Question about Tools & Hardware - Others
My wood floors in my living and dining rooms have 4 coats of polyurethane. This was done professionally about 5 yrs. ago. I want to give the floors a facelift by adding another coat of polyurethane. What are the steps for me to follow so I can do it myself? Thanks, Joanne
  • 4 Answers
This will dependa litlle on the type of Polyurathane that was originaly put down - single pack or two pack and if you have done any type of upkeep to it in the mean time. Some people like to wax there floors to give them shine and a deadly slip factor, if you have waxed your floor you need to remove this wax before youo go any further. Talk to a local chemical supplier to find a wax remover. If you have not waxed your floor this makes it easy.
Wash the floor with a solvent cleaner that contains no waxs or soaps - I use mineral Turpentine on clean rags.
Sand the floor with a hand sander (orbital, vibrating or belt your choice, I prefer to use a square vibrating sander or 8" Orbital) - you do not need a floor sander unless you want to remove all your PU and get back to bear timber. The process of sanding is designed to rough up the whole top surface so that a new layer of PU will adhear to the old PU. So use about a 80 gritt pad. to fine a sand paper will not give a good key for the new PU and to rouogh a paper may scratch to deep into your floor.
Note: if your original floor was stained you must be very carful not to sand all the way through the PU as the timber underneath will show through as a differant colour.
Dust off the floor with a clean broom to remove the bulk of the dust then use Methalated spirits on clean rags and completly clean the floor. You are now ready to start applying the PU as per the manufacturers specifications.
Other things to note:
1) I always wear socks when cleaning back the floor for the last time as oil from your feet and hands can transfere onto the floor and cause small patches were the PU does not adhere properly.
2) After the reccomended drying time I always insist that my clients wait an additonal 24 - 48 hours to allow the PU to fully harden before they walk on it or move furniture. A lot of the PU manufactures seem to cut down there drying times to make there product more appealing to busy market.
Hope this helps.
Posted on Jun 26, 2009
How easy or difficult is it to remove wall-to-wall carpeting and what are the best tools?
Ok,first off you may not need to remove the 1/4 round, being hardwood floor under the carpet, the 1/4 round was probably installed for it and the carpet was installed up to the 1/4 round baseboard.
It is fairly easy to remove carpet and pad. Take a pair of pliers and go to a corner, take a bite of carpet with the pliers and pull. It should come up if no base was installed on top. Now you just work your way around the room pulling up the carpet. once the carpet is free you can roll it up like a burrito, (each side to the middle then roll from one end. The tighter the easier to manage.) or you can fold one side in and cut it into strips 3 foot 4 foot whatever, to make it easier to carry out then roll strips up. Once carpet is out the pad is next. It will have been stapled to the wood floor around the perimeter and where 2 pieces of pad come together. You just pull the pad up, it will tear and the staples will stay in floor but just get rid of the pad, pull it and roll it and carry it out. That will leave you with a hardwood floor with a bunch of staples with pad chunks and tackstrip nailed to the floor.
A pair of pliers and a lot of patience will remove the staples and a pry bar and hammer will remove the tackstrip. A carpet knife available at any Depot for Homes is best for cutting the carpet. The brick on your floor was probably laid on top of the hardwood and wont need any trim, if you want you can trim it with 1/4 round to match the existing. Your transitions from wood to linoleum can be done in flat metal that comes in 1 inch wide or 1 1/2 inch wide gold or silver and nails down with twisted nails of the same color. You can also find wood transition strips or make them yourself, the wood transitions I think look better but cannot be made as flat, so there is a trip hazard issue. Any gloves will work. I have been installing floors for 37 years and I personally dont wear gloves when tearing out carpet and pad.
Jul 01, 2015 | Building Materials
I've put oil on my penetrating finish wood floor and it won't dry! Footprints everywhere!
Jennifer there are certian types of oils are made for wood such as linseed oil,but they set up with a hard and shiny finish. If you used an oil that does not set up such as motor oil for instance it will up to a point soak in but still feel oily.If that is the type you used, you may need to cut it with a solvent so it will soak in the wood better. then refinish after a thorough drying with a floor varnish. If you do try to cut it with a solvent be sure to turn out all pilot lights or better yet just shut off your gas, and up plug any appliances that have motors thst start automaticly. good luck
Jun 14, 2014 | Garden
Equlvalent expression
Assume that the room are rectangular.
