Question about KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher
Kitchenaid model # kuds011jbs0
The normal and rinse button is constantly blinking and washer will not run . I did recommended reset by turning off power for 5 - 10 minutes and it still didnt go off !! please help !
reg501
  • 413 Answers
SOURCE: My KitchenAid dishwasher model KUDM01TJBS0
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Posted on May 29, 2008
bestdarngood
  • 3037 Answers
SOURCE: RINSE ONLY LIGHT BLINKING Kitchenaid KUDM01TJBS0
The keypad interface is bad, you would need to replace that and then it should work great. Let me know if you run into any trouble or have further questions and I would be glad to help.
good luck
Posted on Jun 02, 2008
SOURCE: Kitchenaid KUDS01DL. The "Rinse
Turned off the breaker for the dishwasher overnight. It is working fine this morning.
Posted on Nov 25, 2008
Daniel S
  • 4323 Answers
SOURCE: My kitchenaid dishwasher (KUDL02FR) on the control
Hi
To resolve the issue try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 30, 2011
mc1bean
  • 3053 Answers
SOURCE: my kitchenaid dishwasher KUDS011JBS0 has
Hello, solar
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 27, 2011
Dishwasher motor starts and stops
Hey Bill,
Not professing to be any kind of a dishwasher repairman but I have had a similar issue with the start and stop thing and it turned out to be the timer motor had started to go, and in going it 'burned' a couple of sets of the contacts as well. Check with a local appliance repair centre and see first if they agree with me, and if they have anyone who can rebuild the timer - Typically not too hard to get access to and remove - In my case in Canada, it had to go to Toronto pre-paid but $70 was cheaper then a new dishwasher and it's worked great for years
Feb 09, 2014 | KitchenAid Dishwashers
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
Whirlpool AWM8121-The Rinse and Door open light blinks constantly
This error code means there is an abnormality.
If the on-off door lock LED on a Whirlpool washer flashes rapidly at the same time as at least one other LED, then this means there is an abnormality.
Try first to reset the machine. You can press and hold the reset button for a couple of seconds, otherwise turn off the power completely (unplug it) for 5 mins.
Mar 01, 2018 | Whirlpool AWM8123 Front Load Washer
My normal cycle and cancel button lights are blinking on my kitchenaid dishwasher. Model # KUDP02CR8S2 Any suggestions?
Probably a keypad gone bad. Try replacing the keypad.
There is a troubleshooting guide behind the foot kick panel. It gives a sequence to test for a bad keypad. You can try that sequence to be sure.
Apr 20, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
KitchenAid 23 in. KUDD01DPPA Stainless Steel Dishwasher Logo
312 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
