Question about Kenmore 24932 Top Load Washer
My Kenmore washing machine will not fill with water but it will run all the cycles dry... what is this and how can I fix?
  • stacy_willia Jun 24, 2009
    Thank you so much; I will try this as soon as I get home.
    President:
  • 1,185 Answers
Replace the pressure switch , it must be stuck in the full position
If you are running it dry I am surprised there has not been a cloud of smoke as the heater kicks in.
Could also be a soap blockage in the air bell leading up to the pressure switch
Take the pipe off the air bell and blow into it ,you should be able to hear a clicking sound , if you do check out the part where you took the pipe from to make sure it is clean and soap free inside
Posted on Jun 24, 2009
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 240 Answers
SOURCE: Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Posted on Apr 28, 2009
jsrock516
  • 5911 Answers
SOURCE: kenmore 300 won't start spinning after water fills
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. I hope this helps you.
Posted on Jul 18, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: kenmore 80 series washing machine - won't stop
Your air pressure tube going to the water level switch is pinched or stopped up,OR, the water level switch is going bad.
Use this manual to access these parts and diagnose which is bad.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb?OpenDocument
Posted on Jan 16, 2010
No water filling at all in any cycle position?
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 22, 2011 | Kenmore 24032\24036 Top Load Washer
Kenmore 29832800, top loading will spin, but will not fill (or start to) machine on wash or rinse cycle - spin feature is all i have
heatman101
Apr 17, 2011 | Kenmore Washing Machines
We just installed a new kenmore dishwasher yesterday. Model 13242 It has been running for almost2 hours and is still on the washing cycle--no water in it however--is this normal? I'm in a bit of a panic as...
THAT IS NOT NORMAL!!!!!!! A normal wash and dry cycle will take approx. 2 hours in length including drying cycle.
You should see that water has been present in the machine within the first 2 minutes of the start of the wash cycle, you should also be able to hear the water entering the wash tub.
The fill valve or water supply seems to be the issue, if the water doesn't enter the tub then the controller won't proceed witht the wash cycle. Double check your water supply tube / hose to make sure there is water present at the connection to the dishwasher.
GOOD LUCK !
Aug 08, 2010 | Kenmore Dishwashers
Kenmore stackable washer wont work on Cold cycle only hot water
Here are a couple of tips that I wrote to help people that are having problems with the washing machine not filling...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 07, 2010 | Kenmore 98702 Stacked Washer/Dryer
Sometimes my new machine will not fill with water
make sure that your drain hose is coming up ( 90 degrees ) from the base of the machine. and then drains near or close to the height of the machine. the drain hose at least needs to be at a 45 degree angle to fill properly otherwise it will continuosly drain. hope this helps.
Oct 18, 2009 | Washing Machines
Dishwasher takes hours to run through wash and dry cycle. what should normal cycle time be?
2 to 6 hours is possible. The newer machines have a water heat cycle that will raise the water temperature. lets say your incoming water is 90 degrees. The machine want to see 140 -165 depending on the cycle so that cycle will take 75 minutes to reach 165 (1 min per degree temp rise). multiply that by the number of wash and rinse cycles and it can run a very long time. Water should enter the washer at 120 degrees minimum. let it fill and measure the temp you will be surprised. Eric
Sep 13, 2009 | Kenmore Dishwashers
Kenmore washing machine will not fill with water.
The drain hose might be too low. Make sure the drain hose is at least three feet above the floor.
Jun 01, 2009 | Kenmore Washing Machines
Kenmore 24932 Top Load Washer Logo
96 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
