Question about Dometic Rooftop RV Air Conditioner
Durotherm Model 57915.331 - not cooling properly
I have a similar problem - my unit starts to cool then turns to blowing room temp air. I can hear the compressor kick on and run. It doesn't sound like there's any valves flapping or running rough (i.e. low freon). Also, I checked the voltage in the camper - I'm getting a solid 118V at the wall plug.
I also sprayed out the coils on the roof. I didn't take the cover off to clean it, just blew water spray backwards through the coils to flush it out.
After doing this, I still have the same problems.
Should I take the cover off the top and make sure the coils are clean on the back side? I've also been told these units cannot be recharged - is that true?????
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Yes, you should remove the upper cover and check the back side of the condenser as Duo-Therms pull air in from the sides and blow it through the coils from inside the shroud. This usually will cause the compressor to shut down, but only after running for awhile. When you notice that the unit is not cooling as well, or not at all, got up on the roof and remove the shroud, check to see if the compressor is actually running. If the compressor is shut off, the problem lies elsewhere in the system. Check to see if the compressor is cycling on and off or if once it is off it stays off.
If you have a wall thermostat control, check for 12VDC power at the yellow wire when the compressor is off. If power is present, then remove the control box from inside the inner shroud of the unit and check for power at the yellow wire in the there. If it is still present, check for 120VAC power at the compressor relay (black wire with Purple or Blue wire). If the purple or blue wire have 120VAC power, then the problem is upstairs either with start capacitor or the thermal overload (located on top of Compressor). If there is no power at the purple or blue wire, try unplugging the freeze control and jumper the connection on the board (blue connection, white wires) with a small piece of wire, if the compressor comes on and runs, then you have a bad freeze control. If not, then you have a bad control board.
If you have manual controls on the ceiling unit, you could have a bad thermostat. Unplug power from the unit and remove the two wires on the back of the thermostat. With an ohmmeter, check for continuity between the two terminals, if there is, turn the knob and watch the meter. You should not lose connection until the temperature you set is above the temp. inside the unit. If this is ok, then you need to check the selector switch. Also check the components in the upper unit as described in the above paragraph.
Hope this helps,
Jeff
Rate me please!
Posted on Jul 05, 2009
2 Suggested Answers
motor1258
  • 6674 Answers
SOURCE: how to add freon to my 57915-331 duo therm camper
Normally that would be a closed/sealed system, not rechargeable, from the factory. Don't know what valve your seeing, unless someone has retrofitted it with valves for recharging prior to you purchasing it. I will say that quite often the reason for poor, or less cooling, than when new, is often due to simply needing a good cleaning of evaporator and condenser coils and fins. Has that been done lately?
Posted on Oct 04, 2011
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Jul 10, 2007 | Sharp CV-P09FX Air Conditioner
Check the fuses in the rv to make sure you are getting power to the roof unit. If the stat clicks and nothing happens up there you have got a faulty stat, or, worse, a compressor fault.
May 19, 2012 | Dometic Rooftop RV Air Conditioner
I have an celestial air con unit model KFR-70GW/K it is blowing air refresh out but will not turn on to air con with the remote... help
Check temp setting minimum -3 degree than your room temp and also in cool mode. If while settings there any beep sound? If not transmission problem between remote and PCB. Replace batteries and check once again. If beep sound comes and no start, check compressor is working and also with proper gas pressure. Thanks.
Jan 22, 2011 | Heating & Cooling
We have model #57915.54. The fan and compressor run, but is blowing hot air. Is there freon for the unit? If so, I heard that there was a kit you could purchase to do it.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure. If leak call repairman to rectify it.
Jan 11, 2011 | Heating & Cooling
Unit comes on and shut off correctly but dosen't heat and cool home equally. Blows cold air in winter and doesn't cool home properly in summer.
Toget proper heat, keep your temp setting at 30+ degree and also mode in "heat"position. If still no heat, check your heating sensor for closed circuit by anOHMs metre.It it's with RV, check power to RV.If it's with heatingelement check power to element. If power is there but still no heat meanselement defective. Replace new heating element. Thanks. To get proper cool, keep the tips as follows:
Thanks. Helpful?
Jan 09, 2011 | Intertherm Heating & Cooling
I have an old Kenmore 25,000 BTU Air Conditioner (Model number 253.7792580). Recently it started blowing air that is not really cool, it's actually room temp. It makes a slightly different sound when it is...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 29, 2010 | Kenmore Heating & Cooling
Problem with mitsubishi air roof units
to tricked the thermostat only a way i know,to put on it an ice cube for a while.propably wrong choice to installed roof unit you must installed to the floor better for the ac and to you
Dec 13, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Jun 16, 2008 | Heating & Cooling
Dometic Rooftop RV Air Conditioner Logo
972 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
