Question about Zanussi ZWF1230W Front Load Washer
Washing machine has power also has runing water as checked water pipe machine will make a noise as if starting but will not fill with water
Inlet filter blocked, or inlet valve broken.
Posted on Jan 13, 2010
It will not fill with cold water. Could it be due to the cold weather - the cold water pipe frozen. Kitchen is very cold (pipe is next to an east facing wall). Same pipe also fills the dishwasher,...
If youve taken the fill hose off and checked for running water out of tap and its not coming through, your machine is ok, you have a water fault.the humming is the water valve working.
Dec 21, 2010 | Washing Machines
My machine is 5 yrs old and has just stopped working. the wash light comes on but the wash cycle just does not start. The machine makes the normal start up noise but it appears that no water is going in or...
sounds like water valve is open circuit cheap fix ,manually fill machine with water to check it will wash and drain ok if so get valve replaced you can do yourself not difficult to change.
May 26, 2010 | Dishwashers
Maytag top loadind washer. Won't stop filling up.
Make sure your drain hose to the drain pipe is higher than the water in the tub if not it will keep running and going out the drain.
Also try taking the hose off the level switch and blow in it to be sure it's not stoped up. If is it won't let the level sw cut off. air should go through it. Good luck
When you unpluged the power and it ddn't keep runing the water valve should be ok.
Mar 25, 2010 | Maytag PAV2300 Top Load Washer
Water keep runing into the machine and exceed the required level setting. the machine will not start to washing is it that the water level in to high or does the water level setting control the washing...
put the washer on warm setting,start to fill washer,turn washer off,if it still keeps filling then you have a bad water inlet valve,if it turns off then check the water level hose from the head of the washer to the side of the outer tub,make sure both ends are on-mike
Jan 27, 2010 | Washing Machines
Whirpoll AWM 6000 does not take water.
What to check next is the water inlet valve. To do it, turn on the machine and start the filling cycle. If you cannot hear a faint buzzing or humming noise from the water inlet valve, the solenoid coil is not getting any power. Check it's wiring. If you can hear some noise, you need to replace it. Make sure to unplug the unit before doing any service.
Oct 18, 2009 | Whirlpool Washing Machines
Maytag washing machine won't drain or agitate
Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like a stray piece of clothing) and check the pump impeller. Make sure there are no blades missing/broken and that the impeller spins freely. If there are any broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Remember to disconnect the machine from electrical source before attempting any repair. Sorry for your trouble and I hope this helped. Best wishes.
Sep 23, 2009 | Washing Machines
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
My washing machine will not stop filling up. When you switch it on and set it to run on a normal wash, it will start ok and pump out some of the water but then it doesn't seems to stop filling up with...
possibly no part at all.
take top off and locate the pressurestat. this is usually round with up to 9 elec connections and a small diameter pipe as well.
take pipe off and blow down hard and check no split in pipe.
to check pressostat itself, put on a piece of pipe of the same diameter. put machine on fill and gently blow into the pipe ie pressure. you should hear a click and the water will stop coming in
Jul 15, 2008 | Washing Machines
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Zanussi ZWF1230W Front Load Washer Logo
91 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
