Question about Sony ACY-BR81/OB
My rca tv fell on the floor. now the color is messed up. it still works.
  • Sony Master
  • 5,515 Answers
Chances are that this is physical damage which will be visible to the eye. Look for areas on the printed board that are cracked and look at the solder joints for detachments from it, or lose joints. Pay close attention to where screws hold things in place.
Posted on Jun 24, 2009
New rca rtd3276h DVD home theater system only displays black & white , no color . Already tried different cables & I see nothing in menus about color. Help !!!!!!
There has to be a control for color level - look for it. If adjusting it does nada then something is messed up with your color circuits on tv.
Nov 14, 2015 | RCA Audio Players & Recorders
RCA 27R410T Television colors are distorted
If you`re talking about colored spots in the screen, then you may have a degauss problem. It was frequent for those sets to have bad solder joint on the degaussing coil connector or thermistor next to it.If you`re handy with a soldering iron these connections would be near the a.c line input. good luck and don`t forget to unplug
Nov 01, 2009 | RCA 27R410T 27" TV
I have an RCA 36 inch tv, the color is messed up, it has a round circle and it will not change channels
If the set wasn't dropped or physically dammaged the chances of it being the picture tube is very small.
The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV. Be sure to vote/rate me if this helped Thanks!
Oct 23, 2009 | RCA F36650 36" TV
The colors are out of wack.
THIS IS CAUSED BY A MAGNET IN THE SPEAKER OR SEPERATES SPEAKERS AROUND TV U WILL NEED TO GET IT DEGOUSED BY TV ENGINEER U MAY HAVE TO HAVE A SMALL THERMISTER CHANGED/BY ENGINEER
SOMETIMES LEAVE SET OF FOR A WHILE AND SWITCH ON AGAIN SOMETIMES USED TO WORK
MOVE SPEAKERS FROM SET
Aug 28, 2009 | Televison & Video
I have a rainbow of color about the screen. The TV fell out of the stand and now the color pattern is messed up. It fell face down.
sounds like a degaussing (magnetizing) problem.could be that the posistor inside the TV set got loose when the tv fell down. If you have experience soldering electronic components, you should be able to fix it by re-soldering. Otherwise, call a tv tech to do it.
Jul 15, 2009 | Sony KV-27V42 27" TV
Color of tv is mess up
just check your color settings at your menu on your tv. if ok its a cold solder from your CRT socket board.
May 24, 2009 | RCA TruFlat 27F520T 27" TV
My Tv doesn't power on!
hello the glass fuse inside the tv might have come out or worse the circuit board might have broken
shaun
Apr 08, 2009 | RCA R52WH73 Projection Television
Infocus 61 inches DLP-HDTV.
Infocus was always made by RCA for infocus the parts are straight RCA be warned that the parts for the RCA dlp's are very exspensive
Mar 04, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
RCA MM36100 color problem
sounds like you have a deguassing problem with your TV .. have the repair person bring out a deguassing coil and see if thsat helps.. This will only be a temp repair as you will have to have the problem that caused this to be fixed. good Luck
Aug 12, 2006 | RCA MM36100 36" TV
Computers & Internet Logo
95 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
