Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Spectra XL 44 Gas Oven Bottom Heating Element Faulty
The Oven part doea not turn on at all & I do not detext any gas leaking. The broiler section ( @ the top ) works perfectly fine. Any ideas? Does the broiler heating element and the standrd heating element work simultaneously?
  • 21 more comments
  • ZekerCat Nov 05, 2007
    I have the same problem... the igniter doesn't come on at all
  • sharilyn danebrock Nov 06, 2007
    I have the same problem. It was working fine up until yesterday. I tried to turn the oven on and the bottom doesn't heat up. The broiler is fine and the stove top works fine. There was no gradual decrease. Just stopped working all of a sudden.
  • Anonymous Nov 06, 2007
    I found a whole stream of people with this same problem. Go to and you will find out the problem and how to fix it.
  • Anonymous Dec 05, 2007
    turn on the oven nothing happens
  • Anonymous Dec 08, 2007
    same problem
    It was working...then not. The broiler works but not the Bake mode. Any suggestions?
  • Anonymous Mar 21, 2008
    Oven suddenly won't come on. Broiler, stove top and self-cleaning work. Isn't this the same heating element as the regular oven?
  • Anonymous Mar 24, 2008
    Gas burners work, but oven does not.
  • Anonymous Mar 25, 2008
  • Fixnow Mar 25, 2008
    I have a GEXL44 gas range. The stove top works fine, but oven isn't working. Pilot lght is out and will not light back. Smell no gas when trying to light. Any suggestions......
  • Anonymous Apr 26, 2008
    I baked a cheesecake, turned th eoven off, turned it back on to bake a cake and no heat...found out the lower glow bar stopped working.
  • Anonymous May 09, 2008
    I have had the same problem twice with my GE Spectra XL 44!! Replaced one oven igniter in Jan and a second one today!
  • gocubs May 23, 2008
    the top burners work and top broiler, but when I try to use just the won't heat.
  • Anonymous May 23, 2008
    My oven does not come on and I do not smell gas. The stove top works but the self cleaning does not work. Are they connected? Does it pay to call a serviceman or should I buy a new stove?
  • Anonymous Jun 08, 2008
    My GE JGSP28 does not always come on. It is supposed to heat to 350 unless a higher setting is punched in. Half the time it comes on when a higher temp is selected.
    Any idas?
  • Anonymous Jun 09, 2008
    Same thing here, when I press the button for BAKE nothing happens. I put a candle under the gas pipe and close the door to see if it was the lighting element...but apparantly no gas is coming out.
    I am thinking the electronics are kaput.
    Appreciate any insights.
  • wendyhed Jun 30, 2008
    after cleaning my oven now the oven want come on at all to bake. what do i do?
  • valana Apr 07, 2009
    I checked and found there is no power getting to the ignitor. What do I check next?
  • Anonymous Apr 30, 2009
    When i try to use the bake function, I cant set the temp, and then hit start, the computer says the oven is on, but the oven burner will not fire up, and there is no heat.
  • Anonymous Mar 17, 2014
    replaced broiler element and oven still does not work
  • Anonymous Mar 19, 2014
    could it be the temp hi thermostat ? replaced oven sencer.
  • Anonymous Mar 24, 2014
    switches work no heat oven elements?
    indicator lights are working
  • 473 Answers
First look to see if the ignitor is coming on. Most common problem is the ignitor is weak or just bad. When the power is applied to the ignitor it glows and builds up resistance to open the gas valve then it lights. If the ignitor is weak or bad it will not build up enough resistance for gas to come into the burner. One sign of this would be a "woosh" sound when it trys to light. If the ignitor is coming on but not lighting it is most likely the ignitor is bad. Should have a full glow. Also, if the ignitor looks whiteish in color this is a sign of it going bad. You can compare to the broil ignitor to be sure. If the ignitor doesn't come on at all will need to see if you have power to the ignitor. Let me know what you find and let's solve it before you rate the solution.
Posted on Nov 05, 2007
Same problem here. The ignitor went bad. The part + labor from a local appliance person set us back $201.35 !!
Posted on Mar 28, 2008
How do you get to it? On my stove there is no access panel
Posted on Mar 06, 2008
  • johnnie o Dec 28, 2012
    Remove the bottom Drawer and you can easily access it !
Broiler works but oven does not ge xl 44 model JJBP24BEA2WH serial LV201917P Is this worth fixing?
Hello-  Yes if it's the igniter for the oven burner. The lower burner may light, but if igniter is bad, gas flow will not increase, causing under-temp condition. The part is available for 40-75$, and is fairly easy to install. Part is accessed by removing drip pan at bottom of oven. Gas ranges last longer than electric if the self-clean 'function' is avoided. Go ahead and fix it!  Let me know if this info helps-- have more if needed.   Thanks-  Ed
Mar 17, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GX XL 44 Gas Stove Oven won't Work
HI. thanks for your question. the problem you are having is with the bare igniter, located in the oven on the gas burner. replace the igniter. thanks the appliance doc.
Oct 08, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
you will need a new heating element at the bottom. to find the part, go to ge's website and get the model #- you should be able to find it either online or a service center.
Apr 28, 2008 | Kitchen Ranges
Oven won't light
Probably a bad oven igniter. Remove oven floor then remove flame spreader. Turn oven on and see if igniter glows. If it does and still doesn't light gas, it's probably weak. Replace the igniter!
If it doesn't glow, remove and take to your parts store. They should ne able to check it to see if it's opened up.. If so replace it!
Nov 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra XL 44 gas oven
If you can smell the gas when you turn on the oven, it may be on a separate igniter that has gone bad. I would check this first. If you are not getting gas to the oven, there is possibly an issue with the supply line.
Sep 25, 2007 | GE Profile JGSP44 Dual Fuel (Electric and...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
3,582 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
