Question about Canon Selphy CP510 Thermal Photo Printer
"paper-feed error" I've got a Canon SELPHY CP510 and it worked yesterday, but when I tried to print again today (both times from the computer, not the camera) it told me I had a paper-feed error and I should "Check that paper is correctly loaded in the paper cassette, and that the paper cassette is correctly installed." I did, and it all seems fine, but when I hit resume it refused to print. There's plenty of paper in the cassette thing, and it's in the right way, so why won't it print?
Had the same problem with mine, very intermittent. Remove all the paper and open the feed tray lid so you can get access to the three grey pinch rollers. Start printing then push on the roller with your finger to try and 'rough it up' (if it clicks you are pressing too hard).
The fault appears to be that the pinch rollers are loosing their grip and can not pull the glossy paper through. I dare say using a mild washing up liquid solution would be better but this is a safe quick fix.
Did this to mine and it has worked fine ever since.
Posted on Aug 02, 2009
  • Thomas
    Thomas Dec 28, 2013
    did not work for my Canon Selphy 810 -same error message
Recently had the same problem, including same error message. Scratched the three grey pinch rollers (located inside the unit, not the load tray) w/my fingernail to "rough it up." Also gently lifted the load tray until the paper was fully "engaged" by the three pinch rollers. Woiked like a charm!!
Posted on Oct 24, 2010
  • Thomas
    Thomas Dec 28, 2013
2 Suggested Answers
SOURCE: cassette has paper in it; fresh ink cartridge; can
This is sort of scenario is usually caused by dust inside the printer. Dust has a way of preventing the sensors from detecting paper. Also it prevents the rollers from having a firm grip on the paper while picking paper. I will suggest you get a long handle brush and try to reach as far inside the printer as possible and brush (from the back and front). If you have a blower you may also use it to blow well into the interior of the printer (If you do not have a blower the brushing will still do if you do it well.) This, if properly done should do it. Brush especially the rollers etc.
Posted on Dec 21, 2009
Testimonial: "That was exactly the information I needed. It still needs a little push on the paper once in a while, but I'm back to printing. THX"
I don't have the paper tray. Can I feed photo paper into it by hand?
Yes you can one at a time but you need to have it positioned correctly or the machine will not feed the paper in straight and you will wind up with a paper jam.
Jan 10, 2016 | Canon Selphy CP510 Thermal Photo Printer
Canon selphy cp510 printing spuneti
Typically the paper pickup rollers need to be cleaned or replaced.
Pickup mechanism may be damaged as well.
If you attempt to clean use 100% isopropyl alcohol with caution.
Nov 22, 2013 | Canon Selphy CP510 Thermal Photo Printer
Cassette has paper in it; fresh ink cartridge; can hear the engine running, but I get a paper feed error Canon Selphy CP510
Dec 21, 2009 | Canon Selphy CP510 Thermal Photo Printer
I have a Canon Selphy CP510 printer. I have honestly not used it in a few months. I just got back from vacation and wanted to print my photos. I send the pictures from my computer to the printer. It...
If the rollers are working, but its not pulling the paper in, I would suggest, as suggested in another thread, to 'rough up' the rollers in an attempt to give them better grip and maybe a bit more circumference.
May 28, 2009 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy 510
Hi! I have same problem. I opened cover (4 deep screws at the bottom) and found small plastic gear was separated from stepping motor shaft. I fixed it on shaft and my printer started work again. Today I will try to fix same problem on another CP510. I think same reason. Try to do it. Simple. vadim.y.astakhov@gmail.com
Feb 29, 2008 | Canon Selphy CP510 Thermal Photo Printer
Printing marks
I had issues like this, and changed to thinner paper. That solved my problem
Jan 01, 2008 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy CP510 "no paper" error
dak puteti sami spuneti de unde iau kitul de instalare pt canon cp510 VA MULTUMESC
Nov 26, 2007 | Canon Selphy CP510 Thermal Photo Printer
Canon selphy cp510
pull open the blue flap at the front, cartridge goes in there.
Jun 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
Printer will not feed paper
Mine did that too.
I found that propping the paper feed cassette up at the end away from the printer worked.
May 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
Canon Selphy CP510 Thermal Photo Printer Logo
2,795 people viewed this question
old marine
old marine
