Question about Delphi 10.2" FLIP DOWN MNTR/DVD (GRAY)-MV10018 Car Video Player
DVD player will not play disc.
DVD player will play disc. It says "open" and then it says "load a valid disc" and then ejects disc. Disc is also hard to initially load as it "closes" before you can load it. HELP!!
    President:
  • 1,114 Answers
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Posted on Jun 24, 2009
Vbr220 will not play blue ray but will play dvd it ejects blue ray disks
Does not play disc
1.No disc. - Load a disc into the tray.
2.Disc has been loaded upside down. Place the disc with the label side up.
3.Disc region code does not match region code of the player.
4.Disc type is not the correct type to play.
5.Disc is damaged or dirty. Clean the disc or try another.
6.Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.2_9_2013_12_09_45_pm.jpg
Use the owner manual for additional information.
God bless you
Feb 09, 2013 | Vizio Televison & Video
Clarion ohm107vd in car DVD won't eject disc
It not the disc, it won't take a disc ...... if I go to put one in it Makes noise but won't actually take the disc. Would this be the loading gear and can it be fixed or?
Jan 08, 2012 | Clarion Car Audio & Video
My dvd wont eject. when i press open it blinks for a minute then goes to loading! then dvd will then play. I can hear it running but it will not eject the dvd.
unplug it for 10 - 15 mins... when you plug it back press the stop/eject quickly (player will automatic try to load disc)
Aug 09, 2011 | Toshiba SD-6000
DvD disc won play
the lazer might not be seeing the disc properly try a disc cleaner which has nylon string on it and they clean the lazer lens
Jul 06, 2010 | Onkyo DV-SP800 DVD Player
When the disc is loading it stops and says
pls. check regnel code seting .
use remote cantrol on setup menu open and selact regnal code set Adealt . or all regnel code after then use disc is play caractly
if not then problum is inside your disc player .
Use. lance clenar disc and clenig your disc player lance.
Oct 20, 2009 | Venturer 3.6" Portable DVD Player
Hi i am using vista, and am using dvd shrink 3.2 version to burn dvd discs i open my disc in dvd shrink then back up in dvd shrink to file created in documents, then dvd drive ejects disk and asks for...
you must remove the region lock off the DVD image you're trying to burn make it region free. your DVD player might have locks on which DVD regions you can play, your DVD writer doesn't come with a region lock that's why you're able to play the disc
Sep 21, 2009 | Ritek /RIDATA DRD+4716-RDSM50 16X DVD+R...
No valid disc
your not using a good disc. use a regular disc and no blue rays
Mar 31, 2009 | GPX D1816 DVD Player
Portable dvd player showing"no valid disc"
try to clean the lens using cd cleaner or cotton buds with drop of water on it. that really works.
Dec 03, 2008 | Venturer PVS177W Portable DVD Player
Problem with dvd player. Trutech 7 inch
I was told that they could reset it but I can not find a number on this company
Mar 20, 2008 | TruTech PVS12701 Portable DVD Player
Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Aug 10, 2006 | Sony RDRGX210S DVD Recorder
Car Audio & Video Logo
310 people viewed this question
Top Delphi Car Audio & Video Experts
Billy Mac
Lawrence Oravetz
Jeremiah Meyer
Jeremiah Meyer
Are you a Delphi Car Audio and Video Expert? Answer questions, earn points and help others
