Question about Canon PowerShot A75 Digital Camera
I have a couple broken pins in the compact flash connector internal to the camera. Can I order a replacement socket and attempt repair myself?
  • Anonymous Mar 22, 2014
    flash wont pop up, looks like one of the external flash pins is pushed in or broken, is this repairable
  • Canon Master
  • 4,738 Answers
It can be done, but it's not easy and requires patience and a good invetory of parts and screws. Replacement card reader can be salvaged from a broken ebay camera (A75 and A85 readers are interchangeable). Here's a disassembly of a very similar A70:
http://blog.thustra.com/2007/03/canon-a70-ir-modification.html
Now are the pins actually broken or just bent. If just bent, you can actually and easily unbend them, but it requires patience:
http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
Posted on Jun 25, 2009
A few pins in the compact flash card holder of my canon 5d mark lll are bent and i can not insert the compact card. can i fix it myself
How experienced are you at electronics repair? You can try straightening the pins with needle-nose pliers. If you need a replacement part, one source is here.
Apr 06, 2013 | Cameras
Bent pin in card slot , i have bent one of the pins that fit the compact flash card is there any one out there with spares to repair, ta steve
This is not a consumer repairable problem. Take it to a professional. If it's just a bent pin (not broken), the repair shouldn't be too expensive.
Oct 09, 2009 | Cameras
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Best regards - Michael
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
Compact flash connector pins bend/pushed inside
The CF socket must be replaced. Try canonusa.com to find a repair facility.
Sorry there is no easy fix for this. If the repair cost is too great, try picking up a used body on craigslist.com
Nov 27, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Minolta Maxxum 7D Lithium Battery Replacement
You need an NP-400 Li-ion lithium battery - I suspect ebay or Amazon can fix you right up.
Jun 13, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
Hp Photosmart 145 printer charging pin broken
If the pin is pushed inside to one side use a small screwdriver (ones used for watches)  , you can push up underneath the pin and it will become straight enough for you to connect it , other wise you need to open up the camera and desolder the socket and buy another one and solder it , make sure you measure the diameter of it & keep it look on ebay for that connector of that size, if you can take a photo of it and upload it on flickr  and provide a link it might help a bit
Apr 13, 2008 | HP Photosmart 435 & HP Photosmart 145...
Canon Rebel XT unable to access compact flash card
check all the pins in the CF socket in the camera are there, or are not bent, repair is expensive if broken
Jan 17, 2008 | Canon Rebel XT / EOS 350D Digital Camera
CF pin
I'm afraid they break most of the time. You can try it though since the repair involves replacing the board that the connector is soldered to, $$$
Jan 06, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Replacement flash card connector
I had the same thing happen... broken pins. I purchased a card reader at Wal-Mart.
Take your pics, pop the card out of the camera, pop it into the card reader and plug into your pc to upload.
Sep 18, 2006 | Konica Minolta DiMAGE S414 Digital Camera
Compact Fash
No Fix The liklyhood is a pin in the chamber has broken off - a common fault. The Item is integrated into the main board so a replacement is not likely. But you could ask Fuji customer support
Mar 23, 2006 | Fuji FinePix S602 Pro Digital Camera
Canon PowerShot A75 Digital Camera Logo
439 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
