Question about Dryers
I have a GE Dryer Serial #GL228541G Model DD25310 BAC WH. I am trying to replace the belt around the drum. I tried hooking the belt around the hooks to tighten the belt, but the drum is not turning.
  • taylorva Jun 24, 2009
    Thanks, the motor runs. I was having a problem with putting the belt on correctly. I will try agin using your instructions.
    Problem Solver:
  • 13 Answers
Does the motor run? The path of the belt is a little tricky. You have to push a loop of the belt around the belt tightener and then over the motor pulley. The top of the belt loop will ride against either a rolling wheel, or a plastic guide made out of low friction plastic. The bottom of the loop of belt should only go over to the drum. The tensioner is held in place by a tab that fits into the bottom pan of the dryer.
Posted on Jun 24, 2009
Squeaky GE Profile dryer model DPSE810EG5WT
There should be two wheels in the back that may have to be greased or replaced. There are two no friction pads that the drum rests on in the front that need to be replaced every once in a while. Go to searspartsdirect.com or appliancezone.com, with your dryer's serial number you should be able to find the parts.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dryer-Parts/Model-DPSE810EG5WT/0432/0151200?pathTaken=&prst=0&shdMod=DPSE810EG5WT
or
Appliance Parts and Accessories Repair Appliance Parts Discount Parts...
Feb 23, 2014 | GE Dryers
Need to identify belt parts for GE Gas Dryer DDG8580RCMWH
Check with an appliance parts supplier or directly with GE.
Jan 26, 2014 | Dryers
Lid on chest freezer will not securely close Model #FCM 7DAA WH Serial #RTI63278 Mfg 81998
Remove lid, squeeze hinge back into shape and refit, adjusting screws in rear of hinge bracket as you do.
May 19, 2012 | GE Freezers
Dryer belt replacement
put belt around drum then around motor pulley, then pull or push idler pulley so as to put belt over this pulley and release,this will tighten the belt,then manually hand rotate drum to self-align belt on pulleys and drum and put covers back on
Sep 04, 2009 | GE Profile Wizard DPSE592EAWW Electric...
Looking for a belt for G.E tumble dryer, model no: TL22PG. cant see code on belt as it is shredded.
take you model number to repair shop they will know
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 09, 2009 | Dryers
Need to know the exact way to put belt on ge dryer model number DDE7200RALWH cant figure it out around the pulleys , ge assures its the right size belt for the dryer , but belt seems loose and drum wont...
with belt around drum, pull idler back with tension on it and put belt over pulley of motor and let idler up against belt and it should be right ,,,, larryyb
Dec 10, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Drier Belt Replacement on GE model DDG7580
Open the door and remove four screws which go into the dryer top. Swing top back. Take out the screw on each side holding the dryer front to the side panels near the open top. Tilt the dryer front forward and lift it off the bottom pegs, then swing it to the side. Leave door switch wires connected. Lift up slightly on drum to allow the belt to be placed around drum. (grooves of WE12X82 belt touch the drum) Belt goes down from the left side of the dryer directly to the grooved motor pulley, then around the belt tensioning pulley and back to the drum. Your model has a removable panel at the bottom side of the back which will allow easy access to the motor pulley area.
Nov 10, 2008 | GE DVL223GB Gas Dryer
Ge dryer
you need to remove the front panel and kickplate (if you have one) This will allow you to detach the front of the top of the dryer and you can prop the top up while you replace the belt around the drum, down to the drive belt. Here's a link for your make and model. It shows an exploded view of the parts of your dryer. http://www.partselect.com/MultiModels.aspx?ModelNum=dde7100&searchTerm=&RefineSearch=0. This can help you figure out what parts you might need and how things go back together. Good luck!
Jul 14, 2008 | GE DBSR453EBWW Electric Dryer
GE Gas Dryer Replace the belt Model # DDG8280G
Usually there are one or two panel in the front that are held by some screws. Once removed the top panel is usually attached to the front panel and you can get a screwdriver and release the plastic push in retainers. Prop the top up and the drum is exposed. The belt usually goes around the drum down to a drive pulley on the bottom of the machine. You will need to route the belt around the drum in the front or back to get it routed correctly.
Jul 08, 2008 | GE DVL223GB Gas Dryer
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
Dryers Logo
113 people viewed this question
Top Dryers Experts
