Question about Microsoft Xbox 360 Console
My xbox goes off atfter 10 minets
I have 2 red lites someone help me
  • 6,784 Answers
Alternatively Overheating can be cause by the console locking up or "freezing" after a set amount of time. Lockups that occur at a specific point in a game are generally problems with the game itself and not caused by overheating.
THINGS TO TRY
1. Let the Xbox 360 console cool.
Note You may have to wait several hours for the console to cool enough. Do not turn on the console when the console is hot.
2. Verify that the console has sufficient ventilation and that the fan is operating. For more information about ventilation, see the "More Information" section.
PREVENTION SUGGESTIONS
To try to prevent this problem, use the following precautions:
* Do not block any ventilation openings on the Xbox 360 console.
* Do not put the Xbox 360 console on a bed, on a sofa, or on any other soft surface that may block ventilation openings.
* Do not put the Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well-ventilated.
* Do not put the Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
DO NOT EVER PUT YOUR CONSOLE IN THE FREEZER OR OUT IN COLD WEATHER
Some people think that doing this might help "fix" an overheating console, in fact doing so could cause even bigger problems. Electronic devices like your console are made to function at and around room temperature, extreme cold temperatures can often cause just as many problems as extreme warm temperatures (such as overheating). Also if the console is located in a dramatically cold area while running, the difference in temperature between the hot console and cold air can create condensation which in turn will short out your console making the situation far worse. Condensation will happen more quickly if your console is overheating due to the greater difference in temperature. In short... DON'T DO IT.
A more aggressive Solution to overheating is to improve the cooling system of the console. The best solution is to replace the thermal compound. If you attempt this you do so at your own risk. If you're console is still under warranty it is recommended that you contact MS for a replacement before attempting to fix it yourself.
Posted on Jun 24, 2009
Screen is all different colors and lines
wrap it in 2 towels 4 ten minets n the pictur should come up worked with mine but the day later got red ring of death
Jun 10, 2010 | Microsoft Xbox 360 Console
My xbox flashes 3 red lights then goes to 2
Hello Mr .
1) Remove your hard drive and/or memory units.
2) Run "Initial Setup" under the system blade.
3) Decline inserting HDD or memory unit when prompted.
4) Sync your controller and pop in a game.
Fix-shadow
May 19, 2010 | Microsoft Xbox 360 Console
How do i fix an xbox 360? everytime i turn it on after 5-10 minutes the screen goes blue and the green light are replaced by 2 red rings of death. How can i prevent this from happening please help? ...
Without opening up the console itself, there is nothing you can do. By opening up the console, you will void the warranty also, so unless you are trained in console repair, this is ill-advised. If you contact Microsoft directly, they are usually very helpful with repairing or replacing faulty units up to around 3 years old. Their details can be found on their website or in your manual.
Feb 17, 2010 | Microsoft Xbox 360 Console
DS Lite mic is not working for brain age or nintendogs help!!!
i think you should look for atechnician to
fix it !!!!!!!!!..........ok?
Aug 03, 2009 | Nintendo DS Lite Console
2 red flashing lights
The Xbox console is overheated.
  1. Let your Xbox 360 console cool. You may have to wait several hours for your console to cool enough. Don't turn on your Xbox 360 console when the console is hot.
  2. Verify that your Xbox 360 console has enough ventilation and that the fans are operating.
  3. If the two lights continue to flash red after you try steps 1 and 2, contact Xbox Customer Support.
To try to prevent this problem, follow these precautions:
  • Don't block any ventilation openings on your Xbox 360 console.
  • Don't put your Xbox 360 console on a bed, on a sofa, on a carpet floor, or on any other soft surface that may block ventilation openings.
  • Don't put your Xbox 360 console in a confined space, such as a bookcase, a rack, or a stereo cabinet, unless the space is well ventilated.
  • Don't put your Xbox 360 console near any heat source, such as a radiator, a heat register, a stove, or an amplifier.
Taken from Microsoft support.
Best of Luck.
-Mind
Jun 30, 2009 | Microsoft Xbox 360 Console
Red & green flashing lights
Microsoft knows this is a problem with the connection to the board from the power cable to the disk drive. They cannot repair soldered points to the board. neither can't anyone else. I have been loking for someone to repair mines. The point at which the power cable connects to the board is lose and disconnected at certain points. Pretty much if this is your problem you need a new console. If thats your problem.
Jun 03, 2009 | Microsoft Xbox 360 Console
I have 3 red lights what is the problem !!!!!!!!!!
Three red lights on the ring of light is an indication of a hardware failure
Here are things to try:
1. Turn off the xbox 360, disconnect the cables wait for 20 seconds reconnect the cables and turn it back on.
2. Check the light on the power supply ( The big brick that goes to your wall )
If the light is green that means the power supply is OK
If the light is Red that means the power supply needs to be replaced
3. If above steps doesn't work, you need to contact xbox customer support to get your xbox repaired
and shipping and handling will be covered.
Apr 05, 2009 | Microsoft Xbox 360 Console
Two red rings
that meas your xbox is broken
Jul 16, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
