Question about Dewalt DW7118PT 8 1/2 Inch 60 Tooth Precision Trim Fine Crosscutting Circular Saw Blade
I cant seem to find a lever or button to lift my dewalt dw711 saw so i can use it for mitring
    Sergeant:
  • 353 Answers
Small pin at rear ,push down on saw to releave pressure and pull out on pin
Posted on Jun 24, 2009
Drive belt on DW707 mitre saw
should be a slide bracket for tension loosen it and lift motor same idea as belt tensioner on car for some saws
Apr 04, 2014 | Dewalt Saws
I need to know how to move the main arm for doing mitres on the Dewalt power shop DW 1251
There are three levers near the top of the column. One is the crank for raising and lowering the saw. You need to use the other two. One is a clamp which you need to loosen about a quarter turn (toward you I think). The other moves up and down about a quarter turn. Move this last lever up, which raises a wedge out of a slot in the column. Now you can swing the main arm of the saw left and right. It is impractical and unsafe to use it swung to the left, so swing it to the right. At 45 degrees there is another slot in the column that the lever you raised will fit into. You need to finesse the postion of the column so that this lever fits all of the way into the slot. Now you can lock the other lever.
Good luck.
Jun 14, 2012 | Saws
Problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Jun 04, 2012 | Dewalt Tools & Hardware - Others
I cant seem to work out how to lift the saw handle on my powerbase xtreme compound mitre saw, 1300w 210mm J1G-ZP4-210P , is there a catch ?
there is a locking pin or lever located by the hinged part of the saw that releases the lock down position. Just put a little pressure down on the top of the handle to release.Do the opposite to lock it back down.
Jun 12, 2011 | Garden
How do unlock mitre saw mastercraft 7-1/4-in mitre saw with laser its in the lock postion and wont release
There is a lever or push button by the hinge (where the saw pivots).Just push down on the top of the saw and release latch.To lock back down , just push down on the saw and put lever back in the lock position.
Jun 04, 2011 | Garden
Dewalt DW707 compound saw
Did you sense an odd smell? Try removing the brushes, there should be two, it could be one is worn too short or the connecting wire is broken.
Oct 30, 2009 | Dewalt DW703 10" Compound Miter Saw
Dewalt DW7118PT 8 1/2 Inch 60 Tooth Precision Trim Fine Crosscutting Circular Saw Blade Logo
156 people viewed this question
Top Dewalt Saws Experts
Craig Butler
Craig Butler
JOHN LAPIER
Tim Venetis
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
