Question about Dometic Rooftop RV Air Conditioner
Heater and AC run even though thermostat is off
My heater and AC will run even though the thermostat is off. I have to pull the fuse on the heater and breaker to off on the AC to get them to shut off. The AC only runs when plugged into 110 power of course and heater will run off batteries or house power. I swapped out the thermostat and it's still doing the same thing. I have a Conquest travel trailer with dual control thermostat. Dermatic is the brand. Please help.
    Novelist:
  • 127 Answers
It sounds like you have a short in the control unit at the ceiling pack. Remove the inner shroud from the AC and pull down the control unit. Remove the cover from the control unit to access the relays. With the thermostat off, check for power at the white (or orange depending on the unit) wire coming from the thermostat to the relay board. Also check power from the yellow and gray wires from the thermostat to the control board. None of these should be hot with the thermostat off. If there is power then you have a short in the wiring between the tstat and the upper unit. If there is no power, then you have a bad control board.
Hope this helps,
Jeff
Rate please!
Posted on Jul 05, 2009
The heater is blowing cold air
Check heater hoses running from the engine to the cabin. and check if heater switch works
Nov 28, 2012 | Cars & Trucks
The difference between thermal fuse and thermostat
Thermal fuse is a heat-sensitive safety feature that shuts down system when overheating is detected.
In electrical wiring, the thermal fuse reacts to high temperature caused by too many amps on the electric circuit. When temperature exceeds the fuse amp rating, then the fuse trips and cuts power to electric circuit.
Example of thermal fuse is a household circuit breaker.
Gas water heaters have a different type of thermal fuse located in the combustion chamber or on the combustion chamber door, and also inside a copper probe inside water tank. Water heater thermal fuses will trip when water temperature exceeds fuse rating, or when heat inside the combustion chamber exceeds temperature rating of fuse. This action will cut off gas supply to water heater.
So a thermal fuse is a safety feature.
Thermostat is not a safety feature.
Thermostat is a measuring tool.
Thermostats measure temperature.
Example of thermostat is outdoor thermometer, or cooking thermometer, or Heat-AC control located on wall inside house.
Thermostats can give a simple temperature reading, or they can cause a separate control to turn on-off depending on application.
For example thermostat on Heat-AC will read room temperature, and when temperature exceeds setting, this triggers a switch that turns Heat-AC on-off.
Many appliances have both thermal safety fuse and thermostat.
Take for example a gas water heater. A copper tube extends into the water tank. Inside the copper tube are 2 things: A thermostat probe to measure water temperature, and a thermal fuse called an ECO for energy cut off. The ECO is a thermal fuse, and is a safety feature.
http://waterheatertimer.org/images/Gas-valve-ECO2-358.jpg
The thermostat reads temperature of water, and turns water heater on-off to keep water hot. A person can adjust water temperature by adjusting the thermostat dial on front of water heater.
However if the thermostat fails, or some other problem occurs, and water inside the tank gets hotter than 180 degrees, then the ECO or thermal fuse will trip. When the thermal fuse trips, this turns off gas to the water heater so water cannot get any hotter. The safety device prevents water heater explosion. The water heater must be repaired since this particular thermal fuse cannot be re-used afterwards, and must be replaced.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 11, 2012 | Dryers
Difference between thermostat and thermal fuse
Hello Mary
Payne AC not working. 1. Thermostat set 68 to AC w/fan on. 2. Breakers and switch near heater are on. 3. Outside unit has 220v but is not running. 4. Fan in heater/Ac unit is not running 5. ...
Dan is this a new system, or has some work on the system (to include the thermostat) been done recently?
Sounds like the thermostat may be wired wrong. From what you describe, the igniter element is coming on, as though you are calling for heating. Do you allow the ignitor to keep going and see if the gas fires off, or are you seeing this and shutting down the system immediately?
If you had the t-stat changed recently, or this is a new system, contact the installing contractor. It may be under warranty.
Sep 03, 2010 | Carrier Heating & Cooling
My mini one is overheating I have replaced the thermostat. Even though the engine is overheating the heater is not getting warm.
make sure your coolant level is not too low.if all is good sound like water pump bad.check fuse controls heater and ac controls.if fuse looks okay.you have a faulty heater air control air flap motor.or electrical problem to heater air control air flap motor.also check engine oil if it looks like milk shake.you have a blown head gasket it will cause over heating problems.
Jan 03, 2010 | BMW Mini Cars & Trucks
How can I tell if the thermostat is broken or not?
Before going to electrical components ,please firstly check the power supply ,then the electrical wire to the heater and so on .
Oct 04, 2009 | Honeywell Programmable Thermostat Heater
Ac and heater not working. New Heater core and
You need to but a scanner on the computer and activate the AC. If it does not activate you may have a bad PCM. Also if the pressure in the AC is low it will not run. Also you have a AC relay in the engine fuse box.
Now for the bummer part. I have this same truck. Replaced heater core and I didnt get the blend door quite on track and it jammed. I had to take the dash off again. Also your center heat control may be bad.
I don't think these two problems are related. Even without AC your heat should work. Do you have rear climate control also. See if that works. If it does you may have a jammed door for the dash area
Aug 10, 2009 | 1998 Ford Expedition
Problem with my Airtron Thermostat
Two things, first go up to the heater and check the fuse inside the heater, looks like a car fuse. If that is not popped, then go outside to your AC unit and pull out the emergency disconnect. Check those fuses with a multimeter. IF you do not get anything replace those fuses, It has nothing at all to do with your thermostat.
Feb 09, 2009 | Honeywell Programmable Thermostat Heater
Need thermostat for 170t reddy heater
reddyparts.com still has most parts for reddy heaters even though reddy heater went out of business in 98.
Feb 09, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
HEATER DOES NOT TURN ON BUT AC WORKS.
- If no voltage output at the thermostat for the supply of heater/reversing valve, then replacement of thermostat is needed (but check the thermostat setting).
- If the voltage output at the thermostat for the supply of heater/reversing valve is present, then then check for heater/reversing valve fuse or overheat protection, and check for defective heater/reversing valve
Jan 03, 2008 | Honeywell Programmable Thermostat Heater
Dometic Rooftop RV Air Conditioner Logo
311 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
