Question about Cameras
Camea keeps switching off doesn't seem to be charging
The green light on my MD1063 keeps going off after a second and the camera switches off. I've tried charging it but the light switches off straight away
    President:
  • 2,712 Answers
Could be a problem with either the charger or the power unit in the camera. I would contact a service center to get it serviced.
Posted on Jun 24, 2009
Reset Digilife DDV 7000 or other solution to get the camera switched on.
Appears this is a known problem - look it up on Google
Dec 19, 2017 | DigiLife Cameras
My kobo wont turn on
How to Fix Kobo eReader Locked up Frozen or Not Responding
1)Slide power switch to right and hold for 15 seconds and release
    2)Slide power switch to right again and hold till green/blue button near switch lights up.
Dec 05, 2017 | iPhone Apps
Seems to have a bad connection...
take a OBD2 scanner to have check, maybe you will know what is problem.
car diagnostic tools
Jul 29, 2013 | Razor USA Razor Dirt Quad Electric ATV
Philips HS8020/18 Shaver Red Light
How can check the s pass status check the passport number?
Jul 27, 2013 | Health & Beauty
Hp pavilion 752n wont turn on.
Seems like a dirty or a bad switch altogether. With the face cover off, try spraying it with an electrical parts cleaner. If that doesn't work, replace it.
Mar 10, 2012 | Computers & Internet
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
E system 1212 Laptop won't switch on. Power
Laptops are so integrated that usually a system failure that involves power issues such as in your case where you cant get it turn on with anything on the screen mean the mainboard (motherboard) is damaged. This usually leads to buying a new laptop or paying for the board to be replaced which usually costs as much as the laptop.
May 12, 2011 | Computers & Internet
The camera (option m*5 pentax) got wet (on Songkran in Thailand). Now it works again except that it seems not to be able to load the battery. If I connect the battery charger while the camea is 'off'', the...
Normally when camera gets wet, first remove battery, use dry facial quality tissue to wipe water, keep camera in a/c so that whatsoever moisture inside camera evaporates due to low humidity in AC room for 24 hours . Take hair drier set in low heat mode holding minimum 6 inches away from camera blow warm air in battery compartment, mirror compartment, memory card slot for 2minutes each. Wait for cooling down to room temperature. Put battery switch on. It should work. Wet camera if you switching on main board get short due to flash voltage in side camera.
Sep 25, 2017 | Pentax Optio M85 Digital Camera
Kodak Easyshare camera model MD1063 wont turn on
hi,your camera needs a servise , its a lance problem just open your camera and remove the lance assembly and servise it properly , otherewise contact authorised person,
Aug 29, 2009 | Digital Blue EasyShare MD1063 Digital...
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Feb 17, 2009 | Samsung Cameras
Cameras Logo
80 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
