Question about Logitech Attack 3 Joystick
How to set the throttle - Logitech Attack 3 Joystick
    Problem Solver:
  • 16 Answers
If you look at the very bottom of the front of the joystick, you will see something the is sorta like a wheel. pull the tab up to increase the throttle, vise versa to slow down.
Posted on Jul 03, 2009
Error codes 2101 and 1516 on my 2004 chevy trailblazer
DTC P2101-
The commanded throttle position (TP), based on accelerator pedal position (APP) and possibly other limiting factors, is compared to the actual TP. The 2 values should be within a calibrated range of each other. Both the powertrain control module (PCM) and the throttle actuator control (TAC) module redundantly monitor the commanded and actual TP. This DTC sets if the PCM detects an out-of-range condition between commanded and actual throttle position.
DTC P1516
The predicted throttle position (TP) is compared to the actual throttle position. The two values should be within a calibrated range of each other. Both the powertrain control module (PCM) and the throttle actuator control (TAC) module redundantly monitor the predicted and actual throttle position. This DTC sets if the PCM detects an out of range condition between the predicted and actual throttle position.
Do you know what electronic throttle control is ?
Pt 1 2007 Chevy 2500HD Reduced Engine Power Warning Fault Code P1516...
Jul 31, 2017 | Cars & Trucks
Carb settings for Homelite weedeater ST-275
Set both the H and L for 1 1/2 turn out from bottom, start and adj. The H for max rpm for full throttle, now set the low for good idle and very little or no hesitation when opening throttle. Now set H for max rpm again and then back off until you get more of rumble at full throttle.
May 31, 2017 | Homelite Garden
Lacks power after 1/2 throttle also knock on motor after 1/2 throttle
it may all be in the carby settings
if you do not have it adjusted correctly then it may be running too lean at full throttle and that is causing a problem such as detonation causing the knock
start it and slowly adjust the settings as you increase the throttle settings
take it in to a service center for a proper diagnosis and quote
Sep 18, 2016 | Garden
194. what's the timing light setting for a 3-1 throttle body type still distributor cap type?
Search Results
    194. what's the timing light setting for a 3-1 throttle body - Fixya
    www.fixya.com/.../t25920220-timing_light_setting_94_chevy_luminaap...
    Nov 30, 2008 - 194. what's the timing light setting for a 3-1 throttle body type still ...Question about Chevrolet Lumina APV .... Apr 08, 2011 ' 1994 Ford Aspire.
Oct 22, 2015 | Chevrolet Lumina APV Cars & Trucks
Settings for a mikuni carb t-40
Hi Anonymous, with engine at normal operating temperature idle speed is 950-1050 RPM and air fuel mixture screw (if unsealed) is 1/2-3/4 turns out from bottom, if sealed it's already pre-set. There is a throttle stop screw by the throttle cable ends that with the throttle wide open so the butterfly plate must be perfectly horizontal. Good luck
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 22, 2014 | 2002 Harley Davidson FXSTD - FXSTDI Deuce
1998 Kia sportage shows no codes but will start and idle although sounds labored, but will accept no throttle response. You can ease into it and some times it will accelerate
probley your throttle position sensor should have shown a code. try disconecting the pig tail and put it back tap on the side a little if theres any change to your problem then its probley the sensor .if your going to tinker aroud dont mess with the throttle set screw. leave it alone your throttle position sensor gets set from that screw wich the screw itself gets set while on the computer.also check to make sure the cable is okay and hooked to the throttle arm have your assistant press down the peddal as you hold the cable making sure the cable is not snapped if its not make sure the cable pulls the throttle arm back and forth .best i have to offer
Aug 05, 2010 | 2000 Kia Sportage
How do you set up the idle on a '93 Mazda Protege? It was easy to do on the old carburater cars.
Idles are preset ,and not adjustable on fuel injection,but look where the throttle cable attaches to the throttle,and where the throttle sets,there might be a screw with a lock nut,and will allow some setting,but not much,cause the throttle position sensor does this threw the computer.The throttle position sensor is on the throttle,on the opposite side of where the throttle cables attach.If this was helpful,then please rate,thank you.
Jun 20, 2010 | 1993 Mazda Protege
Where is the location of throttle actuator control module on a v6, 2006 gmc envoy? I believe it may be a reason why my vehicle will not crank. I got DTC: P1516 on a code reader. My brake is locked-in. I...
The commanded throttle position is compared to the actual throttle position based on accelerator pedal position (APP) and possibly other limiting factors. Both values should be within a calibrated range of each other. The powertrain control module (PCM) continuously monitors the commanded and actual throttle positions. This DTC sets if the values are greater than the calibrated range.
DTC Descriptor This diagnostic procedure supports the following DTC:
DTC P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
Conditions for Running the DTC • The ignition is ON. • The ignition voltage is greater than 8 volts. • The system is not in the battery save mode. • The engine is running. • DTC P0068 is not set. • DTC P1516 runs continuously when the above conditions are met. Conditions for Setting the DTC • The difference between the predicted and the actual throttle position is more than a calibrated amount. • The above condition is present for more than 0.5 second. Action Taken When the DTC Sets • The control module illuminates the malfunction indicator lamp (MIL) when the diagnostic runs and fails. • The control module records the operating conditions at the time the diagnostic fails. The control module stores this information in the Freeze Frame and/or the Failure Records. • The control module commands the TAC system to operate in the Reduced Engine Power mode. • A message center or an indicator displays Reduced Engine Power. • Under certain conditions the control module commands the engine OFF. Conditions for Clearing the MIL/DTC • The PCM turns OFF the MIL after 3 consecutive drive trips that the diagnostic runs and passes. • A History DTC clears after 40 consecutive warm-up cycles in which there are no failures reported of this diagnostic or any other emission related diagnostic. • The scan tool clears the MIL/DTC. Diagnostic Aids The throttle valve is spring loaded to a slightly open position. The throttle valve should be open approximately 20 percent. This is referred to as the rest position. The throttle valve should not be completely closed nor should they be open any more than the specified amount. The throttle valve should move open and to the closed position without binding under the normal spring pressure. The throttle should NOT be free to move open or closed WITHOUT spring pressure. Replace the throttle body if any of these conditions are found.
Important: Operating the throttle blade with the Throttle Blade Control function of the scan tool may cause additional DTCs to set. Do not attempt to diagnose DTCs set during this function.
The scan tool has the ability to operate the throttle control system using Special Functions. Actuate the throttle valve using the throttle blade control function located in the Throttle Actuator Control (TAC) System menu. This function will operate the throttle valve through the entire range in order to determine if the throttle body and system operate correctly
Oct 30, 2009 | 2006 GMC Envoy Xl
How do i install the inner throttle cable on a 1973 flh and get the length right?
If you're talking about the old style throttle cable that is internal of the handlebar, it's pretty straight forward. Remove the throttle grip, the rollers and pin for the plunger. Pull the plunger out bringing the old throttle cable with it or at least out far enough to loosen the small set screws that lock the cable in. Now, run the new cable through the outer housing. put the end of new cable into the plunger and tighten the set screws. Replace plunger into the handlebar, replace pin and rollers, replace throttle grip. Now, set the throttle to full closed posititon. Move carb throttle lever to full closed position. With throttle cable through clamp tighten screw securing cable. Check for proper operation of throttle mechanism.
Aug 08, 2009 | Harley Davidson FLHT - FLHTI Electra Glide...
Only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Jun 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Logitech Attack 3 Joystick Logo
265 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
