Question about Hand Tools
I have a 2004 DPC 6400 Makita/type325--62825 cut off saw,so far, I have replaced the ring-the pot and piston are A1-the ring that replaced the old one is a lot wider if you like,the carb has had a new kit--problem-the saw will fire and run for a short time after choke etc,then it suddenly dies as if fuel isn't getting through,then the saw will not fire at all until left for 10 mins.After this the saw won't even fire-The orginal problem was that the pot srews had vibrated loose ,which made the pot have little compression-also there has been a new pot gasket fitted. I have adjusted the carb diaphram so many times its dizzy, also this takes time,the carb is hidden under everything and has to be striped down.The saw has been used 3 days a week, tops, and then there could be days, weeks when not used ---Help please.
  • 62 Answers
MaKita DPC 7311 Saw, how do I get a piston in cylinder when replacing with a new one & ring ?
Provided the cylinder is sized for the piston and you have the correct rings, you need a ring compressor. If the cylinder slides over the piston/rings be sure to get a ring compressor that allows you to get the compressor off when the rings go into the cylinder. You can't use too much force to get the rings into the cylinder or you'll break the rings and have to start over. An auto parts or small engine shop will be able to get you the tool.
Dec 27, 2017 | Makita Garden
Spark plug gap for makita dpc 7311
take the cover of a pack of cigarette paper then its most of the times right.
Feb 24, 2012 | Makita Saws
Ive got a Makita concrete saw DPC 7311,it says a mix of 100:1 but thats alot ?
The manual says to mix it 100:1 if using Makita high performance oil or 50:1 using regular Makita 2 stroke oil. I'd go 50:1 with non Makita oil too.
Here is a site to download a pdf manual if you need it.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 18, 2011 | Makita DPC7311 73cc 14Inch Gas Powered...
Whats the mix for a two cycle dpc 7311
50:1 synthetic... one 2.8fl oz bottle per gallon of regular gas
Nov 27, 2010 | Makita DPC7311 73cc 14Inch Gas Powered...
Makita DPC 6410 won't start
Piston and cylinder kit Bailey's about $190.00
http://www.baileysonline.com/itemdetail.asp?item=DM+038130030&catID=395
HTH
Lou
This saw can handle up to 79CCs. we can rebuild him ,bigger, faster, LOL HTH
Lou
Sometimes the cylinder can be salvaged with muratic acid. Piston kits are quite reasonable.
Oct 23, 2009 | Makita DPC6410 64cc 12" Power Cutter
I have a makita dpc6410 disc cutter.it has a good spark and i have cleaned the carb and pressure tested the carb and the needle is holding and i have fitted a new fuel filter.it will fire up and run flat...
after servicing the carb,do u retune it?
blacking around the piston is no big deal for a small engine,as long as the piston rings are in order or in other words it still has compression.
check the fuel supply..
the tank should be airtight...
it is a diaphragmed carby...
Aug 17, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Hand Tools Logo
103 people viewed this question
Top Hand Tools Experts
Don Numinen
Don Numinen
Ivan
Ivan
Level 1 Expert
Bill Boyd
Are you a Hand Tool Expert? Answer questions, earn points and help others
