Question about Sony Playstation 3 (PS3) Console
WHEN I TURN ON THE PLAYSTATION3 IT GOES ON QUICK AND THE FAN RUNS AND IT AUTOMATICK SHUTS OFF. WHAT COULD I DO IN THIS CASE
    Novelist:
  • Sony Expert
  • 172 Answers
You need to find somebody that does a reflow to the motherboard the video graphics card needs to be reflow and this will make your ps3 to work again I do this type of job but not many people in this web side trust me and I undestund is dificall to send you unit to someone you don't know but I am a ebay power seller one guy he contact me about his playstation it was not playing any games or movies and I got his unit fix now he is so happy that his unit is running again I thank him to trust on me
Posted on Jun 24, 2009
I turn power switch on, fan runs really fast for a minute, 4 quick beeps, then shuts down, no lights or anything
Do you have a disk stuck inside? Many issues have simple fixes. For some reason, when the Blueray drive fails to read a disk, it sees it as a fault and shuts the system down. If you don't have a disk in, try putting one in and see if that turns your system on. Also, the PS3 system auto recognizes the audio/video connection. If you don't have it connected to your video source,(TV, Projector, etc.) It won't turn on properly. Just some things to think about, and I hope this helps. Good luck. ^^
Oct 30, 2015 | Sony Playstation 3 (PS3) Console
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Compressor turns on and runs for about 1 min then shuts off for a while before it does it again and the on/off switch when u switch it off it only goes to low fan. Never turns off. Also the thermastat is...
First replaced the thermostat then check on condenser unit that's outside .make sure the fan is running when compressor runs .if not there is your issue .If fan runs and compressor keep shutting off you might have a dirty coil so clean it out with water or you might have a leak in the system causing unit to shut off on low pressure .if this is the case you need to call a service technician .
Try simple things first like clean coil ,capicator and fan operation.
Mar 07, 2018 | Dometic Rooftop RV Air Conditioner
Computer is a Lenovo TC M52 P4 / 3.2 - I have added a sound card, a PCI express Geforce graphics card and a NIC card. The problem seems to be overheating as it only shuts down like this during the summer...
The case fan should start running as soon as you turn on the computer. I would replace the fan with a higher capacity (CFM). If you have a case that can take 2 case fans, I would install the send fan. Also with the case off, check that the CPU cooler fan is functioning. With the quick shut off, I would suspect that the CPU cooler fan is not functioning. I could be impeded by dust. Vacuum and blow out any dust on the motherboard, fans and battery fan while you have the case off.
This should aleviate the shutoff problem due to overheating.
Let me know if this solves the problem.
Please rate this solutution. Thanks.
Jun 23, 2010 | Lenovo ThinkCentre M52 8212 - Pentium D...
The protect mode issue
Disconnect and/or turn off speakers and see what happens.Check for running cooling fan and that unit is clean inside and has good ventilation.
Sep 07, 2009 | JVC HX-C6 Shelf System
My Playstation3 will turn on but after in a few seconds it shuts off by itself
it is either over heating which is the fan or it is the software either way you will have to send it to sony to be repaired
Jul 26, 2009 | Video Game Consoles & Games
Duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Jun 28, 2008 | Dometic Rooftop RV Air Conditioner
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Sony Playstation 3 (PS3) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