Let W be the unknown width of the dining room in feet
Area of living room= 10*12=120 ft^2
Area of dining room =10*W
Combined area= sum of the two areas= (120 + 10* W) ft^2
Alternatively, you can factor out the 10 to get
Combined area =10*(12+W) ft^2
Mar 09, 2014 | Office Equipment & Supplies
Sealing laminate flooring
for determining that more information is needed, especially what type, brand/manufacturer, what thickness, base and chemical base of it...
in most cases sealing laminate (especially printed laminate!) is bad idea. if this laminate is with wood overlay at the top, with thickness of at least 1.5mm (1/16") and not chamfered edges (for skilled craftsman - floor installer, even 1mm) , then you can use any type of floor paint on the top,
you will need to wear chemical mask if you use poly or any solvent based paint, mask will not be necessary if you use water based paint. during sealer process - you can keep windows open, but not during painting... open windows will cause ripple effect on the paint!
prepare floor in following method:
sand very lightly (matt only indeed) firstly whole area with #120 or even #150 mesh and then with scourer of #180 or #240, if possible use rotary, do not forget to do edges of the rooms! and especially corners...
if this is "bare" wood then:
1. use universal sealer, use good quality paintbrush (50mm - 2") on the edges and corners of the floor and use good quality long hair roller on broad area, sealer will dry up within half hour to 1hr, depending on temperature and humidity, after seal dry,
2. paint directly over prepared floor with appropriate paint, suitable to the sealer and your requirements.
3. after 24hrs, scour area again in method as above and then
4. strain the paint and paint final coat.
5. wait at least 24hrs before you step on the floor,
6. wait at least 5 to 7 days before moving furniture in, especially haevy items!
7. wait at least 30 days before you put rugs or mats on the floor
if this is pre-painted laminate and no damage to it, you skip point 1 and follow from point 2.
it is labour intensive process and albeit cut can be made in several days, paint must be done in single go! better if you have some assistance, one person doing the edges and one person rolling the paint. i do this sometime alone but usually one of the ta's will assist me... paint need to be applied rather thick in even motions no puddles and no bare bits left on the floor!
if you think about skipping cutting stage - DONT! - paint will start flaking and peeling away sometimes in few days or weeks, sometime after a year or so...
Jan 23, 2014 | Hampton Bay Building Materials
How do i finish a doorway threshold going from hardwood to linoleum, there is a height difference, the hardwood is lower.
You need a reducer strip. Find a local hardwood flooring supplier and tell them the height difference between the two floors and the length of the opening. Once you have the right reducer find a wood stain that matches your floor. Next stain the reducer and finish with either a high gloss or matt finish polyurethane coating available in a spray can. Once the piece is finished your ready to install it. If the subfloor is wood then you can nail it down and putty the holes. If your subfloor is concrete then you will need to glue it to the floor with some liquid nails. Apply the glue to the bottom of the reducer put into place and weigh it down for 24 hrs.
May 29, 2013 | Building Materials
Where can I see a good example of how to set up a floor vase in my kitchen?
I love these. This picture inspired me to add floor vases to my dining room.
http://www.houzz.com/photos/881231/Modern-Dining-Room-modern-dining-room-toronto
Feb 27, 2013 | Home
I have decided to distress my old dining room table to give it a vintage look. What do I need to get started? Will this be hard to do?
Distressing wood is not a difficult task. It is quite simple and can make a boring old table look interesting again. Here is a how-to guide that will take you through the process.
http://www.ehow.com/how_4882264_distress-wood-table.html
Aug 09, 2012 | Furniture
I'm looking to purchase a Rudd 2 stage model, 16 SEER, 5 ton along with a 100000 BTU 95% furnace. I have a two story home and will only be using the 1 AC. Will the Rudd cool both floors?
Assuming that there are ducts ran upstairs and downstairs, it all depends on the square footage of the living spaces, i.e. bedrooms, living room, dining room, etc. You need an average of 1 cfm per sq ft. For every 1 ton of air, you have an average of 400cfms. So your 5 ton unit will cool/heat 2000 sq ft. A 16 seer unit with a 95% furnace is a nice buy and you will notice the difference for sure. Hope this helps!
Aug 03, 2010 | Ruud Central System Air Conditioner
Tools & Hardware - Others Logo
155 people viewed this question
Top Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
