Load off balance, smelled burning and now the washer wont spin or drain.even leaking a bit but that may be because the hoses were pulled when it walked
    Sergeant:
  • 353 Answers
Belt burnt
Posted on Jun 24, 2009
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
Spins but wont drain has a slight burning smell
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 05, 2011 | Frigidaire FWS833A Top Load Washer
Dont remove all water in spin cycle
clogged drain pump,line or pump is failing.
Feb 26, 2010 | Whirlpool Washing Machines
Kenmore Oasis washer model 110.27032600; trapped hidden water
when you tipped the washer was the drain hose still attached? and if so was the drain hose elevated? most top load washers will have an amount of leftover water in the bottom of the tub. with the drain hose off and the washer tipped towards the rear you should lose any excess water. also try to open the top of the agitator to see if there is any water trapped there. hope this helps....
Oct 18, 2009 | Kenmore Washing Machines
Fisher & paykel GWL11 washer won't rinse
sounds like you have two problems, the burning smell is probably the pump,out of balance is usually due to worn aout suspension rods
Oct 14, 2017 | Fisher and Paykel GWL11 Top Load Washer
Whirlpool Ultimate Care II LSQ8243HQ0 weak spin, wet clothes
if it has a belt, it may be slipping, but you would smell a bit of burning rubber.in high use times(4 to 8 pm), the current of electric supply is low, thus less power. third, motor may need to be replaced. plz rate-bozcro
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator spins slowly and wont drain water-slight burning smell when operating
Hi, Th smell is most likely the belt. If the washer is not draining, the pump could be locked up and this will cause the belt to smell.
The pump is located underneath rear right corner. If you set the drain hose itno abucket and get the water out. you can tip the washer back and see if the pump is froze. I see you posted this premium but I didn't get to it in time cause I was asnwering this.
Hope it helps
Vic
Jun 21, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Washer will not drain on spin
We ended up opening up the washer and checking the pump and guess what , there was a tiny drill bit stuck in it that stopped it from spinning and working. Thank god we didnt burn out the pump.
Nov 11, 2008 | Frigidaire CWS3600AS Top Load Washer
Spin/Drain cycle...Kenmore 417.40042990 Front load belt drive washer.
If the water is draining quickly (less than 30 secs) every time, than it sounds like its sensing an out of balance load, the CCU looks for this.... Before every spin cycle it goes through an out of balance routine it will do this even when empty.....It speeds up, slows down and will tumble again at least once....then speeds up ....looks at motor amps......decelerates.....looks at rate of deceleration.......Then decides if its ok to spin at the high speed...or if it should tumble again to distribute the clothes....If it cant balance itself to what it like than it will spin at a lower speed like yours is doing if its bad enough than it wont spin at all really (very slow). Im sure you checked the shocks while you were looking at the pump, but double check that there not broken at the mounts, or lots of grease at the base mount. If thats all good than you should try this......Sort a large size load of just regular tshirts and casual wear (no towels, jeans). Let me know how it spins then. Also make sure that its draining quickly every time. Sometimes the drain pump can appear fine and not be starting every time.
Jan 19, 2008 | Washing Machines
Error code 20
i think your on the right track but a couple of things you need to know first that model washer wont spin tiny loads or one articles of clothing it has a device in the motor called a tacho generator to balance if you have only a small load it cant sense the balance and most of the time will only rock back and forth second your pump is the most likely culprit if you look in side the washer you will see a seem in the tub next to that will be one of the washer tumblers take the screws out of that tumbler slide it forward there will be a hole there rotate the tub to your right and you will find the hole going down to the drain pump can check it there but i don't think you'll find any thing as that is a larger hole it think your drain pump is now if you have a shop vac this is time to vacuum the water of the tub and all the way down the drain hole for the next stage usally i tell customers to remove the drain hose from the stand pipe and vacuum the water ou of the washer from the drain hose but because of the pillow this might not work in your case.now remove the two screws on the front lowerpanel and pull the panel
Jan 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
