You might want to turn your Gain setting down a little. Also Look to be sure you have enough air flow around the amp. If it cannot breath, the heat from the amp will build until it wigs out. Use your Ingenuity to get more air to the AMp.
sounds like you have the power antenna remote wire (blue) instead of the amp remote wire (blue/white stripe). when you go from radio to cd the power antenna wire shuts off.
Either the amp is ad or the sub got shorted? You can check itby disconnecting the Sub and seeing if the amp comes on blue then. If yes, then the sub is shorted. If no, then the amp is shorted. Also chck the voltage AT THE AMP. Make sure that it is above 12 Volts.
check your remote wire and check your power and ground, clean all connections with a contact cleaner/rejuvinator (ridox/deoxit).. many times the thin remote wire will develop breaks or conductivity issues over time, i have replaced many of these just in the last few months.
to make sure this is the problem, remove the remote wire and temporarily jump the power wire to power and remote, the amp will always be on at this point, but it should help you diagnose whether the remote wire is the problem or if it is an amp or cabling issue.
