Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
IMac won't recognize my external speakers
My wife has a 6 month old iMac. It no longer recognizes any external speakers. I've tried three different sets, so it's not the speakers. The internal speakers work fine. Coincidentally my house was recently hit by a lightening strike which knocked out the ethernet port on my Mac Pro. That computer was in a different room connected to a surge protector and powered by a different outlet. I was wondering if my sound card's the culprit or it's a problem with the operating system after my most recent OS upgrade. The machine is running Leopart 10.5.7.
I had the same problem..... turns out that there is a specific order that you need to plug them in. Disconnect your speakers from usb and from power. Then plug in the Power first. Then plug in the usb connection. They should show up in your sound control panel now.
Posted on Oct 13, 2009
    Problem Solver:
  • 5 Answers
Well the only way to find out is buy a new sound card but if you dont want to spend any money as long as you have a back up of your hard drive you can do a fresh install of leopard but make sure you back it up on something or you will lose your data. if you have any questions you can email me at jadenb333@gmail,com
Posted on Jun 24, 2009
4 Suggested Answers
myjosh007
  • 530 Answers
SOURCE: USB flash drive not recognized by Macbook Pro
hi im josh in cebu phils. if that happened that the usb port don't detect your usb drive then there maybe some problem in your pc. friend all you have to do is check first the usb connections of your pc.you can browse the my computer device manager then click the usb icons and see if marked + or 2nd you reboot your pc then go to bios setup utility then go to peripherals then check wether it is enable.if disable usb on board you enable it. and don't forget to save the changes you made before you exit. then reboot your pc. then problem will be solved. good luck please vote me so that i will know if i helped you.thnks
Posted on Feb 23, 2009
MacApplePi
  • 86 Answers
SOURCE: screen goes white, flashing a folder with a question mark
The flashing folder means that the computer can't find the boot system on the hard drive. If your girlfriend's step-dad has removed some parts of the OS, then the system will not start giving the 'flashing folder' result. You will need to re-install the OS from the system disk.
Insert the disk into the computer and it will boot from that and take you through the install procedure.
Posted on May 18, 2009
  • 9 Answers
SOURCE: Lost install disk for Mac book pro My 13" Mac book
You will need some install disks to even begin working on your issue.
Your options:
  • Find someone with the same model MacBook Pro and borrow the disks.
  • Buy a copy of Leopard (10.5) or Snow Leopard (10.6) and use them. If you are going to buy a set you might as well update to Snow Leopard (10.6)
  • Check eBay for install disks but make sure they are for the same model MacBook Pro.
  • Contact an Apple service center and purchase a replacement set of install disks.
Once you have a install CD, I would recommend backing up your system by making a disk image of the hard drive to an external drive. Then doing a clean install and then using the Migration Assistant to restore your user files to the clean install on your hard drive.
Posted on Apr 24, 2011
I have a uniden wireless mouse and it won't
here ur pc is recognizing ur external hardware that is mouse but cursor is not moving this indicates that bluetooth connection is good and problem comes with the mouse. i advise to meet a good technician and there is nothing to do with it further.
Jun 28, 2013 | Computers & Internet
New Lion OS X computer does not recognize DCR PC109
Yes this is a 6 year old OS. Update it to Sierra or at least El Capitan.
Apr 19, 2017 | Sony Handycam DCR-PC109 Mini DV Digital...
Laptop no longer recognizes my iomega external hard drive
How old is your OS maybe driver needs for that device for that device is corrupt try to localize and reinstall driver for external HDD
Apr 17, 2012 | Iomega Computers & Internet
My iMac (OS X 10.6.8) no longer recognizes my G-Tech 500G external hard drive. Time Machine noted that a backup had not occurred for 10 days and so I turned the disk off and then back on (this generally...
The drive has probably gone, but what I would try is make sure that it is not a cabling or port problem. First try the cable that you have been using in another usb device (one that you know works) and see if that works, that will prove that the cable is functioning properly. If that does not work try the cable in one of your other usb ports. If you are funning it as a firewire device do the same with firewire as above. If these work then it is more than likely the hard drive is gone.
If the drive is under three years old as far as I can see the G-Tech external hard drives are covered with a three year warranty see http://g-technology.com/products/g-drive.cfm get in touch with the manufacturer and claim under their warranty.
Hope this helps.
Sep 11, 2011 | Computers & Internet
IMac won't recognize firelite external disk
Try to connect it to another computer (Mac or PC).
Disasemble the case, and remove the disk-drive.
Connect the disk-drive as a "slave" in some other desktop computer, and see if the drive is "detected", and if your files/directories are visible.
Apr 16, 2010 | SmartDisk (DHXF250F) 250 GB Hard Drive
IMac failing to recognize Iomega UltraMax Hard Drive
I have the same problem too, this iomega is terrible, I have it only less than two months and it is not working already. Evan it has one year warranty I will not suggest anyone to buy it in the future.
Jan 03, 2010 | Iomega 33089 250 GB Hard Drive
External no longer recognized
Right click My Computer, Properties, then click on Device Manager.
Select Disk Drives then on tab menu Action, Add legacy hardware. Go through the setup and use CD's that came with Hard Drive otherwise search company site for drivers.
Oct 05, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
My MX1100 cordless mouse no longer recognized
It sounds like the Drivers for the Mouse aren't be installed. Since it is a wireless mouse and receiver it will need separate drivers to function properly. If it came with a CD I would try re-installing any software that came on the disc. If not (I'm assuming its a Logitech Mouse here) I would visit the Logitech website (www.logitech.com) and see if you can locate Drivers there.
Jul 08, 2009 | Computers & Internet
Toshiba 160 GB Hard drive is not seen by 'new' computer
I have had a similar problems with external drives that only plug into a USB port (no ext power adapter). It is very common that the power supply fed through the USB port is inadequate to power an external hard drive. Some enclosures have a external A/C input to resolve this. Also, some computers (motherboards) only have a select number of USB ports that are powered. Since this device is detected by your other computer and not on the new one, my next attempt would be to locate a USB hub with external A/C power. There is a good chance that this will resolve the problem. By the way, when you plug in the drive does it spin up?
May 03, 2009 | Toshiba 120GB USB 2.0 Portable External...
Won't recognize music files
My Sansa only reads mp3 or WMA files, not mp4 files.
also, i have tried three different computers, and all of them recognize (or NOT) my player differently....
~Rebecca~
Jan 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
3,694 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
