Question about Averatec Tablets & eReaders
Can't get my Averatec to power up at all.We had been experiencing issues with the ac adapter and then starting having problems with start up. We had to reboot the entire system at least twice. I finally purchased a new ac adapter thinking that would help the issue. No luck. There is no response from the notebook when plugged in. It is not charging and won't power up. Any suggestions or insights as to what might be going on?
SOURCE: the AC adapter light does not come on when plugged in
This happened to me recently. I did as the engineer said and it worked.
Posted on Feb 03, 2008
  • 72 Answers
SOURCE: My Gateway m275 tablet will not charge or power up even with it plugged in
At least a 50% chance the power pin inside the computer has been damaged. Taking apart a laptop and getting it back together correctly is a tough job . . . .The part (the power pin) is not that expensive ($ 5-10) but the labor is expensive. If you don;t feel up to the task, have it fixed by a professional and after it''s fixed get a CRD (Cable Retention Device) to keep from damaging the pin a second time.
Posted on Aug 26, 2008
  • 157 Answers
SOURCE: Power adpater/battery problem
You need to check with an HP service site about the mixed battery/power adapter problem. You may have a bad battery.
Posted on Feb 03, 2010
  • 256 Answers
SOURCE: HP 2710P will not power on!
Try power draining your computer first. remove battery and ac adapter, then press and hold power button for 15-20 sec. Expect no response since there is no power source. After that, try if pc will now turn on. If it still wont, possibly it will be needing a motherboard replacement.
Posted on Apr 26, 2010
  • 367 Answers
SOURCE: My m1300 works great as
Take the battery out of your device and inspect the pins on the tablet. If they are very dirty or if something is stuck between pins, it could cause the battery to fail at transferring the correct power for the device in order for it to stay on. If all the pins look ok and it still doesn't work after putting the battery back in, you may have an issue with the motherboard which will need to be serviced by the manufacture.
Here are some battery LED codes from the manual:
LED steady green --> battery 100% charged AC plugged in LED steady amber --> battery charging AC plugged in LED steady red --> battery overheated or defective (replace it) LED flashing green and amber --> battery discharging abnormally (replace it) LED slow-flashing amber --> 10% battery charge remaining AC unplugged LED fast-flashing amber for only a few seconds --> 3% battery charge remaining AC unplugged
Chris
Posted on Aug 15, 2011
HiSense Sero 7 tablet. Why no charge, no power?
About 1,620 results (0.80 seconds) Search Results
    HQRP USB to micro USB Cable / USB Charging Cable for ...
    www.amazon.com > ... > USB Cables
    Amazon.com, Inc.
    Rating: 2.9 - ‎22 reviews
    1A AC Wall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA .... If you try to use the tablet while it is being charged, no charging will take place.
    HQRP AC Adapter / Battery Charger / micro USB Charging ...
    Amazon.com, Inc.
    Rating: 3.7 - ‎6 reviews
    HQRP USB to micro USB Cable / USB Charging Cable for Hisense Sero 7 LT E270BSA / Hisense... ... HQRP Micro-USB AC Adapter rapidly charges your Cell Phone / Tablet PC ... This one does not. ... Yes No Sending feedback. ... $3.91. 1A ACWall Power Charger Adapter Cord for Hisense Sero 7 LT Lite E270BSA Tablet.
    HQRP AC Adapter Dual microUSB Charging Cable for ...
    www.amazon.com/HQRP-Adapter-microUSB-Chargin...
    Amazon.com, Inc.HQRP AC Adapter Dual microUSB Charging Cable for Hisense Sero 7 LT E270BSA... Do not wait until charging one of your devices to charge the second.
Feb 09, 2016 | Tablets & eReaders
My Averatec C3500 powers on all lights come on except the blue one, which i think is for the display. the screen dosent display anything, when i hook it up to an external monitor via vga it still dosent...
hi
i found the Averatec link for support -- i was able to locate something may help you -- but if you are not egtting any viewing, then the LCD panl;e may be defective or dmagaed somehow.
go to this link , .. it may be brightness issue (hopefully)
http://www.trigem.com/us/support/faq_view.asp
Jan 09, 2011 | Averatec C3500 Tablet PC
The power light is off The charger is OK with 19Volt The connector is OK and somehow there is a problem with in the power
remove the battery, connect the ac adapter and turn on the laptop. If it turns on then it's your battery. If it doesn't turn on then it is either your ac adapter, your dc jack, or your system board.
