Question about Seagate Barracuda 7200.10 ST380815AS 80 GB SATA Hard Drive
BSOD In windows XP Pro the BSOD 0x0000007B "can't find the boot sector" screen appears after the desktop loads.
  • 217 Answers
This error means that the system is unable to access the boot device...for info on the causes and resolution of this error plz follow the following links
http://support.microsoft.com/kb/316401
http://support.microsoft.com/kb/324103
Posted on Jun 24, 2009
When i am trying to instaling win xp .getting a error message like stop 0x00000007B in a blue screen
hello Shameeralipk,
The most popular Blue Screen of Death error in Windows is the STOP 0x0000007B error, sometimes called the 0x7b error or the "INACCESSIBLE BOOT DEVICE" BSOD.
This BSOD (which is actually the common name for a STOP Error) could mean that there's a serious hardware problem with a hard drive controller, a driver issue, or even a boot sector virus.
thansk.
Sep 06, 2011 | Acer Extensa 4230 Notebook
Hi there! i just bought a new acer aspire m5641 (the rep told me that the computer doesnt come with an OS but when i booted it, linpus is installed) on my CPU there is a sticker that states...
Stop: 0x0000007B error code refers to memory issues
You need make some changes in your computer before installing XP
1. On start up, press F2 to enter BIOS 2. Expand the "Drives" section 3. Go to "SATA Operation" 4. Change this from "RAID Auto/AHCI" to "RAID Auto/ATA"
You will be able to install XP now
Jun 30, 2011 | Acer Aspire M5641 PC Desktop
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
Error while trying to install windows xp Stop: 0x0000007B on a dell Optiplex sx270
In your case though, this is most likely one of 4 capacitors that are known to blow out on any SX270. Slide the bar at the back of your PC to the remove cover side and look inside for swollen caps. Remove the fans and cpu cover as well and check around there. Replace any bad ones you can find with old caps borrowed from an old motherboard if you have one, or new ones from any decent electronics parts warehouse. This fix has worked for me on every SX270 I have ever had.
Mar 10, 2010 | Dell OptiPlex SX270 PC Desktop
I bought lenovo G550 last week. It came with Windows Vista. I want to install Windows XP on it. I have found that lenovo has driver for windows XP so that will make my life easy :-) But when I try to...
you are most likely getting a BSOD with a stop error code of 0x0000007B which is caused by the Windows XP CD that you are using doesn't have the SATA Hard Drive controller driver needed to recognize and utilize the hard drive. If Lenovo has XP drivers for this model then they should have a SATA driver (roughly 394k) that will need to be loaded FROM A FLOPPY DISKETTE during the boot to XP. (XP Requires the driver to either be slipstreamed into the CD or loaded from a floppy diskette. Trying to load the controller driver USB or a different CD will not work)
http://www.digitgeek.com/how-to-slipstream-sata-drivers-into-xp-cd/
Jan 11, 2010 | Computers & Internet
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
Gigabyte Ga-K8N Pro Windows XP Installation
Download "MEMTEST86+" from the Internet.
One version boots from a diskette;
another version boots from a CD-R (that you have created).
Either way, make MEMTEST do a "full" test of the RAM in your computer -- bad RAM can cause "unpredictable" crashes.
Sep 13, 2009 | Gigabyte GA-K8N PRO nVIDIA nFORCE3,...
O*oooooo7b(0*f7a21524,0*c0000034,0*00000000,0*00000000)
If you can install Windows Vista and only XP not work for sure this is the solution :
SATA operation mode is AHCI
To change this :
Open BIOS
Look for SATA Operation Mode or somethin equivalent and change-it to IDE or Compatibility Mode.
Jul 19, 2009 | Compaq tc4400 Tablet PC
Blue screen on dell svc tag:GSKTL1S.Ox000000ED,0x8734D9EO,0xC0000006 how to fix this error?
Fine..You have reached the Blue Screen of Death (BSoD)..common in Windows Operating Systems. Generally this must be a hardware problem. If parts liek RAM or bad sectors in Harddisk, such BSoD comes, indicating the crash of the OS. Try repairing XP using the cd. If not, go for a format so that the bad sectors in the Hard disk is repaired.
Thank you!
Sabharish
May 30, 2009 | Microsoft Windows XP Professional for PC
Wont load passed windows xp screen
Try holding down the "F-8" key when the emachines logo appears, see if you get a prompt for "safe mode". If you can get the system up and running in safe mode, shut it back down from the start menu. That should rewrite the boot sector and may clear the problem.
May 10, 2009 | Computers & Internet
Seagate Barracuda 7200.10 ST380815AS 80 GB SATA Hard Drive Logo
245 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
