Question about Dometic Rooftop RV Air Conditioner
99 suburban air not cold at all I don't see compressor clutch kick in all fuses are good
  • Dennis Boxerman May 11, 2010
    are you able to attach any gauges to the system to see if any refrigerant is in there? This is the starting point. Does it have freon in it?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 127 Answers
Try unplugging the pressure switch and jumping it with a wire. Either the high pressure or low pressure switch with make the compressor not turn on if bad. If the compressor kicks on, then check the pressure in the system. If the system is low on freon, have it repaired and all should be ok. If the freon level is ok, replace the pressure switch.
Hope this helps,
Jeff
Posted on Jul 05, 2009
2001 Oldsmobile Alero 4 cyl , Air Conditioning, compressor clutch will diss-engage. Blower fan is working, Freon psi is good, All the fuses and relays are good, Did some testing, and the compressor and...
The pressure means nothing as far as the state of charge. You need to have the system completely evacuated and recharged with the specific charge weight for that vehicle. Only then can the pressures or anything else mean anything.
Aug 18, 2013 | 2001 Oldsmobile Alero
Honda Accord 2003 4dr LX - AC does not cool always. The compressor does not kick in every time. When it comes on, it is very cold But otherwise there is no click sound. I got it checked by the mechanic...
Most likely a restriction in the lines causing the compressor to shut down after a breif period of cold air. Check for bad orifice tube or thermal expantion valve.
Mar 23, 2011 | 2003 Honda Accord
Air compressor not engage was blowing cold just quit while running check fuse all show good check freon all good no broken hoses compressor wont kick in getting fire ti presser switch
the clutch on the air compressor coil is proably burnt out. disconnect electrical plug at end of air compressor and supply current direct from battery to see if clutch engages, if it does not, change thecoil clutch switch.
Jul 23, 2010 | 2005 Kia Sedona
Truck AC keeps kicking off
Have you tested the presure in the system? Check the condensor, (is it clogged or restricted, also check the clutch fan. With engine NOT running, move the blade up and down. You should feel a resistance and there should me no lateral (front to back of vehicle) play.
Aug 15, 2009 | 1999 Ford F250 Regular Cab
Acura integra 96 Air Conditioner compressor did not run
Check the A.C>Relay or It could be low or leaking freon
Jul 06, 2009 | 1995 Acura Integra Coupe
The air on my 1998 chevy suburban blows but it doesn't get cold. I put free-on in it. It only took a little. The compressor will turn manually & will not kick on. fuse ok. electricity in harness ok....
Probably the electric clutch of the compressor is not working. This is the part that uses the power generated from the drive belt to drive the compressor. Normally if this is working, you would hear a sound in the engine compartment once you turn on the ac. Otherwise you may have only the AC blower spinning. If they check out OK, the thermostat may not be working. Your AC will not engage because it may be getting the wrong signal thermostat.
Jun 15, 2009 | 1998 Chevrolet Suburban
My ac on my 99 Chevrolet suburban not cold at stop
sounds like you have a minor vacuum leak in the system or a weak blend door motor. Your a/c is responding to engine vacuum changes.
Jun 13, 2009 | 1998 Chevrolet Suburban
99 Suburban A/C Not working
The A/C pressue switch may be bad as well. Also the mode switch on the control head inside the vehicle. There are many other exsisting problems pertaining to a/c. I suggest a manual from Auto Zone for many faults can be noted especially wiring can be at fault
May 23, 2009 | 1999 GMC Suburban
A/C Compressor is shot
generally speaking if the a/c clutch doesn't kick in it's because of either no voltage or low refrigerant. you can waste the money and just recharge the system and replace the a/c clutch, however it's been my expeirience that often times the compressor goes bad and that money was needlessly spent. this time of year the price to fix the system is far cheaper than the begining of the spring take the vehicle to a qualified a/c tech and your problem will cease. if you have no voltage that means the a/c clutch relay is bad. make sure all relays and fuses are good. the relays are clearly marked. quick to find out is to switch the cooling fan relay with the clutch relay if the a/c kicks in you know that relay was bad. hope this helps
Jul 08, 2008 | 1998 Cadillac DeVille
Dometic Rooftop RV Air Conditioner Logo
117 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
