Question about NetGear DG834G Router
How do I connect a 3rd laptop to netgeat DG834g
A second lap was connected OK but having difficulty connecting 3rd. I have no info at all re this - Son is away!
  • 1,272 Answers
If you have windows XP on this laptop then follow the steps below:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
Rate it, if it helps.
Posted on Jun 26, 2009
I cannot get wirelessconect to my laptop from my netgear modem router DG834G.I can see the signal but unable to connect
check whether the dhcp option is turned on in ur wireless router. if its turned off, change it to on state and try. u will be able to connect. still if u din get access. use some other lap to connect to ur wireless network. if it is possible to connect with someother lap, then the problem is with ur lap. the wifi drivers might get corrupted. re-install it to fix the problems. if all above doesn't gets work, then the problem is with ur wireless router.
Jul 21, 2010 | NetGear DG834G Router
Having prob connecting a 3rd laptop
If you are aware of security encryption, if any, on the router then you just need to scan for the wireless network on the laptop and connect to your network.
Jun 24, 2009 | NetGear DG834G Router
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Netgear DG834G V4 Website connection problems
Please try to use a difrent DNS service.
For example open DNS:
Primary: 208.67.222.222
Secundary: 208.67.220.220
Jan 14, 2009 | NetGear DG834G Router
Connecting lap top
If this is a new router you will find everything you need in the router's manual. You will need that to set up the WEP key. If the router has been used wirelessly before, then you will need the WEP key to set up the connection through the windows wireless connection wizard. If you don't know the WEP key, you will have to connect to the router with a cat-5 cable and access the router that way with your internet browser to find the WEP key, or generate a new one. You'll need to type in the router's IP address in the address bar of the browser.
If you find my suggestions to be helpful, please share with us some details so that others may benefit from knowing the whole story. Thank you!
Dec 26, 2008 | NetGear DG834G Router
Connect netgear DG834GT to laptop - says limited connectivity
how do i connect the netgear dg834gt to my computer please help
Jun 29, 2008 | NetGear DG834G Router
Can't wireless connect to netgear router
With the router powered on, use a pen or paper clip to hold the "Reset" button for at least 10 seconds, this will reset the router to default settings and you can start over with setting your encryption protocols. Make sure to note the WEP/WAP key you assign.
May 07, 2008 | HP Pavilion dv4000 Notebook
NetGear DG834G Router Logo
101 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