If it doesn't turn on then try a different ac adapter from your local pc shop or electronics store. If it still doesn't work then try moving the ac adapter connector and see if it attempts to turn on. If it does then it's your dc jack. If it is your dc jack then you will have to replace it. The problem with that is that it can be pretty expensive to replace it.
The way I have solved this is by ordering a dc jack on ebay or any other online parts supplier and replacing it myself. If you can take your computer apart and put it back together then it's just a matter of desoldering and soldering the new one. If you want you can have a pc or tv shop do the soldering for you.
Have fun and let me know if you have anymore questions.
Dec 14, 2010 | IBM ThinkPad X60 Tablet PC
I purchased this product around June 2010, and it has been great but now it won't come on. I plugged it in to the wall using the adaptor provided and still no power. This is not the first time it has done...
Drain Flee power
Steps to do
Disconnect AC adapter,
Remove Battery
Press and hold power button for 30 seconds.
Reconnect adapter and battery
Start your pc and go to safe mode and check power settings.
Depending on your OS check event log /windows error log to find out what is causing the problem. And disable the service or reinstall driver needed.
Check for post message , check display screen in bios
Dont forget to say thanks!
Aug 11, 2010 | ASUS Eee PC T91MTPU17BK Tablet
Feb 03, 2010 | Compaq tc4200 Tablet PC
The power button doesnt start the laptop
Toshiba Satellite R15-S822 Tablet: Battery is charged and operational power supply (charging light is on) is plugged into power port on back side of laptop: Problem is sliding "power on" switch does not start laptop - no sign of any electrical activity...
Nov 04, 2009 | Toshiba Satellite R15-S822 Tablet PC
WHEN IM ON MY NEC VERSA LITEPAD DOIN WHATEVER THE CURSUR(arrow)CONSTANTLY JUMPS TO THE START MENU AND WONT STOP. HOW DO I STOP IT?
Almost all NEC litepad's have that problem, it's caused by AC current leaking fromt he adapter. Seacrch for LitePad Fix on google for a software solution. Also, preferably change your AC adapter to a OEM.
Jun 30, 2009 | NEC VL-PAD-933 Tablet PC
Acer Travelmate C112TCi- Won't power on
Remove the adapter and the battery from the laptop.
Press the power button and hold it down for 20 seconds(without the battery or adapter plugged in to it). This process is called POWER DRAIN.
Now connect only the adapter and try to turn it on.
If it starts up, there is no problem with the adapter or the laptop.
If it doesn't, it can be either the adapter or the laptop.
You will have to check it with a different adapter to confirm which one is faulty.
The second case is that the computer powers on only with the adapter.
Then you can put the battery back in and try powering it up.
If it doesn't work, try connecting the adapter too.
If still it doesn't work, its a faulty battery.
Sometimes after doing a power drain, the computer will work fine.
If you have any more issues, feel free to contact me.
Aug 25, 2008 | Acer TravelMate C112TCi-SP2 Tablet PC
Need to fix AC adapter plug in
I'm trying to repair the same thing right now.
to get the case apart, the hangup screws are under the keyboard. to remove the keyboard, you must remove the small plastic (1"x8") strip that has the power button and indicator leds on it.
to remove it, go along the top of the keyboard, closest to the screen, there are 5 plastic tabs to be released, then pop only that side closest to the keyboard up, then, slowly work it around until it comes free. flip the keyboard towards you, and carefully remove its ribbon cable by first popping up the sockets (on the mb) retainer.
then you can get those last screws out and have at it.
peace!
May 19, 2008 | Averatec C3500 Tablet PC
Averatec c3500 code 39
Hi
The recovery disc is run during the start up of the computer not in windows. But I do have a suggestion on the Code 39 problem.
See it on this page
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
Let me know if you need further assistance.
Thanks,
Ekse
Apr 03, 2008 | Averatec 3500T60 Tablet PC
Tablets & eReaders Logo
63 people viewed this question
Top Averatec Tablets & eReaders Experts
Are you an Averatec Tablet and eReader Expert? Answer questions, earn points and help others
