure at any other time.
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [5], [2], [0], [4]. The screen will display: Change drum.
    1. Yes
    2. No
  2. Press [1], then press [Enter]. The screen will display: Completed.
  3. Press [Stop] to return to the Standby Mode.
Posted on Jun 25, 2009
Paper fix in machine do not out the paper
Posted on Sep 17, 2010
OPC-Life over error. How to fixit
If the print quality is still acceptable you may be able to perform a reset on the drum counter. If print quality is bad you will need a new drum. Reset instructions at this site.
Brother HL 2150N Drum Unit Reset Instructions
May 26, 2015 | Brother HL-2150N Laser Printer
Tip
How to reset drum message after replacement on brother printers
Does your brother printer or fax machine have bad printing such as dark blurry pages or your machines says replace drum then follow these instructions. When you replace the drum unit with a new one reset the drum unit counter by following the instructions below:
  1. Turn the machine’s power switch back on.
  2. Press Menu => Machine Info. => Reset Menu.
  3. Press the Up or Down Arrow key to choose Drum.
  4. Press OK.
  5. Press 1 to reset the drum unit counter.
  6. Press Stop/Exit.
on Dec 09, 2009 | Office Equipment & Supplies
We have a Toshiba 170F fax machine that is no longer under warranty. I need instructions on how to replace the drum.
the drum & its cover is one unit
just remove the toner cartridge & put it in the new drum unit cover
May 11, 2011 | Toshiba E-Studio 161 Copier
It has come up drum error, i have cleaned the laser pinter window screen as well as the cornora wire yet it still comes up with drum error? help me please
Your drum has reached the end of its life. You either need to reset the drum or buy a new one. If you reset the drum (you can find instructions on the web) and then notice poor print quality you need to replace the drum to correct the print quality.
Sep 27, 2010 | Office Equipment & Supplies
Panasonic KX-FL511 fax, have replaced the drum kit twice now, following the install instructions with drum (and same instructions in manual). Machine still will not reset counter or recognize the new...
after replacement of drum when you close the the cover just wait for few seconds to reset the drum
machine will take one cycle. do not open lid before comletion of reset cycle done.
Feb 12, 2010 | Panasonic KX-FL511 Plain Paper Laser Fax
Change drum soon message won't go away after changing drum and toner. what do I need to do?
35YRTECH, aren't you being a wee bit flippant? I just changed my drum, had the same problem, and no where in mys instructions does it tell me how to inform the printer that I did reset the drum.
Anyway, here's how to do it (form the brother web site)
  • This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
    1. Open the front cover.
    2. Press the Clear/Back key.
    3. Press 1 to reset.
    4. Close the front cover, pressing firmly on each side until they click into place.
Jan 07, 2010 | Brother Office Equipment & Supplies
Replaced the drum in our 8220, however we still receive a message to change the drum. Do we need to reset?
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum:
I’m happy to assist further over the phone at https://www.6ya.com/expert/dan_91204789c5bd4b93
Sep 10, 2009 | Brother MFC-8220 Fax
Brother HL 1250 Laser. Drum & page counter
Reset the drum counter as follows:
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
  4. close front cover
Mar 23, 2009 | Brother HL 1250 Laser Printer
Change drum soon
Instructions are in the box that the new drum comes in.
Jan 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother printer HL 5250 DN. The drum light was flashes and I have replaced the drum kit and toner cartridge.
Brother Drum Reset Instructions
The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Reset the drum counter only when you replaced the drum unit with a new one.
Dec 05, 2008 | Brother HL-2070N Laser Printer
Xerox WorkCentre Pro 575 Plain Paper Laser Fax Logo
498 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
