Question about Kodak Easyshare M580 Digital Camera
Kodak easyshare m580 wont turn on or charge? - Kodak Easyshare M580 Digital Camera
SOURCE:
SOURCE: Kodak Easyshare Z1285
Are you using the batteries listed as compatible according to the cameras battery door? Or are you using NON-compatible Alkaline or Ni-Cad batteries? Only Li-Ion and Ni-MH are compatible. Hope this helps...
Posted on Jan 04, 2009
BillB-SA
  • 2761 Answers
SOURCE: kodak easyshare ls743
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
  • 8 Answers
SOURCE: My Kodak Easyshare M1063 won't turn on
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem and this fixed it, it seems to be a common problem.
Posted on Aug 15, 2009
  • 33 Answers
SOURCE: my camera wont charge
have you check the charger? or is there a power on the outlet? try to charge it from different power source
Posted on May 25, 2010
lock123
  • 6831 Answers
SOURCE: kodak easyshare ls743. lens wont retract. camera error #E45 shows on screen. battery is fully charged.
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
Will not charge
Kodak camera wont charge? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 1, 2011 - My Kodak EasyShare M580 digital camera wont charge. I have the USB charger, but when I plug everything in, the charging light wont light up, ... Kodak Easyshare camera will not charge?
Mar 27, 2014
My kodak easyshare m580 WILL NOT charge?
Mar 14, 2012
Kodak Easyshare M580 Not Responding To Charger?
Dec 7, 2011
My kodak easyshare m580 will not charge?
Apr 16, 2011
More results from answers.yahoo.com
Nov 29, 2015 | Kodak Easyshare M580 Digital Camera
What cable do I need to buy so I can connect my Kodak M580 Easyshare to either my laptop or my desktop computer
You don't need a cable. As I explained in my answer to your earlier question, you'll be much better off with a card reader, if you don't already have one on your computer.
Aug 02, 2013 | Kodak Easyshare M580 Digital Camera
What kind of battery can I buy for my M580 Kodak easy share?
The M580 uses the KLIC-7006 or equivalent. Two sources are here and here.
Mar 24, 2013 | Kodak Easyshare M580 Digital Camera
Kodak easyshare m580 camera getting locked on switching on
Hello, Don't quite understand "getting locked on" do you mean jamming up ? Please add further details.
Dec 29, 2012 | Kodak Easyshare M580 Digital Camera
I have a Kodak m580 it says internal memory full only 10 pictures on it and a 4 gb card is in it what do I do
Remove the 4 gb card and turn power on, go into menu and scroll down until you find the section on picture deletion, erase all data in the internal memory, turn power off and install your memory card should be good to go.
May 08, 2012 | Kodak Easyshare M580 Digital Camera
My Kodak Easyshare M580 works but the shutter will not go in all the way when turned off? Starts to go in then stops.
The problem is in the shutter itself, I would use it until it go's completely, it would cost as much if not more to have it repaired, chances are they would replace the whole lens housing.
Mar 13, 2012 | Kodak Easyshare M580 Digital Camera
Disassemble Kodak M580
you have 7 screws you have to unscrew, then you will have more inside to take it apart.
Nov 27, 2011 | Kodak Easyshare M580 Digital Camera
My Kodak Easyshare M580 will not turn on. It said the battery was low so I plugged it into the wall to charge it and the light was blinking at first and then the light shut off. Now, the camera won't turn...
The battery is probably a Li-ion battery and if the voltage gets too low, trying to charge it will lock the battery out as this is a built in safety feature to prevent the battery from charging too fast and causing a fire. You may want to try this. Take the battery and put it in to freezer for about an hour (do not Freeze), and then put it back in your charger and try to charge it. If it does not come back to life then the battery is kaput, and you are going to have to get a new one. You may have to any way as the battery is old and has lost it's ability to be recharged fully.
Jan 10, 2011 | Kodak Easyshare M580 Digital Camera
Kodak Easyshare M580 Digital Camera Logo
141 people viewed this question
Top Kodak Cameras Experts
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
