Question about Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP)
Reset AP Canopy 100 series
Hello! I need to reset an AP Canopy 100 series. Can help me? Thanks!
SOURCE: DWL-2100 AP will not reset to factory defaults with reset push. Ideas?
Reset, hold for 10/15 secs, do it again 3 times total. Then it works.
Posted on Feb 27, 2008
SOURCE: reset to default a symbol spectrum24 ap-3021
On the Symbol Spectrum24 AP-3021 and what looks like all of the Spectrum24 AP models. There is not a reset button. We only have the RS-232 serial port to work with.
Start with the power off.
Short pin 2 and pin 3 together.
Plug in the power.
Wait 15 secs.
After the two network lights become solid.
Remove whatever you used to short pins 2 and 3.
(make sure to only jumper pins 2 and 3 - if you ground against the outer shield it will not work)
Cycle the power on the unit.
The password is Symbol and it is case sensitive.
Posted on Sep 17, 2008
  • 4 Answers
SOURCE: Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Posted on Dec 01, 2008
mhusa68
  • 10 Answers
SOURCE: Factory Default Motorolla Canopy 900mhz. AP
all you need is a phone cord (that you dont want to use anymore) just ground the number 4 and 6 wire together and leave the rest alone. plug it in the canopy and then power it on. It should then be at the default ip. I think its 169.254.1.1 or 192.168.100.1.
Posted on Dec 13, 2008
SOURCE: Reset AP to default
2.4ghz.will it operate on a city area?
Posted on Jun 03, 2009
Hard reset ap 6511
Dhruv-
Please contact Motorola Solutions for assistance. portal motorolasolutions com
Mark
Motorola Mobility Support
Sep 02, 2014 | Motorola AP-6511 Access Point
Cisco Acces Point series 1020 Air-AP-1020-A-KG
This is an enterprise AP and needs to run with a Cisco router.
Mar 30, 2014 | Cisco Computers & Internet
How to RESET Motorola AP 6532 Access Point to Factory Default?
This is the reset username Username : reset Password:
MAC address XX XX XX XX 10 20 = IP address of 169.254.16.32 *10 in Hex = 16 in Dec *20 in Hex = 32 in Dec
Apr 29, 2012 | Motorola AP 6532 Access Point
How to reset my ap password
press teh reset switch on the device with a samll pin or pointed object
Mar 29, 2010 | Motorola Canopy 5.2 GHz Wireless Access...
Reset AP to default
May 06, 2009 | Motorola Canopy 5.2 GHz Wireless Access...
Reset AP-700 failed
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
Jun 16, 2008 | Motorola Canopy 5.2 GHz Wireless Access...
How can I reset the margins of my Canon AP 610
Thanks, but I already solved the problem!!
Mar 04, 2008 | Office Equipment & Supplies
Hello, I need directions on how to reset the margin on a Canon AP 610 Typewriter, otherwise I'll go nuts!! I've already tried each single combination.. please help me!! Thanks! Kathi
Position the carrier to where you want the margin. Use the margin release to get past the current margins. set using the margin set buttton. Lawrence
Not connecting to internet
When you power down the canopy, what happens is you also do a hard reset which from your post re-establish the connection.
One of the many possible causes is that the canopy is loosing its DHCP lease on its assigned IP add. This may be a security feature/measure of your ISP limiting assigned IP add through a DHCP server for only a couple of hours to clients such as yourself. If this is the case then you have to bring this to the attention of your provider;
Another that you can try is to telnet to the canopy interface and check its settings. Its IP add is 169.254.1.1(255.255.0.0). Newer versions uses the 10.X.X.X (255.0.0.0) series, pls check which one you have.
Alternately, what can be done is to do a soft reset (not powering down/hard reset). Right click on your Networking icon in the System Tray and click on "Repair".
Other areas you can check/try are your router settings (if you are using one), settings of HTTP1.1 through proxy connections in IE, fix DNS (you can get them from your ISP). If you are using XP, there is also a registry tweak for DNS errors resulting to no connection (winxp_dnscache.zip).
Hope that this be of some help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Dec 31, 2007 | Motorola CANOPY 2400AP (2400APBC)
Motorola Canopy 5.2 GHz Wireless Access Point - AES Encryption (5201AP) Logo
194 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
