Question about Poulan "Poulan" Push Mower
I put a new gasket and diaphram on my Poulan Push mower. Now it starts and I can manually rev it up and it runs fine. It however will not rev on its own and runs at a very low RPM. What do I do?
  • 376 Answers
Sound like the governor spring needs more tension on it. The end to adjust is on the front right of the engine, under the air filter. You can see it's attached to a lever that you can bend away from the engine to stretch the spring. Caution! Don't bend the tab too much. You dont want to over rev the engine. It's made to run about 3000 to 3200 rpm's.
Posted on Jun 24, 2009
Lawn Mower Surges
Check valves. Vacuum from the engine draws the fuel in...sounds like vacuum is surging. Also it may have a "fuel pump" that may be bad
Aug 24, 2016 | Briggs & Stratton Garden
What did i miss
Valves have to be seated by lapping. If you skipped this then the valve seat is not correct.
Aug 11, 2014 | Poulan Pro Yard Tractor 2006 and Newer...
Lawn mower running suggish
fuel problem???? ya know carb cleaner works on lawn mowers as well as cars .
Jun 07, 2014 | Poulan "Poulan" Push Mower
Primer will not pull gas to carb and will not run. gasket replaced
You can check the priming circuit manually by pulling the plug off the spark plug and then with our hand over the air inlet to the carb have someone give the mower 3-5 pull starts. Then, put the plug boot back on and try to start it. Did it work? Is it still running? If it started and ran your primer bulb probably has a leak and needs replacement. If it started and ran for a few seconds and died clean out the main jet and the bowl inlet.
You can look at the breakdown of the carb in your manual to see where these parts are. Or just go online and find a familiar carb diagram and work from there.
Good luck and be careful!
May 24, 2010 | Poulan "Poulan" Push Mower
Won't stay running
you may need to disassamble the carb and clean it thoroughly.
May 09, 2010 | Poulan "Poulan" Push Mower
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Won't stay running
these carb /air filter housing gaskets were notorious for warping? there are 2 screws behind the air cleaner remove those and disconnect the throttle cable pull the black square housing off and replace the gasket with a rubber one from local mower shop?
Aug 27, 2009 | Poulan Pro 22" Self Propelled High Wheel...
My Poulan runs for a few minutes then idles down shuts off. Get it running again does same thing
Check the governor spring to see if it is streched out or the bracket it attaches to is bent,this can cause the problem. Also the carb may need cleaned and rebuilt,if it contains a diaphram gasket it could be bad causing it to die.
Jul 01, 2009 | Poulan "Poulan" Push Mower
Push mower runs for 3 seconds and dies brand new mower used it 2x
If the carb mounts directly on top of the tank chances are the diaphram gasket between the carb ant tank has swelled and needs replaced
Jun 14, 2009 | Mtd 22" Yard Machine Push Mower
Poulan "Poulan" Push Mower Logo
289 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
