Question about Friedrich WallMaster WY13B33A Air Conditioner
I read your ac solution and ours is froze all the way up the coil what does this mean
  • 4 Answers
Cut off the a/c and run just the fan til the frost is completly gone. Restart and check in 15 minutes. Poor airflow, low refrigerant, or metering device problems are the cause of frozen indoor coils.
Clean the filter at least once a month. These units normally are sealed refrigerant circuits and do not have ports for gauges to add refrigerant- just like your refrigerator. Cars and whole home a/c's do.
Posted on Jun 24, 2009
Split system AC has pungent brussel sprout odor
clean well all the small drainage with bleaching liquid and soap it with scented soap.also at the back of the unit that are having small drainage and through the drain hose
Apr 17, 2014 | Coleman Heating & Cooling
Our ac froze up and we can't find our book to see what to do
freezing is caused by 2 things poor air flow (dirty filter, coil or blower) and low refergrant charge(leak)
Jun 26, 2010 | Heating & Cooling
Why does my AC keep freezing (Carrier FB4ANF036). I have replaced the blower motor less than a month ago due to the same problem. Just last night we had a lightening storm and shortly after that the AC...
if your system is a heat pump you can switch to heat and see if coil outside gets cold while indoor blows warm air - then switch back to a/c - both coils should not be cold at the same time - low freon pressure / dirty coil / dirty filter / low air flow causes freezing
Sep 22, 2009 | Carrier Heating & Cooling
Water leakage in onida split AC
clogged drain. dirty coils, or froze up. clear the drain with a shop vac. call a tech to clean coils or check charge on unit
Jul 11, 2009 | Heating & Cooling
AC not working. Sound but no cold air.
Dirty filter and or froze up indoor coil. most likely locked or stuck blower motor.
Jun 27, 2009 | Heating & Cooling
AC unit dripping water and won't cool
The coil is likely froze up due to dirty evaporator plugged ,air filter or low on freon .Tom
Jun 18, 2009 | Heating & Cooling
Ac problem
the coil is inside the front of compressor the electrical connector on the compressor that the coil for a block orifice tube forget it high pressure would go up pass 3oo untill pressure sensor cut the compressor you have to look if you have power and ground when the compressor not working or a bad sensor near the dryer 12volt positive bypass that switch i think that what it is, wire beeteen the 2 therminal send power to compressor the pressure that you have mean the ac system get cool off our low side is 40 not block you said 100 somthing the warmer it is the high side is higher our pressure look good its probably a sensor problem look at it pierre
Jul 19, 2008 | 1999 Ford F250 Regular Cab
Ac turning on and off
How did they check the freon in the home? You can feel the front(evaporator coil)coil on all four sides. Are you sure the motor is running fast enough? If the four corners do not feel cold in about 5 minutes or so, there is a compressor problem, Capillary tube blockage, moisture in the system or you are low of freon. Good Luck
Jun 15, 2007 | Haier Energy Star ESA3183 Air Conditioner
Friedrich WallMaster WY13B33A Air Conditioner Logo
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
