Question about Maytag MDB9100A Dishwasher
Maytag MDB9100AWB Dishwasher
I live in Brazil and have had some components of the control board of my MDB9100AWB dishwasher burned out when I turned the machine on (plugged to a 110 volts stabilized electrical outlet) at my new home. I have called a local technician (did not have another board to replace) and have ordered a new board directly from Maytag in the USA, but never received it.
The question is: Is there any place where I can obtain the MDB9100AWB controller board's electric diagram, so that I can try to fix the board myself?
Paulo Nobre
Embu, Brazil
SOURCE: Maytag Dishwasher
Posted on Sep 21, 2008
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
SOURCE: maytag mdb6000awb dishwasher will not start the washing cycle
Well, I fixed it. (It might be too late for the first post - I hope not - but it will hopefully help the next person, SOLUTION: Using a six point star bit, I opened the inside door panel. I carefully removed the inside panel from the door and noticed two rectangular modular connectors that connect on eitherside of the door latch assembly. One of them was loose/disconnected. I reconnected the loose/disconnected modular connector. All is working now. My Model # is MDBTT60AWB. I hope it helps.
Posted on Mar 31, 2009
SOURCE: MDBH945AWW maytag dishwasher panel lights will not
These control boards do not have fuses on them. I opened mine up when the front panel touch pad stopped working and the LED indicators were anemic. This is a sign of the ribbon cable connections have oxidized. The ribbon cable connects the touch pad to the control board.
Others have written up nice solutions on similar Maytag diswashers with the touch pad.
The previous expert shows that you can diagnose this by using a 10k resistor and connecting pin 6 and 10 on the ribbon cable connector and it will start the dishwasher (you have to trip the door handle and carefully do this with the power on). This proves that the control board is fine and ribbon cable connections are the problem. Don't forget to quickly trip the door latch once the dishwasher starts.
My solution was to purchase a contact cleaner called Deoxit. You can order from or get at Frys. Spray Deoxit on both the ribbon cable end (removed) and into the connector on the control board. Deoxit removed the oxide on the connectors. The twin pack Deoxit spray comes with a solution that helps prevent corrosion. I am 1 day into the successful repair of this model Maytag dishwasher.
Previous people have suggested heat and steam get into the control board and oxidize this connector. I notice on the top right where the control board sits, there is a gap to allow steam to get into the door/control board area. I used bathroom caulk to seal both sides of the door to hopefully prevent further corrosion.
Posted on Apr 11, 2010
  • 60 Answers
SOURCE: Calcium buildup in dishwasher-receiving low ampage
Have you tried cleaning with vinegar? Start the washer and let it get to the start of the wash cycle. Open it up and scoop out about a gallon of water from the bottom. Pour in a gallon of vinegar and let it finish the wash. May have to repeat a few times. This should get it. To keep it clean, add a few vitamin C tablets in with your detergent every few washes.
Posted on May 21, 2010
How do i determine if my Maytag dishwasher needs a new control panel or control board
Remove the cover on the inner side of the door and expose the backside of the panel and control board wiring. Look at the wiring and see if you see a burned cable. That may point you to where the problem is. I have seen burned wiring in that location, especially leading to the control panel itself having burned ribbon cable.
Dec 20, 2015 | Maytag MDB7749SBM JetClean Plus Dishwasher...
Why doesn't it work?
Dishwasher Diagnostic Touchpad is Not Working,Maytag ...
? 8:28
Aug 6, 2013 - Uploaded by
Troubleshoot your Maytag Built-in Dishwasher which has this following issues: Touchpad System Is Not ...
Maytag Dishwasher Repair - Will Not Start or Complete a ...
? 5:06
Aug 9, 2013 - Uploaded by
Troubleshoot your trusty Maytag Built-in Dishwasher which has some of ... Dishwasher Diagnostic Touchpad is NotWorking,Maytag,Whirlpool ...
Top 638 Complaints and Reviews about Maytag Dishwashers > Homeowners > Dishwashers
Rating: 1.2 - ‎185 votes
Can't push a button to choose what cycle I want, it doesn't respond. .... After 2 1/2 years the control panel on my Maytag Dishwasher will not work. This is the 4th ...
Maytag Dishwashers - > Homeowners > Dishwashers
My dishwasher just stopped working 1 year after purchase. .... Holding Control Lock or Delay for 3 seconds doesn't seem to clear the circuit board logic. Problem ...
Dec 12, 2015 | Maytag Dishwashers
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
Does maytag dishwasher model MD9100AWB have a interchangeable color front?
you model number is missing a letter I'm guessing its a MDB9100awb. They don't make them like they use to, where you can just flip them around nor you have to order a whole new front.
For White Order 99001416 For Bsq Order 99002109
For Stainless Steel Order 99002169 For Blk 99001417
they look to be around 75 buck
Oct 12, 2014 | Maytag Door Reversal Kit - Universal for...
My Maytag mdb7749awb1 initially wouldn't drain so I drained it manually. Now, no matter what cycle I select, the lights stay lit and the start light flashes, but no action. I've tried a couple of the...
I am a homeowner. Ooops I thought I had a maytag dishwasher but I have a whirlpool dishwasher. I also had weird symptoms and I opened up the door to look at the control panel. It had a disgusting collection of cockroach eggs and waste products. I've heard that this is a relatively common cause of dishwasher problems in Hawaii. (I don't know where you live or if you have cockroaches in your home) I would advise that you look at your circuit board and if you have cockroach problems and if the board looks corroded then it may be worthwhile replacing it, especially if your first circuit board failed because of cockroaches.
If you've not ever exposed the control panel's innards before, you remove the screws on the door and go from there. You may have to remove a plastic cover over the circuit board first.On my dishwasher I just removed the topmost 6 screws (4 along the top edge and on along the L & R edges of the door). Hope this helps
Nov 07, 2017 | Maytag Dishwashers
My dishwasher the maytag quiet series 300, will not respond to the start button
Find your circuit breaker for your dishwasher and turn it off for 3-5 minutes. Turn it back on, then turn on your dishwasher. If this works, after the complete cycle of your dishwasher, you have to turn it off manually by pressing "on" botton then press it 1 more time to cancel; this will turn off. The defect is, probably the moisture built up in the control board causing it to ground some of the connections. Suggestion for the manufacturer, insulate the control board to prevent absorbing moisture.
Jan 04, 2013 | Maytag Dishwashers
Had a power failure from bad weather now the dishwasher is dead? checked the fuse box the breaker is fine, there are no lights on the display panel. what is the reset procedure for this dishwasher?
Try turning the breaker for the dishwasher off for 30 seconds and turn it back on. This should reset the dishwasher control board. If it still doesn't work then most likely the power failure burned up the main control board. The control boards in the newer dishwashers are sensitive to any type of power surges or failures.
Hope this gets it running for ya.
Dec 15, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
My maytag dishwasher appears dead just after 1 year
You probably have a bad main control or console control unit in there. Turn power off to the machine, be sure that BOTH of your door switches are ok. Unplug your membrane to control panel ribbon cable, then put everything back in place. Leave the door open, then turn power back on to machine. (also, be sure the thermal fuse hasnt tripped while your in the console). After re-appling power, close the door, and wait a few, if the console unit is bad, the machine will go into drain mode (you will here the unit start in drain). If no drain mode, then your control is shorted. You dont have to see any burn marks, etc for one to be bad, in fact, 98% of the boards we replace, dont show any signs of problems. Let me know what you find out.
Nov 15, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag Dishwasher
Jul 01, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MDB9100A Dishwasher Logo
760 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
