Question about Maytag Atlantis MAV6451 Top Load Washer
Maytag washer mavt546eww..will not get up to full speed
After spin cycle starts it acts like the aggitator is trying to start. It makes a loud pop noise and then the aggitator kicks back and stops the drum from spinning. It never gets up to full speed and does this until the spin cycle is finished which leaves the clothes real wet. the washer is about 2.5 years old and all other functions work normally.
  • 6,784 Answers
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Posted on Jun 24, 2009
Washer makes loud noise at start of each spin cycle
sounds like ur o erloaded. but did u run a diagnostic test??
Jul 08, 2014 | Maytag MAH2400A Front Load Washer
My Maytag MAH-24 Washer suddenly started making a clunking grinding sound in the middle of the spin cycle.
The rear tub bearing is going out, and the cost starts normally about the 450 and up range,
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 27, 2012 | Maytag MAH2400A Front Load Washer
WILL NOT REACH FULL SPIN CYCLE, loud hum prior to spin, starts to spin, hits second speed but will not kick into full speed.
I would suspect that you have a Motor and Motor Control Problem. This washer has a three phase motor in it and it could have one phase out of it or the Motor Control board could be bad. However it is recommended that you replace both at the same time with a motor conversion kit.
Jul 15, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
I have a MAYTAG washer that was having trouble in the spin cycle it would drain but would spin slower like the brake was coming on. Now it rinses and spins fine but during the wash cycle it fills then once...
More than likely it has a broken wire underneath that controls the spin. and agitation. I had an old Kenmore that the wire that controls these functions would break about every 6 months.
Apr 28, 2010 | Maytag Washer Timer - 22004015
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud noise when aggitating code says motor not rotating properly
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
or something stuck up in spinning motor assembly.
thanks and plse do not forget to accept the solution.
Apr 02, 2009 | GE Profile Harmony WPGT9360E 4.0 Cu. Ft....
Maytag PAV2300AWW
hi there,
the humming is the motor trying to turn, which means it works. since you did not mention any error messages, it could just be a belt that slipped off the pulley. have you taken it apart yet?
it definitely worth fixing.
Sep 22, 2008 | Maytag PAV2300 Top Load Washer
Noisy Washer
may be blocked outlet pipe or depending on the model a noisy drive belt, check for blockage if belt do not worry. Regards engineer
Jul 25, 2007 | Maytag Performa PAV2200
Loud clicking during spin, won't spin full speed
manofred, you either have something in your pump or the coupler is starting to break up. Tip the washer back and take a look. See if there is a bunch of black debris under the trans. If so, your coupler is failing. The pump will come off with 2 clips and 2 clamps. Check to see if something is in the impeller. Check the attachments....Catriver...post back.
Feb 13, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Atlantis MAV6451 Top Load Washer Logo
580 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
