Question about Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl
Saw does not idle and is hard to start. It is a P3314 Poulan
  • orinwalker Jun 24, 2009
    the saw is only 2 months old and been used 2 times. it was hard to start and would not idle out of the box
  • 10,865 Answers
You have gum in your carbeurator.
You can try a carb. cleaner that you add to the gas. I likve one called seafoam. You add one ounce per gallon of fuel.
Also, you must have a good clean spark plug, and a clean air filter. The spark, the fuel, and the air all contribute to an easy start and a good idle. If you havn't changed the spark plug lately do so, same with the air filter.
Posted on Jun 24, 2009
2 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Posted on Sep 04, 2009
HOW TO ADJUST THE CARB. ON A MODEL P3314 WILL START AND RUN FOR ABOUT 15 SECONDS AND THEN STOP RUNNING.
suspect that the diaphragm is going hard and is not sucking the fuel up from the tank properly
rekit the carby
Oct 02, 2016 | Poulan Garden
What is H and L carb setting for a Poulan P3314
The "L" is your idle setting and the "H" is the wide open fuel setting. After the engine starts and runs a minute adjust the "L" to the smoothest run setting the go full throttle and adjust the "H" the same way.
Hope this helps.
Apr 20, 2012 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
How do you adjust the idle on th poulan p3314 gas chainsaw and is there a special tool you need it just wont idle
Most poulan chain saw have three screws idle, high, and low.. if you look air filter cover you will usually see three holes and the high and low will usually have plastic covers on it.. adjust the low 1/4 of a turn and the idle screw in about 1/4 or until the idle picks up... On the plastic cover where the three holes are you will see H which is High L which is Low and I which is Idle... Let me know if you have any problems.. thanks
Jul 16, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
How do I keep it running?
Try adjusting the idle screw up around the carb.Hope this helps and Thank You for asking
Jul 19, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Model P3314 throttle is stuck
Remove the air cleaner assembly to see the carburetor throttle mechanism and open the handle so that you can access the throttle trigger. There should be either a cable or wire connecting the trigger to the throttle arm on the carburetor. Try moving the trigger and see if it responds at the carburetor. Is the carburetor arm against the idle stop screw, wide open, or some where in between? There should be a spring at the throttle arm that returns the arm to the idle stop if the cable/wire is disconnected. The trigger mechanism may be jammed with sawdust to prevent movement. Hope this helps!
Mar 19, 2010 | Poulan Garden
Need the know the correct H and L settings for our Poulan P3314 14 in. Gas Chainsaw - 33CC. The chainsaw will not idle.
There are no hard and fast settings.
The initial starting point "H" and "L" are 1.5 turns CCW from lightly seated.
The"T" adjustment enters here too (idle speed) and there is initial setting without a tach, depending on age may not be any initial "T" setting.
The "L" needle is primarily idle performance (not speed) and acceleration to full throttle.
The "H" is mostly performance at speed, but all are interconnected.
Fresh mix of fuel. Put ALL of the old mix in any 4 cycle and start new. I suggest 50:1 regardless of what your manual says. This is the best performance adjustment I have found.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If push comes to shove a local saw shop (I prefer Stihl mechanics and do not own a Stihl) should be considered.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 09, 2010 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan model p3314 recoil spring won't go in correctly
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
Mar 11, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan P3314 14" Gas Chain Saw 2.0 Cuin 33CC 2 Cycl Logo
532 people viewed this question
Top Poulan Tools & Hardware - Others Experts
Bill Boyd
joseph m fucci
joseph m fucci
Level 1 Expert
Are you a Poulan Tool and Hardware - Other Expert? Answer questions, earn points and help others
