Question about Intuit QuickBooks Pro 2007 Full Version (299116)
Files are saved to a CD for backup but will not open after they have been burned to the CD. Error message reads "You do not have sufficient permissions to the specified folder. To use QuickBooks in a multi-user environment, you must have read/write access and create/delete rights to the folder where the company file is stored. Full permission has been given, but the message still pops up.
    Scholar:
  • 122 Answers
The files are set to read only on the CD. If you would like to open them, please copy / paste the files to your PC and open them from there.
To rectify this in the future, please set the file permissions on the files before you burn them, and remoce the Read Only attribute.
Posted on Jun 25, 2009
How do I repair a corrupted CDR file?
try the following:
- rename the file to ".zip "
- open the zip-file with Winzip or WinRar (these programs has a repair-function for zip)
- try to repair the file
- then extract the riffdata.cdr from content-folder of zip-file and open this file in CorelDRAW
These steps work for me.
Or try use CorelDRAW Repair Kit. CorelDRAW file repair software for recovery of the contents of damaged CDR files. Program helps to repair corrupted Corel Draw project files.
Corel Draw repair file
Jul 18, 2015 | CorelDRAW Graphics Suite X4 for PC...
When attempting to back up a file to cd error
make sure your disc is a rewritable CDRW or DVRW
Jun 27, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
I am getting an error message that says : could not preform end of disc-at-once
Hi Aubri,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not burn a DVD, chances are your DVD burner componet needs to be replaced. Good Luck.
  • If this helps resolve your issue, would you please rate the solution
Dec 29, 2010 | Gear Head 8XDVDEXT DVD External Slim...
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
Voice Recorder-Files to CD?
Please follow the below solutions to create either an audio CD-ROM of .wav files or back-up
.wav files to a CD-ROM.
Problem: .Wav files downloaded to PC computer from the DW-90, VN Series, and DSS Files
created with DS Series recorders cannot be copied to a rewritable CD-ROM using Windows
Media Player to create an audio CD-ROM.
Explanation: These digital voice recorders create .wav files at 8kHZ, 12kHZ, or 22kHz
depending on the Quality setting. Digital Wave player software is used to download Wav files to
a PC computer from the DW or VN Series of recorders. DSS Player is used to download DSS
files from the DS Series recorders and convert them to Wav files. If Windows Media Player is
then used to copy the files to a rewritable CD-ROM to create an audio CD-ROM, the files will
not copy properly or an error message may appear. Windows Media Player can only create an
audio CD-ROM if the .wav file is 44.1kHZ, 16 bit stereo.
Solution: Follow the procedure below to convert the .wav files to 44.1 kHZ, 16 bit stereo. Then
use Windows Media Player to copy the files to a rewritable CD-ROM.
1. Click Start, click All Programs, click Accessories, click Entertainment, and then click Sound Recorder.
2. On the File menu, click Open.
3. In the Open dialog box, specify the name of the audio file that you want to convert, and
then click OK. Files are usually located at C:\Program Files\Olympus\Digital Wave
Player\Message\Folder A.
4. On the File menu, click Save As.
In the Save As dialog box, click Change.
In the Attributes box, click 44.100 kHz, 16 Bit, Stereo, and then click OK.
Click Save. After you convert your files, try to copy them to a CD-ROM again.
Mar 21, 2009 | Olympus VN-4100PC Digital Voice Recorder
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
I cannot delete folders i put on a 1gb memory stick from my imac, i get error code 1407 or "you do not have sufficient privileges" messages
This is something I have found... Read on
you probably will not like my solution but my problem was only a mini external drive with about 20 files. I opened each file and <save> to another drive. For me it was easy, I saved to my HD. Then open Disk Utility and <erase> my mini drive, which remformatted me a clean and usable drive. Then just copied the files I saved and DONE.
Apr 17, 2008 | Computers & Internet
Back up
open quickbooks and do a backup and save it to your desktop or whatever location you prefer. after this is complete open Nero and choose create data disk. browse to the location of the quickbook backup is located then click to add, you can add serveral backup files by click add and browse to the next backup. put your cd or dvd in the computer and click the burn button.
Oct 30, 2007 | Computers & Internet
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
159 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
